Is this true? What a Nissan dealer told me.
I called up my local Nissan dealership today to make an appointment to bring in my 2k Maxima next week for my oil change, front end alignment, and 30,000 miles tune up. I did some checking around for the front end alignment (I recently put on 18's) and the dealership is the same price as most other shops where I live so I figure why not? Take care of it in one shot. So, I tell the dealer that I have been getting really bad gas mileage these past few months where I'm averaging around 18-19 miles per gallon instead of around 22. He asks me do I fill up on premium gas? Yes, all the time. Do you speed everytime you drive? No, hardly at all. Do you drive for less than 15 minutes at a time? No, more like 30-40 mins. How many miles do you have on your car? 30,895 miles. Well, theirs your problem. And I say what problem? He tells me that the more miles you put on your car, the worse your gas mileage gets until you get a complete tune up in which it will improve your gas mileage. He also says that since I have an SE, we get worse gas mileage then the GXE and GLE. Has anyone ever heard of this before? I'm still kind of new at learning these things so any help would be great! Thanks.
Shadou |
I say BS. Unless the SE has a different set of gear ratios, they all have the same engine.
And at only 30,000 miles, your car should be peaking mpg wise. |
This is the biggest BS i have ever heard...don't listen to any of them dealers, check your tire pressure
SEs have the same exact engine as the GXE and the GLE...its only a difference in the suspension and exterior(wheels..etc) |
was it a tech who told you that, or a service manager? I can't imagine the tech telling you wrong stuff like that... but a service manager is another story :rolleyes:
Originally posted by UMD_MaxSE was it a tech who told you that, or a service manager? I can't imagine the tech telling you wrong stuff like that... but a service manager is another story :rolleyes: Shadou |
Originally posted by yo_its_ok details, possible that your 18s might be causing it as well as alignment. Simply have the spark plugs checke, someone from maxima.org should be able to help you check them out, but I'm pretty sure your plugs should be fine. Only thing I can think of is that your air filter given its stock paper should be replaced by now. Beyond that, whatever Nissan said is absolute BS. try a different brand of gas, its possible that the tanks at the gas station are old and a chance for "bad gas." Good Luck -Peace Shadou |
Definitely a BS line for the SE vs the other models. As for mileage, 30k should not be when your car stops dropping off in mileage either!
The only thing I can think of are the wheels - actually, tires. What size tire is on there now? Wondering how much your speedo is off - that would definitely cause a miscalculation in the gas mileage. |
Yo, man. Dealer as always full of BS. Who on the org can that really surprise? Change ur brand of gas. Change ur spark plugs(do that urself). If u still have ur 17's stockers, drop them back on. My SE with 28k averages 20-21mpg in stop & go city traffic. On long trips in excess of 40min., I averages 26-27mpg. That is an automagic. Last car I owned was a 2000 V6 Accord Coupe. Intake, Greddy full catback, 17inchers(non-stock low profiles), averaged 21-22 city driving(even with 45k when I wrecked it), 28mpg on long trips. Hook up with someone on the org in your area. Dealer BS(what a surprise). Good Luck.
had the same problem with my max too. i was getting 22 mpg on the dot every tank. and then it started to dive, don't know why. i was getting like 17-19 mpg for a while. well i disconnected my battery overnight to clear my ecu and after that everything's been kosher. i have no idea what the problem was, but resetting the ecu seems to have taken care of it.
Originally posted by Pat DiPersia Definitely a BS line for the SE vs the other models. As for mileage, 30k should not be when your car stops dropping off in mileage either! The only thing I can think of are the wheels - actually, tires. What size tire is on there now? Wondering how much your speedo is off - that would definitely cause a miscalculation in the gas mileage. Shadou |
Re: Is this true? What a Nissan dealer told me.
pretty much bs. and as UMD_SE already mentioned, you need to watch the service managers, they're paid on commission and a LOT of them BS (trying to be 'politically correct' by not saying ALL:goofy: ).
besides driving 30 - 40 mintutes at a time, is that local or hi-way driving? if that's local, the max's mpg differs greatly. i can get about 500 miles on a full tank when i drive up north :eek: . no way i could get that driving local. kafene. |
Re: Re: Is this true? What a Nissan dealer told me.
Originally posted by kafene pretty much bs. and as UMD_SE already mentioned, you need to watch the service managers, they're paid on commission and a LOT of them BS (trying to be 'politically correct' by not saying ALL:goofy: ). besides driving 30 - 40 mintutes at a time, is that local or hi-way driving? if that's local, the max's mpg differs greatly. i can get about 500 miles on a full tank when i drive up north :eek: . no way i could get that driving local. kafene. Shadou |
IMPORTANT~~
YOU KNOW WHAT, SINCE U HAVE PRETTY BAD GAS MILAGE, U NEED TO DO THE FUEL INJECTION. TRUST ME, AFTER U DO THAT, UR GAS MILAGE WILL INCREASE "A LOT"....I JUST GOT MY MAXIMA LAST WEEK SO I DONT KNOW MUCH ABOUT MAXIMA, BUT I USED TO HAVE 2000 ACCORD V6, I ALSO START GETTING BAD MILAGE AFTER 30000, AND AFTER I DID THE FUEL INJECTION, I WAS SO IMPRESSED THAT MY GAS MILAGE INCREASE A LOT...SO U SHOULD TRY THAT, COST U ONLY 40-60 DOLLARS DONT PUT THE FUEL INJECTION LIQUID INTO UR GAS TANK, CUZ THAT'S USELESS....SO GO TO THE FUEL INJECTION SERVICE AS SOON AS POSSIBLE~
SE's should in thoery actaully get worse gas mileage. Why you ask? Because the tires are wider, this causes more drag and results in a slight loss of MPG. The difference is very little I am sure. Possibly heavy 18" wheels and wide tires will also give you worse gas mileage. FYI I noticed that I lost 1-2 MPG with my old 17's rims when compared to my 15's.
which dealer? i got a friend that works as a service manager at tony nissan. sounds like bs to me.
Originally posted by shadou Yeah, I believe you when you say that most service managers are full of BS. Most of the driving that I do is both a combination of city and highway as I live in Hawaii so theirs not to much highway to go far. I live in the city but work on the other side of the island (Oahu) so I have to drive on the highway through the mountains. All up hill on this one so wondering if this could affect my gas mileage as well by putting stress on my engine. I usually average around 40 miles a day rt but it seems that the gas mileage keeps slipping lower and lower. The other day my gas light came on at 260 miles on my odometer. Not good but thanks for the advice. We'll see what I can do. Shadou |
Service managers will BS the most out of anyone at the dealership. I've had nothing but BS and trouble at my dealership.
Next Cruise...
hey Todd...
Next cruise, or whenevers, let's fill up on gas, cruise aroud till maybe 3/4 tank then fill up again. Then we can compare numbers and see if there's something up w/ your car or both our cars... I get bad mileage too... I increased air pressure in my tires to 36 front and 33 back. That seemed to help. Initially I used to get 18mpg when i first got it, these days it stays around 20 sometimes 22. . . sleeptime... Bryan |
Originally posted by max808 which dealer? i got a friend that works as a service manager at tony nissan. sounds like bs to me. Shadou |
Re: Next Cruise...
Originally posted by pinakbet hey Todd... Next cruise, or whenevers, let's fill up on gas, cruise aroud till maybe 3/4 tank then fill up again. Then we can compare numbers and see if there's something up w/ your car or both our cars... I get bad mileage too... I increased air pressure in my tires to 36 front and 33 back. That seemed to help. Initially I used to get 18mpg when i first got it, these days it stays around 20 sometimes 22. . . sleeptime... Bryan Todd |
talk to shane over a tony nissan. you should think about doing the 30k check/service yourself. all of the stuff recommended you can do, just buy oem or better parts and fluids. save some $$$, times are tough. i only go to the dealer when something big happens or something i can't do myself. btw, i take my car to new city since i work nearby. if you need parts go to new city, chad is a nice guy.
Originally posted by shadou Yo, what's up? I went over to King Windward since I work over in Kaneohe and I figured it would be easy. I guess they would do anything to get me to pay $280 for my 30,000 mile check up even though it is due for that. I just can't see paying that money right now. Let me know about Tony Nissan if you can. Thanks. Aloha!! Shadou |
Originally posted by shadou I just recently (as in three weeks ago) put on my new rims and tires, ADR GT Sport, 18's, with Falken Z Rated 235/40/18. Love the rims and tires but you may be right. Don't know a lot about the speedo so can you possibly give me a quick lesson on what that is? Thanks for the help!! Shadou |
Originally posted by emax95 SE's should in thoery actaully get worse gas mileage. Why you ask? Because the tires are wider, this causes more drag and results in a slight loss of MPG. The difference is very little I am sure. Possibly heavy 18" wheels and wide tires will also give you worse gas mileage. FYI I noticed that I lost 1-2 MPG with my old 17's rims when compared to my 15's. -Tom Z. |
Re: Re: Next Cruise...
Originally posted by shadou Sounds like a plan to me. Let me know when you free or we can wait until December when Keegs gets back from school. Maybe I try the air pressure thing to. Laterz. Todd I go to New City for service too, but I don't like the guy Craig...I think he's a service manager. He gives me attitude no matter how nice I am to him. Talk to Orlando if you can (@ New City), he's a service writer I think, and he's nice. |
Re: Re: Re: Next Cruise...
Originally posted by Maximum Velocity I get 22 mpg on the average, but I drive speed limit and my car is heavier, therefore more resistance and more strain on the car. Also, with the AE kit, I get more front end downforce, but then again this downforce could cause the car to be more aerodynamic in having a lower center of gravity, and allowing a slipstream to pass over the car more so than under the car (also causing additional downforce). The kit really made a big difference, and I felt it immediately. What type of gas do you use? But yeah, when I get home, then we can try something too. So far (knock on wood) the gas mileage has been pretty good. The K&N should allow some small difference in your car's performance. It's well worth the money in the long run. Let us know how everything turns out. I go to New City for service too, but I don't like the guy Craig...I think he's a service manager. He gives me attitude no matter how nice I am to him. Talk to Orlando if you can (@ New City), he's a service writer I think, and he's nice. Shadou |
craig is japanese and a little older guy.
orlando is philipino looking and younger looking. hope that helps. Originally posted by shadou Mahalo!! Shadou |
Worse Mileage on SE
Maybe the dealer thinks that SE's get worse mileage because they are on average driven a little harder than the other Models. If you are accelerating more than needed to have some fun, it wastes some gas. So I guess it is possible that on average SE's get worse mileage. Just a theory so don't go bashing me.:kiss:
Re: Worse Mileage on SE
Originally posted by AudioMan Maybe the dealer thinks that SE's get worse mileage because they are on average driven a little harder than the other Models. If you are accelerating more than needed to have some fun, it wastes some gas. So I guess it is possible that on average SE's get worse mileage. Just a theory so don't go bashing me.:kiss: Shadou |
© 2024 MH Sub I, LLC dba Internet Brands
