Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   What's the gear ratio/configuration of the 6-speeds? (https://maxima.org/forums/5th-generation-maxima-2000-2003/602227-whats-gear-ratio-configuration-6-speeds.html)
DerrickW Nov 2, 2009 08:46 PM
For the 2002 3.5 6-speed, what's the gear config? Are they 4 under-drive, 2 over-drive? Or 5 under, 1 over?
While I'm axing newbie questions - about how much scratch should I plan on dropping on a short-throw aftermarket and are they an easy DIY installation?
thx
Gemner Nov 2, 2009 09:09 PM
you can drop zero and do the DIY free sts mod
tooreckless00 Nov 2, 2009 09:10 PM
you literally just beat me to it. STS mod has worked for every 5.5 owner and they will all tell you its the same if not better than an aftermarket shifter
DerrickW Nov 2, 2009 09:23 PM
Linky, please.
mist max2000 Nov 3, 2009 04:59 AM
never tried the free sts so i cant speak on that,.. but i have done the ralco rz short shifter which is a breeze to install..and only cost ~57 bucks from cattman on here...
your also going to want the Energy Suspension 6 speed bushings.. amazing difference...
Derrick2k2SE Nov 3, 2009 06:31 AM
Here's a great site with tech specs on all Nissans. It gives you specs, TSBs, recalls, reviews and all sorts of info going back to 2001.
http://www.nissanhelp.com/Models/
I've got one of the first HP Autoworks short throws that came out about 4 years ago. There are a lot more choices out there now including the "free STS" mod. The install or mod isn't very hard. If you look through the "how to" stickies at the top of the 5th gen forum you'll find the info. It's worth it on these cars.
Rochester Nov 3, 2009 07:09 AM
Search the 5th Gen forum for "STS" in the title.
Here's a good one: http://forums.maxima.org/5th-generat...-free-sts.html
The picture says it all:
http://memimage.cardomain.net/member...2_219_full.jpg
Gizm0 Sep 22, 2010 11:56 AM
I was looking online the other day for a graph showing Engine RPM vs. Car Speed for an 02/03 maxima with the 6 speed manual transmission and couldn’t find it anywhere so I made one myself.
I made some measurements at various speeds, and on different gears on the road and came up with this graph. I know that the first 4 gears are + / - accurate, but I’m not too sure for 5 and 6. Can anyone confirm?
http://i777.photobucket.com/albums/y...ARRATIO_02.jpg
knight_yyz Sep 22, 2010 01:06 PM
http://i400.photobucket.com/albums/p...t_yyz/6spd.jpg
