how to remove the tie rod ends on 2001 maxima
i had to replace the spindle and found that the tir rod ends are worn out thye are the original ones and we tried to remove it but can't used plenty of wd40 and i even heated them but still the nut removes unmoved how can i remove it coz without the new one installed i cant install the spindle
thanks
D
thanks
D
If i am reading your post correct, you are having trouble removing the nut? heat should usually do the trick, that is heating the nut till its cherry red, usually requiring an oxygen torch, home depot sells a small oxy-mapp torch for $50. If you where just using a propane or mapp torch that usually wont be enough...Or a grinder w/ a cutoff wheel, and just cut the bolt/nut @ the base.
If its the tie rod end itself that is seized into the spindle, pick up a front end service kit. harbor freight has them for $80 or you can loan on out from advanced auto parts for free.
kingw323
20
10-21-2015 08:36 AM
District
08-15-2015 08:23 PM
kirkhilles
08-08-2015 10:53 AM
