Will 95-2000 Rear Sway Bar fit 03 maxima ?
I just want to ask a simple question. would a Progressive sway bar 95-2000 fit the 2003 Chasis ?
I have someone who is selling that sway bar, and I have a hunch it will fit my 03 Titanium 6MT, but just wanted to get expert suggestions.
As mentioned above, if it fits 2000, it WILL fit 2003, the rear beams have minor differences between 2000-2003, i have installed a 2000 beam into a 2003 with no problems so that sway bar should fit with no problems. It should also fit all 4th gens too since the design is very similar to 5th gen beam even though they are not the same.
So this is what i came across:
http://www.nolimitmotorsport.com/pro...anti-roll.html
That being said, i am tempted to go ahead and buy it
a short .org search shows that the bar fits on both, but the adjustment is different so just make sure that you put it on according to 5th gen directions and not 4th gen. im not sure how you even do that cause i have a stillen, which uses different holes for 4th than 5th, but i guess the answer is that it will fit
according to the progress pdf file it will fit 95-03 part number 62.1520. Reason it may say 95-00 is because the springs are different and the way they set up the catalogue they couldn't put 95-03.
But 95-03 uses the same antisway bar
kingw323
20
10-21-2015 08:36 AM
Huttig2009
09-25-2015 03:31 PM
