2002 OEM Muffler - EXPOSED!
Here's the internal's of an 02 OEM muffler. Things I noticed:
Enjoy! http://s841.photobucket.com/albums/z...8.jpg&newest=1 http://s841.photobucket.com/albums/z...9.jpg&newest=1 http://s841.photobucket.com/albums/z...1.jpg&newest=1 http://s841.photobucket.com/albums/z...2.jpg&newest=1 http://s841.photobucket.com/albums/z...3.jpg&newest=1 |
Awesome post, was always curious how the inside looked! Thanks!
You can see the "hammer marks" on the muffler. It required a LOT of force to rip back the 2nd of 2 layers in the muffler. The outer layer, is rather thin and is easy to cut through. The inner layer is twice as thick and was in perfect shape.
Doing it over again, I would have repaired the broken pipe (near the flange between the mufferl and mid-pipe) and replaced the stainless tips with a 2.75 stainless tips (got them from JC Whitney). In the end, keep the OEM muffler! ;) |
That is a very cool post, sir. Thanks for taking the time to take pics and show us the internals.
P.S. I do miss the bit of torque the muffler helps with, but I have yet to miss it since I got my WS2 muffler. :D |
Wow. Just... wow.
Always wanted to see inside that black box. Nice post, man. |
For all the n00bs I made the following diagram in Paint. Red line is usual flow, blue is after 3,000rpm when the left exhaust tip "opens" to increase flow.
http://img695.imageshack.us/img695/3...7317309991.jpg |
Great thread! I like the arrows too. I was always curious to know how the stock muffler functioned. As for the stock muffler's quality? If it's as good as the stock one on my wife's '91 Maxima, it should last a long, long time. Her's recently lost it's outer skin so I just cut it off. I figure it should take another 20 years to get through the inner skin seeing that it's twice as thick as the outer skin.;)
Pete, are you happy with the Walker or is the stock muffler better? |
Very cool! I have read about the "valve" in the muffler and now I fully understand how it works. No wonder they cost 250 bucks. Performance seems to be a priority for our cars, even down to the muffler.
Originally Posted by n3985
(Post 7360311)
Nice job! I've also always wondered about the famous 'variable capacity' muffler. I even installed one of my beater '93 Altima about 5 years ago and felt a noticeable difference in low end tq and liked the sound it produced vs the regular Altima muffler.
So you're liking the Walker even better? My Max muffler has developed a rattle that's slowly getting louder and it's internal so I'll probably be replacing it down the road w/a larger diameter catback setup... Jeremy |
In our 5th gens, 3k is where it builds enough pressure to utilize the second tip, which is what n3985 is saying. So both are true, I guess. So the rate of the spring is designed to be strong enough to hold before <3k and open when at >3k
I would think that pressure and RPM would be related.
Overall, I am happy with the Walker.
* As quiet as stock * Fitment is an issue, tends to rub on the rear axle. Will fix that with some kind of shim. * Overall quality is excellent. Has one less restrictive kink in it than stock. Worth at least 0.025 HP :D * Looks great with JC Whitney Stainless tips on it (see first picture above).
Originally Posted by kbohip
(Post 7360320)
Originally Posted by spock
(Post 7360375)
owesome pics pretty strong muffler, about the only thing that doesnt rust as bad under the car.
Originally Posted by jasonmax
(Post 7360366)
I dont think it rpm related that valve more of a pressure related
***Happy New Year*** |
If I had to do it again, I would have gotten the OEM muffler ($270+) and a Cattman b-pipe or Walker b-pipe. Not looking for additional HP, just reducing the noise of a broken mid-pipe for the past 2 months. Cattman had no mid-pipes fabricated so I didn't want to wait another 2 months.
But overall cost was cheap (~ $275 for mid-pipe and muffler)
(Post 7360320)
Interesting i had always assumed that it was electronic like the one in my 3000GT VR-4. Obviously there is a lot less to fail with a mechanical design, but some performance loss compared to an electronic valve.
Originally Posted by nismology
(Post 7360432)
Only indirectly. RPM + load = resulting pressure at the muffler. Regardless of the RPM the throttle angle will determine how much airflow through the engine there is. 5000 RPM @ 25% throttle, for instance, won't get it done.
I did the same thing on my old 4th gen muffler. It's hard to resist the opportunity to see how things work.http://memimage.cardomain.com/member...24_14_full.jpg
really sick post man! ive been curious for years what the inside of one of these beasts looked like.
This also explains why the damn thing weighed 9000 pounds when I took it off the car. :laugh:
Nice post, cool to actually see the inside
I always wonder how it looked inside.. thanks!
Is there a difference between the 5th gen and the 5.5 gen oem muffler?
Originally Posted by Kevin319
(Post 7361418)
IIRC all 5th gens got the dual stage mufflers(different designs between the 5th and 5.5's though)
(Post 7360311)
Originally Posted by bryan163
(Post 7361078)
blow it out ya tail pipe!
5th gens and I30s had the same muffler right? Or was it a little different, since on the spec sheets it has 5hp more(from the exhaust IIRC).
Originally Posted by a33i30
(Post 7362935)
Can someone rip open an AE!?!?!
I was under the impression that all 5th gens were the same. GXE, GLE, and SE. |
good to know...
Originally Posted by Mr. Blue Sky
(Post 7361517)
Really cool pic man! Learn something new every day.
Originally Posted by Christobal65
(Post 7363589)
It has always been my impression that the extra 5hp the AE got was from the exhaust.
thanks for doing this. really cool to see the "guts" and get a better understanding of how it works.
Originally Posted by petemo95se
(Post 7360753)
I have seen a lot of things, the inside of a muffler...not. Great stuff!
© 2024 MH Sub I, LLC dba Internet Brands
