Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   Put H&R's on the fronts (https://maxima.org/forums/5th-generation-maxima-2000-2003/578408-put-h-rs-fronts.html)
maximase86 Dec 15, 2008 09:13 AM
Lowered the fronts. Granted I need to give a couple weeks of settle...it didn't seem to help my cause much. I haven't done the rears yet because I rounded the bolt on the passenger side that connects the strut to the multi-link beam.
These are H&R's on Tokico blues. Keep in mind I'm running tires that are to small (225/40/18). So tell me, something look wrong with this? The car did get a little lower. Instead of being about to put a fist in, I can put 3 fingers. :(
Before:
http://i38.photobucket.com/albums/e1...a/IMG_0510.jpg
With 235/40/18 tires
http://i38.photobucket.com/albums/e1...a/IMG_0294.jpg
After:
http://i38.photobucket.com/albums/e1...a/IMG_0514.jpg
ChrisMan287 Dec 15, 2008 09:21 AM
Doesn't look like it lowered at all.
gxe2se Dec 15, 2008 09:31 AM
Give it time to settle. BUT H&Rs do not typically look lowered. However, your handling will be tightened. Its not all about looks. :-)
Eibachs would have been a better choice. IMHO.
Ahmad_1290 Dec 15, 2008 09:32 AM
hmmm. i was thinking about doing this too.. Not too sure i wanna do that anyone. lol
Gollum67 Dec 15, 2008 09:52 AM
H&R's usually drops 1.4" on the front. Very little difference between the last two pics. Did you take before and after measurements?
phatboislim Dec 15, 2008 10:03 AM
not that noticeable
blkonblkmax Dec 15, 2008 10:22 AM
Clean ride you got there, but it doesn't appear to be lowered. Hopefully you'll notice a difference once the springs settle.
playboi21617 Dec 15, 2008 10:29 AM
i have H&Rs on the front (ONLY) now on stocks rims and it looks alot better than that with illuminas. it handles better on the freeway it doesnt feel so much like a boat. i have pics on my cardomain page with my 20s on check it out. PM if you have any questions.
Puppetmaster Dec 15, 2008 10:33 AM
I didn't think springs really settled significantly lower over time (maybe slightly, but it shouldn't be noticeable), but only settled in place with respect to other components so as to eliminate the little squeaks and clunks caused by components not completely seated properly. Over time and with the full weight of the car, components in the suspension assembly shift slightly into "permanent" positions, for lack of a better description.
Drockb418 Dec 15, 2008 11:09 AM
or maybe there fake springs!
hi-tek22 Dec 15, 2008 11:28 AM
i cant tell a difference......where did u get the springs from?
Ive got H&R's and even without my 19's on the car, i can tell its been lowered, and so can others
rroderiques77 Dec 15, 2008 11:30 AM
You will notice a difference when you do the rears. I did with my H&Rs
ChrisMan287 Dec 15, 2008 11:53 AM
What you should have done was gotten some Eibach's.
ShippedOut Dec 15, 2008 12:14 PM
Should have gotten S-Techs (They have the lowest drop rate IIRC). Other than that looks good. I Need some G35 lol.
ChrisMan287 Dec 15, 2008 12:24 PM
I don't think he wanted that much of a drop, thats why he went with H&R's.
MetaOrbit Dec 15, 2008 12:33 PM
Doesn't look as low as mine, but then I think the tires (being too small) are exaggerating the appearance of the gap. I think if you had a set of 245/40/18 on there you'd be much happier.
overbo0st2k4 Dec 15, 2008 12:35 PM
I was thinking about doing this. Have you noticed a difference in the handling? Specifically when cornering?
maximase86 Dec 15, 2008 01:49 PM
Thanks guys. For those who said I should of gotten something else, the reason I went with H&R's was mainly ride and comfort. Even since I totaled my 4th gen (which also sat on H&R/Tokico Blues), I got a really sensitive back now. I had Eibach's in my 2nd gen, they rode sort of stiff for my tastes. S-Tech would be murder on me. I did want to eliminate some of the gap, but it really is not helping with running smaller tires than I should be running. The wheels came off my 4th gen, so I was incline not to spend more money when swapping to this car.
As for the ride, the front firmed up nicely without being harsh. So the ride quality will be where I want it once everything is done. I just wanted to verify there wasn't a problem with my install...(no squeaks, steering is perfectly centered, no noises) because it sure didn't look like anything happened. I've done a lot of suspension installs, and I was a little surprised by the result. However as I mentioned the gap is less. I wish I measured before I started and after.
S
maximase86 Dec 15, 2008 01:51 PM
Yes, the front is firmer and I can be a little more aggressive in cornering, but with the stockers in the back, I don't have a final verdict because of the mismatch.
S
2k0to2k3 Dec 15, 2008 03:46 PM
i have h&r on front only and when first installed i had 245/45/18 and it made a huge difference in appearence and much less noticable gap. now i have 235/40/18 and it looks even better. maybe your tire size is really throwing them off or you got fake springs or h&r but for another vechicle?
not sure what the deal is but i went outside and looked after seeing yours and i have much less gap in mine then you without a doubt
maximase86 Dec 15, 2008 04:00 PM
I doubt they are fakes. I compared them to my 4th gen H&R springs, labels are the same springs look similar albeit one was for a 4th gen and the other for a 5th gen. They are a bit shorter than the stock GLE springs. The front rides just like my 4th gen did. I'm thinking the tires are really what is affecting the look.
Puppetmaster Dec 15, 2008 06:01 PM
:sprint:
235/40s are too thin still, but 245/40s would be perfect, IMO.
maximase86 Dec 15, 2008 06:34 PM
Originally Posted by Puppetmaster (Post 6760736)
:sprint:
The current ones on the rims now are 225/40/18 which makes it even worst. I definately want 245/40/18 at least. I'm really tempted with 245/45/18 as well.
S
Puppetmaster Dec 15, 2008 07:08 PM
245/45s will be pretty far out of spec. According to the tire calcs, it will read 3.2% slower. 245/40s will read 0.5% fast and that's actually pretty damn close to stock. As a point of comparison, 235/40s will be 1.8% fast.
http://www.miata.net/garage/tirecalc.html
nismowolfe Dec 15, 2008 07:51 PM
I have h techs all around and they are 1.5 up front yours are 1.4 and mine looks way lower.
maximase86 Dec 15, 2008 10:31 PM
So the tire definately has most of the effect. I used the tire calculator to get my overall diameter. My stock tire size is actually 215/55/17 (GLE, dunno why they got different size tires...). Stock diameter size is 26.3 inches. With the 225/40/18's I have now, the diameter 25.1 inches. That would definately make a big difference. Since my stock tires are different than SE's, 245/45/18 would actually be a closer fit, making the speedo 1.4% slower vs. 2.3% faster with 245/40/18's.
Pretty wierd huh?
S
notuptodateguy Dec 15, 2008 11:56 PM
That's about how my car look with 225/45/17 and H&R/Tokico Illumina. Switched to 235/45/17 and it looked a little bit better, but still gap. Switched to h-tech and looks perfect to me, not too dropped. And to nismowolfe, it's about the spring's rating (or whatever the correct term is) that determine the actual drop rate. But I do miss the comfort from H&R springs.
Puppetmaster Dec 16, 2008 03:31 AM
Pretty wierd huh?
S
Interesting. Yeah, I plugged in 225/50/17 because I assumed that's what they all were. Didn't know SEs and GLEs were different. Well, the 245/45s will fill up more of that wheel well that's for sure so that's a good thing probably.
maximase86 Dec 16, 2008 07:56 AM
Once little side note, the stance of my car is definitely lower in the front. I also started to scrap on places that I've never had that problem before.
S
Squirrel82 Dec 17, 2008 04:59 PM
Stock:
http://i137.photobucket.com/albums/q...2/DSC01653.jpg
H&R on front,maxspeed out back.
http://i137.photobucket.com/albums/q...15-08_1041.jpg
maximase86 Jan 25, 2009 03:25 PM
I finally got the H&R's in the back. The car looks definately lower now. The front gap is still a little excessive, but I think getting the right tires will fix that:
http://i38.photobucket.com/albums/e1...9/IMG_0712.jpg
http://i38.photobucket.com/albums/e1...9/IMG_0657.jpg
hotstartup Jan 25, 2009 04:44 PM
looks much better than before. How many fingers are you at now. I have H&rs as well debating if i wanna install them. lol
tookrzy4u192 Jan 25, 2009 04:46 PM
still could go lower! but looks much better than before.. i shouldn't say anything about getting low since im still at stock suspension with springs sitting in the garage lol
maximase86 Jan 25, 2009 04:57 PM
barely 2 in the back, about 3 in the front. Again if I changed the tires to the correct size, that'd probably resolve that problem. :)
maximase86 Jan 25, 2009 04:58 PM
I would like to, but this my main family car, and daily driver. Ever since I had my accident with my S/C'er, my back hasn't been the same since. I think any lower will just add to my already bad back problems. The H&R's offer a nice compromise. A moderate lower, but still preserves a nice ride quality.
S
hotstartup Jan 25, 2009 05:13 PM
i am on 235/40/18 ive seen tthat size to be the most popular on this forum for 18s. hows the handling with all 4 h&rS?
wyche89 Jan 25, 2009 09:36 PM
:sprint: i'm also interested to know how composed the car feels going over bumps and uneven surfaces compared to stock
it looks good too
Revs2Hard Jan 25, 2009 10:50 PM
Springs = wheel gap no matter what brand you go with. The only way to kill that gap is to get coils. Your car still looks good and it will even look better when you get a different tire size. I have dropzone springs that are 2.2 in the front and 2.0 in the rear and I still have a little gap with my 235/40/18.
maximase86 Jan 26, 2009 01:44 PM
That I understand, but a 3 finger gap was a bit ridiculous for me. I had H&R's on the S/C'er and it wasn't that bad. However again, tire size is really the attributing factor here.
Originally Posted by wyche89 (Post 6833541)
:sprint: i'm also interested to know how composed the car feels going over bumps and uneven surfaces compared to stock it looks good too
The handling is certainly better than with the stock GLE suspension and the ride is much firmer. However if the road gets really really bad, there are times where it feels like the car is a little more unstable on excessively bumpy roads....probably because it's not as soft as the GLE ride (The GLE felt more like it would 'float' over the bumps) and you feel more. Also there is more tendency for the suspension to bottom out on big bumps/speed bumps if you don't watch your speed. Either way I'm satisfied with the ride outcome.
S
maximumobsesion Jan 26, 2009 09:49 PM
^^^^^ yeah that does seem kinda high. i think when i had them on minethey dropped more than that. not alot but noticeable. but compared to all the other springs these definitly have the best ride.
