Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   hole in the exhause or ......... (https://maxima.org/forums/5th-generation-maxima-2000-2003/586668-hole-exhause.html)
imported_D_Roc 03-31-2009 12:26 PM
lately my car's exhaust makes a deep sound. it sounds great but before it was wicked quiet, so i think there might be a hole in the exhaust, but the car is too low to get underneath and check and i have no money at the time so how long can i run like that, and what is a decent exhaust system i can get for cheap are the ebay ones any good?
ChrisMan287 03-31-2009 01:29 PM
Yeah sounds like you got a leak somewhere under there. When the car is on, cover the muffler tip with a rag to sort of clog it. If you hear air still escaping, then its definitely a leak. You can drive forever like that, but personally I wouldn't.
imported_D_Roc 03-31-2009 01:35 PM
yup there's a leak. its between the muffler and the bit barall thing that is after the cat converter. i have to wait till end of summer to gather up some cash so will i be able to run that long and what can go wrong if i ran like that
thanks
ChrisMan287 03-31-2009 01:55 PM
So you have a leak in the b-pipe? The car will run until then, but your losing performance and probably MPG also. Those are the only things that can go wrong.
Portugue 04-01-2009 11:56 AM
is it leaking at the flange for the muffler and b-pipe? I guess thats common, there should be a hanger at that flange or something.
imported_D_Roc 04-01-2009 08:20 PM
the leak is from one of the welded connectors by the rear axel. its between the b pipe and the muffle and its a big hod thing is rusted tot he core.
I'm on a budget so any one know of a decent catback system i need to replace the whole thing from the headers (the headers are fine so y pipe onwards), so far i looked at the megan catback they look nice and well i heard both good and bad about it, but is there any thing cheaper and good
mannetti21 04-01-2009 10:52 PM
Awhile back my exhaust rusted out at the same flange. It actually broke off the end of the B-pipe. At the time I was strapped for cash also so I bought a Magnaflow rear section and had an exhaust shop weld the rear section directly to the b-pipe. Think I paid $100 for the exhaust and only $60 for the labor. Definitely the way to go if you don't have the cash right away.
vball_max 04-02-2009 04:41 AM
If you can tell which side of the flange connection is leaking, you may only have to replace the b-pipe or the muffler. I would be willing to bet its the muffler side meaning you would just need a new muffler. Mine started leaking there last winter when I hit a pothole, then within a week or 2 the muffler was completely separated.
I replaced mine with OEM because I have a connection at the stealership. If you are strapped for cash, i hear bosal is a decent replacement for the money.
CustomLowz 04-02-2009 05:08 AM
I ended up only having to replace the muffler. The flange was leaking, but on the muffler side, so I lucked out. I also had an OEM replacement put on.
© 2024 MH Sub I, LLC dba Internet Brands
