Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   What's wrong with this engine bay? (https://maxima.org/forums/5th-generation-maxima-2000-2003/602779-whats-wrong-engine-bay.html)
Kevin319 Nov 11, 2009 08:31 PM
http://i384.photobucket.com/albums/o...6kstick012.jpg
That rust doesnt look normal for a Max with 95k miles. Does anyone agree?
DennisMik Nov 11, 2009 08:40 PM
It looks like you drive in some kind of corrosive fumes that is eating the galvanized plating on the non painted parts.
The6spdMax Nov 11, 2009 08:41 PM
Wow, all those tiny bolts are rusted. But consider the age and location of the car then (maybe?). Looks like someone wash the engine bay before... I hope its not as rusted underneath...
Progress Nov 11, 2009 08:42 PM
Aside from the rust on the bolts, other hardware and those rad brackets, that engine bay is immaculate. You have no idea what rust is until you look at 5th gen that has spent all its years in the North East.
Kevin319 Nov 11, 2009 08:53 PM
yeah I am worried about the rusty bolts/pipes/hose/lines. I looked under my 5th gen before ... not a pleasant sight!
FRZ251 Nov 11, 2009 09:22 PM
You guys are just paranoid, all those bolts are just surface rust, Yea sure my radiator supportes look like this too, and the coolant pipes above the exhaust manifold commonly get corroded. This car probably was exposed to salt in the northeast. Pretty clean engine bay IMO. As long as the bottom of the car isnt too bad its fine.
NAKAYAMA IMPORTS Nov 11, 2009 09:33 PM
depends on the year as well!
LoveSick Nov 11, 2009 09:36 PM
To be honest, from my professional standpoint, this engine bay doesn't look all that unusual.
I am NOT saying that these rust are normal, but these rusts are very common in cars driven by the coastline or in areas where salt is used.
These rust pop out and look out of place because the engine bay has been very nicely detailed. On a very dirty engine bay, these rust would fit right into place. But on a clean engine, they look a little unnatural.
Truthfully, just take some rust primer and black paint on these brackets. All that matters is that the body is not rusted. But chance is that the subframe or crossmembers are probably very rusted already, and no amount of spray paint is going to correct those lower structural areas of the car.
Gemner Nov 11, 2009 09:46 PM
What looks wrong with that engine bay is how unbelievably clean it is
mist max2000 Nov 12, 2009 05:16 AM
..or that it is stock
Rochester Nov 12, 2009 05:49 AM
:laugh: Very good, mist_max!
Seriously, there's nothing wrong by that picture. So what if some of the little bolts and brackets are rusted... it's a 10 year old car, for crissakes! In fact, from that POV, your engine bay is amazingly clean. If the little bolts and brackets bother you, replace the bolts and paint the brackets. A wire wheel can make a huge difference before painting things like that.
You know, if this were 30 years ago, a 10 year old car from the Northeast with 95K miles would be ready for the junk heap.
You shouldn't be complaining, you should be pleased. Get your head on straight, Kevin.
bigpopaj369 Nov 12, 2009 05:54 AM
nothing at all with that pic! those parts always rust easy and i would glady trade u :laugh:
Lontar1 Nov 12, 2009 05:59 AM
location, location, location, replace or paint the rusted parts and you will be ok. Look under your car and look at the Rad support just in case....
nzelinsky Nov 12, 2009 11:43 AM
yeah for sure the only thing I see wrong with that pic is a serious lack of mods... that rust is nothing. I'm sure I have just as much if not more. The car looks like its survived some harsh canadian winters or a coastal community.
ButtaMax Nov 12, 2009 04:31 PM
hella detail job on that motor, can you do mine?
Rochester Nov 12, 2009 04:48 PM
That's kind of an unusual thing to say. It almost reads as if you've never opened the hood of your car before.
Kevin319 Nov 12, 2009 05:07 PM
I probably should have mentioned this earlier but this is not my Maxima. I am currently in the market for another one and came upon one with unusual rust (in my opinion) which is raising a yellow flag in my head. Thank you all for the feedback though! Will definitely bring this car to a mechanic to get it thoroughly inspected.
e-subliminal-2 Nov 12, 2009 06:16 PM
There's no turbo. But it's okay, that's a common problem with most of these 5.5's... Only some were lucky enough to have one.:laugh:
