Annoying rattling sound at 1800-1900rpm's.
Hey Guys. I have an 02 I35, but since the maxima boards seem to get more views, i figured i post this here since its basically the same vehicle. For some reason, when im driving the car at low speeds, and the rpms are between 1800-1900 rpms, i get this annoying rattle from either under the car or engine bay. I was told that i could be the timing chain, but wouldnt it make noise all the time, and at any rpm? I was also told that i could be a heat shield, but i took it to a muffler shop and had it inspected. No loose heatshield. Everything was tight.
This noise ONLY happens in between the mentioned RPM's. Once i hit 2krpms, it completely goes away. WTF??? |
it is a weird rattle i had that on my 5th gen i never really found out what it was but when i had that rattle i had my o2 sensors changed at the dealership and after they where changed the rattle was gone..
Originally Posted by Double0Max
(Post 6807333)
I read somewhere that mysterious rattles are common on the 3.5's.
its proly pinging, does the rattle happen at 1700-2000rpm when u rrev the engine at park or neutral. if not the it is most likly pinging. what gas u use?
Originally Posted by gotendbz1
(Post 6807359)
It's pinging coming from the cat converter, it's normal and sounds nice, reminds me of an old mack truck...
Originally Posted by kcxd35
(Post 6807407)
If you search you will find many threads on this, i'm positive on that but replacing cat won't help, Your just hearing the noise from there cause it's originating from the back side of the engine where your manifold connects to the y-pipe...I think it has something to do with the variable valve timing... It's normal, just make sure everything is good as far as plugs and oil and use 10w30 not 5w30 as this may help some...
(Post 6807452)
pinging isn't normal, but it is common on the vq engines. Try running higher octane and see if it goes away.
i doubt it coming for the cat. did it just start? or have you always had this ?
Try a different brand of gas and see if that helps, you can also try to run a bottle of chevron thru system. I have the pinging also and it is very annoying. IF anyone has any other possible solution i would liek to know also. Also for OP, if it sound waste when your going up hill or if the car is under more load. It is definitly pinging. |
Everyone i know on this board has pretty much tried everything from new y-pipe, spacers, higher octane, thicker oil, tune-up, seafoam, etc and the only way you are going to get that to stop is if you buy a different car, Don't waste your money trying different methods, just turn the music up and you won't hear nothing....
(Post 6808963)
I had similar at low rpm's. It was the cat heatshield.
Read this http://forums.maxima.org/5th-generat...ld-rattle.html |
i had the same problem like you, when the gas got ex$$$$$ my wife was putting the cheap gas, i dint no until the car started rattling. so i went to chevron and i put 91 octane or better. remember that you all ways have to put the gas that you owner manual tells you to put if not its going to make that sound if that doesn't work next time you do an oil change get an addictive like Lucas. and that will make your sound go away !!!!!!!!!!!!!!!!!!!!! i jk i hope it does.
I had the pinging issue when I was experimenting with 91oct Ethanol Blended fuel earlier this year, but when the the pinging became more prevalent - i went back to 93 only.
TODAY i began noticing the same rattling issue at low rpm's under load, and I've ONLY been using 93. :slant: I'm going to read-up on the Cat-shield thing, and report back what I come-up with. I HATE thinking my VVT is going to ****e. :shiner: I've had the VTC Rattle since I drove the car off the lot. :bawling: Oh - btw...I just rolled 69k. How about you guys??? Also - can anyone explain why this malody only occurs while you are underway/ engine under load?? --this is strange to me?!-- gr |
I have that rattle too. It is very faint, the stereo has to be off to even hear it. Usually hear it going under 40 mph (in 4th gear) and very lightly accelerating. I guess I'll get under the car and look at the heat shield. The sound seems awfully quiet to be pinging and I only run Top Tier 93 octane gas. Of course, I guess some carbon build-up on the top of the pistons can up the compression just enough to cause pinging.
My observations: I've made some maintenance work on the engine, including TB cleaning. After that I usually get somewhat higher idle around 750 RPM and hidden 0507code (idle speed). Driving in this condition, the engine runs surprisingly clean, no pinging at all. After the idle relearning procedure, the pinging immediately came back. I regret I did it :bonk:can't get back to higher RPM, fooling ECU somehow. I prefer pay more due to the lower MPG (if it occurs) than destroy the engine by pinging
Originally Posted by boris
(Post 6811391)
Maybe I am not listening hard enough but it has always been quite faint even when I do hear it. |
I had the pinging and I rolled like that for so long till one day i swapped out my MAF with a new one and it hasnt pinged since.
Cure for VQ35DE pinging between 1700-2000rpm
I confirmed this today from a very experienced mechanic source from a Nissan dealership. The common engine ping heard between 1700-2000rpm under load will be imminent with the earlier 4th and 5th Gen. Maximas and 2002-2004 Altima 3.5 with the Multi-port fuel injection system(MPFI). This older style fuel injection causes some of the pinging under load because the injectors are fired in batches, instead of individually.That means that some extra gas is spurted onto some valves when they are closed, resulting in gas wastage, and when those flooded valves open on the next intake cycle, they let in that unwanted extra gas and there's pre-detonation in those cylinders. In the newer 6th Gen Maximas and 2005-up Altimas 3.5, they have the newer Sequential Fuel Injection(SFI) system, where each injector has it's own individual control circuit and each only injects the gas into the cylinder when the valves open, resulting in a balanced air/fuel ratio and zero pre-detonation. So the ping cure for the earlier Maximas and Altimas is to covert your MPFI systems to SFI.
Originally Posted by gtnumber1
(Post 6920398)
Is this just a matter of buying 04 max fuel injectors and just replacing with the ones that we currently have? Or is it more complex? |
(Post 6807407)
Reducing the pinging below 2000rpm
Originally Posted by deevel79
(Post 6807308)
I have the exact same issue with my 02 vq35. I also use 93 octane gas and changed the plugs to 1 step colder as well as the typical maintenance.
It is annoying and it gets worse when the weather is warm... |
IT IS THE TIMING CHAIN!
ADD OIL! PINGING DOES NOT COME FROM THE CAT! WOW :rolleyes: :repost2: |
yes I had the exact same problem I was using royal Purple and my engine burned it all up!!!! and was really low on oil! I switched over to Castrol GTX and my engine hasnt burned anymore oil since and the rattle went away
Originally Posted by joebangaa
(Post 6946224)
ADD OIL! PINGING DOES NOT COME FROM THE CAT! WOW :rolleyes: :repost2: This happens all the time, not just when the oil is low. If it was that simple, do you think this many people would be having the same problem??? :buttkick: :rolleyes::rolleyes: |
(Post 6946224)
Originally Posted by kgallerie
(Post 6946778)
It's not low oil.......
Originally Posted by SpooledVQ35
(Post 6946782)
4.5 quarts and you say add more?
(Post 6946914)
OP has yet to confirm his/her oil level for us in this thread ;)
Originally Posted by Scottwax
(Post 6946977)
I will confirm that my oil level is at the full line and I have the same problem. 1700-2000 rpm rattle. I tried some octane booster and that seemed to help, or so I thought. Heard the rattle again yesterday. Still sounds like light pinging but I guess it is possible there is a heat shield rattle too since the sound seems to come from the back side of the engine.
And no I don't have heatshields. |
I have the same problem on my 02 max, it happens to be my center CAT.
Here in canada we have a 8 year 130 000KM Nissan warranty, but with my luck I'm at 132 000KM. I'm fighting nissan canada to get the repair done under warranty. Anyone think they will give in and do the repair? |
at the dealership i work at we have seen the passenger side upper engine mount get a little saggy and cause a noise, i dont know if its the same noise but it also happens on a cold start up in cold weather.
i had that sound on my 02 and i absolutely hated it. whenever i heard that sound i either ease off the gas or push the gas more to get past that rpm range. i got that sound only after engine is warmed up. when i first drove the car in the morning it there's no rattling chain sound. only after engine is warmed up will i hear that sound. i don't think it has anything to do with the oil. i had that sound before the oil change and still same annoying sound after oil change. i've also noticed that murano's have them too. there's one in my neighborhood and when he drove by i can hear that rattling chain sound quite noticeably.
This mysterious rattling sound is due to a bad Rear Monifold heat shield my xperience with rattling sound comes from owning 4 maximas 86 94 98 2003se.My 86 94 2003se had this problem but had desappeared every single times heatshield is changed. This problem is not caused by engine problem or lack of oil like most people here assumed because the problem is only present when car already hot or driven uphill. It takes many hours of labor to fix this problem but your local muffler shop can fix it for u. TO ALL MY FELLOW MAXIMA OWNERS. THIS RATTING SOUND IS CAUSED BY REAR MONIFOLD HEAT SHIELD!!!! my experience on this particular issue comes from owning maximas all my life.
So the rear manifold heatshield rattles only at 1900-2200 rpm lol...Also I had a 99 SE-L and this never happend and I have been part of the NYC crew for a while and noone ever had this problem till people started buying 01-03 max's...
My brother had his cattman headers and y pipe installed a couple of weeks ago. The noise is still there. We thought it was the pre-cats,main cat, heat-shields...but with all that removed...the noise is still there...My mechanic says it sounds something related to the timing chain. One nissan tech told me its because I have sludge in the engine and I would have to replace the timing chain..and timing parts..etc...would cost me $2500 for the job..Of course I didn't go that route. Some people recommended me to add a bottle of lucas when I do an oil change. I have yet to solve this rattling sound.
Originally Posted by maxpassion
(Post 6954370)
| All times are GMT -7. The time now is 05:17 PM. |
