Well, Original Altenator on i'ts way out!
My wife got semi stranded @ here girlfriend's house a few days ago! Kinda surprised that the original altenator is going out! Measured output with a new cheap battery and it measured 12.5-13.25V with all the bells and whistles blaring. With 102K on the clock and the car is 6 yrs almost 7 yrs old, it seems a bit premature when compared to the D21 Hardbody which lost it's Oem altenator 15 yrs later( but hardly any electronic gadgets on truck).....I'm kinda thinking maybe it could be related the ES solid motor mounts and the increase in vibration may have reduced the altenator life by a few years..That's just an assumption! I've it's already ordered an altenator and it or course is an OEM brand spankin new for only $265 (Hitachi). Sorry guys my major components are always Oem only!!!! Now I'll get a chance to see what all you guys were pissing and moaning about during it's removal and replacement.......:bawling:
Damn this happened to me last week, battery light came on and Nissan tested the alt and said it was bad. And I'm at school all the time with no tools or garage so they had to fix it :sadpace:
Maybe check you battery first to make sure it isn't straining the alternator causing the premature failure
IF you do have to change the alternator... would just having it rebuilt be out of the question? Could save a few bucks, and its still OEM.
102k miles come on man...... it was time
Jup... Mine just went
Yea... Min just went out. 300 bucks later and I'm back for more. Mine probably went because the clown before me had two amps and one battery in the car. Then again it was 9 years old so it was time...
mine went out at about 100K too..... 02 max so that was 7 years.
Originally Posted by Lontar1
(Post 7245383)
agreed, mine went at like 115k |
Originally Posted by bigpopaj369
(Post 7245751)
112K and no problems yet. Now Im paranoid. :eek:
Originally Posted by crazy97
(Post 7245851)
I've got 135 on my alt and replaced oem battery last year. Keeping a check on water level paid off for battery.
Originally Posted by J-Rod
(Post 7245382)
How many of you guys that changed your altenators around 100K are equipped with ES poly urethane motor mounts? I'm down here in Texas maybe that freakin heat took it's toll on that altenator. I still believe 102K is premature compared to my 15yrs service of my D21 HB. Maybe I'm wrong...but anyway it's still producing enough power to drive it just won't be going out state! |
Hmm you guys are having better luck then my alternator. It just went on me at 80k. I also didnt end up having to pay for labor. The guys at pep boys are morons and we're "trying" to save me money when I told them my specific problem. So 3 days later they ended up giving me labor free when I had to go back in 3 times in 3 days explaining what I explained was my problem - alternator. (battery and brake light on)
One of the days I had brought the car back in before replacing the alternator (finally) they said it probably was the battery. So they replaced my battery for free which I had used for 3 months (bought from them) Bunch of morons I swear. |
Originally Posted by CMax03
(Post 7246321)
Maybe I'll do it myself... I'm sure it's the rectifiers(diodes) cluster! But I really believe in Nissan's starters, altenators, fuel pumps, timing chains are more durable than those offered by the aftermarket. I always got more service out those new or rebuilt starters(by Nissan themselves) than some little company that beads/sand blast all the cadium plating off everything on the altenator/starter then within a matter of time it's no later working due to the part corroding cause they're no longer protected from the elements.
Just changed my alt on my 2000 with 163k. Local guy rebuilt it for $95.00. I did it myself, Its not that hard, It took me about 2hrs.
Since the replacement is new I'll rebuilt the weakling and maybe see if I can fit it to my 3rd Gen VG.... I noticed Courtesy does offer an exploded veiw of the altenator so maybe I'll be able to purchase the parts myself and fix it @ my workshop!
171k over here and still working never replaced. red top batt and a decent music system.
I have had couple of incidents of engine suddenly cutting out on me in the last year. Are these symptoms of flakey alternator? Does bad alternator cause engine to die on the road? The restart is fine and so is the voltage output measured afterwards.
Thanks, - Vikas 2000 Base GXE 135K |
my OEM alty died around 30k.. lol
lets see, since it kept me outta work today...have had brake/battery light flashing for a few weeks, driving to work this morning: was running stereo/heat/lights, Lights started to go dim, engine started to skip or bog i guess. came to a red light, i assume my brake lights took to much because it seemed to want to die..pulled over and it died, put a decent jump on it and got it started. quick check at both autozone and advanced auto seemed 95% useless. so i guess im just goin to replace the altenator. im not the original owner, prob was a system in it before me, any suggestions on brand...any oem?
01 102k(deadly mileage apparentally) |
Just get a reman with a good warranty. Should be about $140 or so.
Guess what guys??? My Altenator was fine...The UDP driven altenator measured about 12.2-12.75 Volts @ idle with lights, a/c on full, caution lights flashing....But what I failed to do will raise the rpm to about 1000 rpm to see if the output changed to 13.8-14.2!!! I installed a new $300 altenator and now I have a spare used one!!! Don't waste your money on those Exide gel filled batteries they only seem to last 2 yrs out of a 8yr warranty. I'm now running a Optima red top group 35.....Did not throughly test my charging system...my bad!
changed my altenator....said f-it....took it out and it failed the bench test. put rebuilt in...bout $160(autozone). everything seems to be running fine now. not too hard, but there are a few tricks i now know
When I replaced the low output altenator (I thought), I removed the radiator/radiator fans/fan shroud to create clearance for removal and installation! Didn't want to mix with the a/c compressor and possibly causing any problem with the lines trying to manuever it out the way! It's working great now and will be for a long time!!!! The Gates belt wasn't ever cracked not one bit....It's been in service for 3-4 yrs since the UDP was installed...I replaced it, with a new one, and placed the used one in the trunk for an emergency replacement!
Hahaha, would have helped if you mentioned you had a UDP. Our diagnosis would have been different.
Guess it all worked out - except for the extra money you spent. Hopefully you can recover most of that. |
No idea if my alternator is the original (162,600 miles) but the one in my old Accord made it to 175,000 before it started to whine a bit and I changed it so I wouldn't end up getting stranded. On the other hand, the 626 I used to have had the original alternator replaced at 42,000 miles.
The best thing you can do to ensure long alternator life is to buy the best battery you can afford and replace them the first sign the battery is getting weak. Continuing to drive on a bad battery eats alternators. |
My alternator just went last week. I was a bit upset as well as my car only had 79,000KM (very low). What pissed me off the most that a couple of days later my stupid radiator started leaking. I think it had to do with the owner before me never changed the rad fluid (not sure on this though) and I've only had this car since late july so I haven't had the chance to check everything
Take it to an indepedent auto repair and have them perform a 120 point inspection!
I am not getting any battery dash light coming on but sometimes she studders on start up . I have 12.9 to 13.5 v at the Battery. My car is not clearly showing me that its the alternator?Also only 80000km and a new battery!
*UPDATE
-been about 50mi. on new altenator and belt. car is running spectacular. Prior to replacement i had battery/brake light flashing, SES light on showing P0300 code(have replaced coilpacks/sparkplugs, next step was CS pos sensor), and car sputtered often and seemed to be getting worse. -all symtoms are gone and i think my car is running better than ever.not to say that the ses light wont come back on in a few mi.could have just cleared on restart -can prob provide a picture write-up for bottom replacement if anyone needs it, I found it to be fairly simple and it was my first time doing one.Messing with the AC compressor wasnt bad at all, just proba few little trick that could save u some time. -refab alt. autozone. 150 w/ core pretty happy about this, info from the .org helped alot, thanks all |
Would certainly help us if you would do that! |
This is the first time posting something to the forum. My alternator went out on 10/30 and left me on the side of the highway. Earlier that day got a battery and brake light. Took the alternator in and failed the test, bought one at Autozone for $160 with a lifetime warranty. While I was at it I replaced tie rod ends, belts, oil, and front rotors and pads due to warping. Took me 2 days to finish everything and the car is running phenomenal now. This is the first time I have done this much work to the car. For anyone doing this I would recommend removing the fans and radiator, takes less than 10 minutes and gives you 4+ inches to work with.
^ apparentally its 1/2 dozen to 1, 6 to another.
ill make that write-up today |
Does losing alternator mean you get stranded immediately? I know I had 1983 Prelude which had a bug in the design so that when alternator died, it cut off the gas to the carburetor. Do Maxima designer have done something stupid like that?
Originally Posted by sontakke
(Post 7283849)
(Post 7283849)
Drove 32 miles home on the battery when the crank pulley came apart in my 626. No crank pulley, nowhere for the alternator belt to go. When I got home, my car would still start and when I put a charger on it, the meter showed 11 volts.
If you wash the engine often, getting the alternator wet with water, dressing, and degreaser, then the alternator would go prematurely. Alternators do not have an expiry date. They wear out due to the conditions they are subjected to.
I've never washed my engine and my alternator still went at 95k. Beg to differ. It's a part that you should expect to have a shelf life.
| All times are GMT -7. The time now is 05:30 PM. |
