Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   e-manage blue can't rev pass 2200 (https://maxima.org/forums/5th-generation-maxima-2000-2003/599684-e-manage-blue-cant-rev-pass-2200-a.html)
tedo007 Sep 22, 2009 10:35 PM
so i hooked up all the wires and cut the maf wire and hooked up the green wire going from eblue to ecu and white wire going from eblue to maf adapator. i start the car and it wont let me rev pass the 2200 RPM. as soon as i hook those two wire back to factory way it works just fine. help me out guys. i am a newbie to installing this.
vinco Sep 23, 2009 01:45 PM
It's getting no MAFS signal. Recheck your e-manage manual for correct wiring.
Phantom-V Sep 23, 2009 01:55 PM
Its deff not reading a MAF signal. check the wiring once again. You may have wired it wrong. Doesn't hurt to check it over again. I hade a similar problem with my VAFCII but it was my knock sensor wire that didn't need to be wired. good luck !!!
