Turbo Automatic...Won't move in reverse
I recently had a turbo kit installed on my Maxima. Car is not making crazy power, but is in the 270whp and 290wtq range. I have a transmission cooler and Drop Resistor mod and the tranny has been handling the power fine. However, I got to work this morning and went to back into my parking spot and put the car in reverse and it won't move. It will rev up but just sits there. I cannot figure out what is going on with the car. The car did sit in the garage for the last 3 days because of rain.
Has anyone ever had this issue? |
I doubt it's anything boost related
what did you check so far cause I would start by checking your fluid levels |
Check your fluid lever if its ok then its either your torque converter or your tranny. It doesn't move in any great that most likely torque converter.
Check your fluid level, what fluid did you have in there all this time? Usually what keeps the auto strong and alive is not only the cooler and drop resistor but mainly the fluid, it HAS to be synthetic ATF (mobil 1!!!, or amsoil). See if the level is fine first. also let the car warm up for a while, before you try moving it.
Originally Posted by streetzlegend
(Post 7199836)
clutch packs going. Does it move at all if it's cold? Like as soon as you turn the car on put it in reverse and see if it moves. I know the old saturn I have does not move in reverse when fully warmed up unless I rev it high then it sorta moves.
Originally Posted by nismomaxct
(Post 7201095)
I checked the fluid. That was the fist thing I checked and the level is fine. The car was scheduled to get the transmission flushed this week and the shop was going to use Mobil 1. I have put under 100 miles on the car since I got it back. Car warms up for 10-15 minutes before I drive it anywhere.
(Post 7201243)
What fluid did you have in there before? might be possible that it wasnt able to withstand the heat and broke down, causing some slippage/damage. just an idea, or possiblilty.
Oohh man, I hope my tranny don't go anytime soon.
damn chris, sorry to hear about that. Hope everything gets taken care of soon.
Ok, so the car sat at work since saturday. I started it up, put it in reverse and it didn't move. I reved it up a little like I did the other day and it lurched backwards. Put it in reverse now and it moves right away. This is the strangest thing.
haha wOw.. that is the strangest thing i have ever heard! good to hear tho. did u change fluids?!
Yea but dont expect it to be ok now. It did that for a reason and its not just going to disappear, so still try to save up or plan for another auto
tranny is going!!!! same thing happened
(Post 7204611)
From my experience with bad transmissions, if you leave the car sitting for awhile and drive it again it will work but will go bad sooner or later. Expect a full transmission failure soon. It has happened to two cars I have owned.
Originally Posted by max_pusher
(Post 7214882)
| All times are GMT -7. The time now is 12:42 AM. |
