GAS SMELL
I have a 2001 GXE and I have noticed that when I finish driving the car it smells like gas.What can be the cauase of the smell.
Originally Posted by bluebriscoe
(Post 6447749)
LAWL^
Originally Posted by UGAd13
(Post 6447898)
I have the same problem. Mine usually occurs after eating Mexican food. Not sure where it comes from…
:mrgone: :fart: *a leak somewhere? |
its burning to much gas? do you have any check engine lights?
like an O2 sensor ? |
Check the fuel pressure regulator (if its easy or even has one, not sure)...I know one of those suckers went on my last car and caused it to smell like gas...
I had the same problem under hard acceleration. My ECU needed a reprogram because it was running WAY too rich (120% higher than normal)
its burning to much gas? do you have any check engine lights? like an O2 sensor ? |
Get this resolved ASAP.......and why would you ignore the fault code, particularly with an apparent rich condition. This is an O2 sensor code but it can be caused by other engine operational issues. If you have no obvious vacuum leaks or holes in the exhaust, you need to get it hooked up to a scantool to observe the O2 sensor readings and response etc. Has the SES light ever been on?
No the code is not an O2 sensor code the code is for a faulty pre-cat.And I cant resolve a problem that I dont know what it is.Thats the reason I posted the question.
Sorry, it is a "cat. code", but triggered by the O2 sensors. But as I tried to explain, the root cause may actually be one of several things. This particular fault code can turn into a can of worms and it really is an advantage to get the car hooked up to a scantool for troubleshooting, and to follow the FSM step by step. You do not want to just start throwing parts at the car. If you have no SES light on and no other obvious problems as I already mentioned and nothing has been done to the car recently, then my gut tells me that it could be the MAF, but I'd just be guessing.
The ses is on the code is P0420 but that should not make the car smell like gas on the outside.
Originally Posted by P. Samson
(Post 6452371)
(Post 6452070)
I do have the code P0420 and it does seem to get poor gas mileage.
Originally Posted by SoonerFan
(Post 6452958)
so you know what the problem is....fix it
Not sure if you read P. Sampson's post, but if you have not.. do yourself a favor and do so. It (reading) will greatly benefit you.
ive had that code for months and the car is fine
So you think. You could be slowly deteriorating your cats.
Im no disagreeing with P. Sampsom I have done those steps and I got the P0420 code which led me nowhere.
Originally Posted by NmexMAX
(Post 6453693)
Could I just eliminate this problem with a aftermarket y-pipe?
(Post 6454147)
What does?
(Post 6454190)
What does?
(Post 6454255)
sorry...just saw that you have a 3.0....y-pipe will get of pre-cats
Originally Posted by M1RAG3
(Post 6455753)
Are pre-cats proven to be the cause of the gas smell? How often do they really go bad? Im kind of confused about this
We've tried to explain to you.......your "gassy"/rich mixture smell is not caused by a precat or cat. Neither is your poor fuel economy. There is a problem with the basic engine fuel metering/emissions control system. I think that you are confusing a basic fault "code scanner/reader" with a "scantool" such as Nissan's "Consult ll", or what is commonly called a "generic scantool" that are made by companies like SnapOn, Actron, SunPro etc. They usually start at about $350 and run up to several thousand. A "scantool" has the capability to read (and store) live streaming data as seen by the ECM from all the different sensors (such as the O2 sensors) and to monitor all the ECM data related to engine operation/performance. It's not as simple usually as just coming up with a fault code. There is a fairly involved step by step procedure in the FSM for troubleshooting this fault code and actually determining what is the real problem.
I had a similar problem with my A33 and it was a fuel connecting line in the engine bay.
Were would I go to get the car scanned?
(Post 6447749)
© 2024 MH Sub I, LLC dba Internet Brands
