Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   HELP! 2001 Infiniti I30 Moonroof won't open (https://maxima.org/forums/5th-generation-maxima-2000-2003/610420-help-2001-infiniti-i30-moonroof-wont-open.html)
BassMax95 Mar 21, 2010 02:54 PM
There is no power, so I replaced the obvious, the switch, NO GOOD. I had the wiring to the switch tested to see if there is power to the switch, and there is. Now I was told to check the fuse, that's where I am stuck at now...I've checked every fuse in the 3 boxes under the hood and the 1 in the car on the drivers side. Can someone please help by telling me where to find the fuse that is for the Power Moonroof? I think my last resort would be to change the sunroof motor but first I need to find the fuse. Does anyone have any other ideas what could be the problem? It just stopped working! Any help would be appreciated...........
mandyfig Mar 21, 2010 03:22 PM
Check the FSM, should be the same as the MAx.
Ghost_54 Mar 21, 2010 03:28 PM
Did you disconnect the battery at all since last time you used the sun roof, if so you most likely need to reset the switch, the 02-03 Max's you just push and hold the switch in the off position for about 5 sec. you may hear it click a couple of times as it resets ... then just push the open switch as normal and away it goes. I am not sure on the reset procedure for 00-01, best try a search or two.
BassMax95 Mar 21, 2010 03:48 PM
No I haven't disconnected the battery, thanks.....will try a search for resetting but wouldn't I need power first?
BassMax95 Mar 21, 2010 03:52 PM
I checked my manual and it is very bland on the sunroof option. How about your Maxima FSM?
BassMax95 Mar 21, 2010 04:41 PM
Everything I've read on resetting the sunroof pertains to 2002 and newer cars. Can someone please tell me how to reset the 2000/2001 sunroofs? Thanks
Ghost_54 Mar 21, 2010 04:46 PM
Here's the link for the FSM for the i30
http://www.nicoclub.com/FSM/i30/
edmond Mar 29, 2011 05:48 PM
I'm having the same problem. I've tried the solutions I've been able to find online with no luck yet. Have you been able to fix your problem yet?
