Dress up your Engine Bay -- A Write-up for Nuts & Bolts
Old 10-06-2010, 10:26 AM
  #41
Rochester's Avatar
Originally Posted by RobertColianni
Let me point out that the nuts and bolts found at a hardware store are lower grade metals than those found at an automotive shop. We need grade 8 or higher for automotive work. Hardware stores typically use grade 5 which will not hold up. Please take note when dressing.
Originally Posted by luvlexus101
Well is that for like engine mounts etc or everything? I don't see us needing some really high quality bolts to hold down the headlamps and stuff
You're both right, actually. Most hardware store stuff doesn't look as good, and you have to actively seek out a high grade metal. And headlamp tie-downs certainly don't warrant titanium hardware.
The point of this thread, however, is dressing up the engine bay. And until you get a bunch of titanium parts in your hand, it's hard to explain how cool that is. The sharp edges, the color and the lightweight is, well... cool.
Rochester is offline
Old 10-06-2010, 11:17 AM
  #42
Toolie
knight_yyz's Avatar
I agree that certain bolts need to be higher grade. Structural bolts though. Fender bolts and other bolts that are holding brackets etc could be made of aluminum and would still function normally. Obviously you can't hold your struts to the steering knuckles with aluminum.
But a lot of race cars use titanium because they are as strong as steel. Unalloyed titanium is just as strong as a low grade steel and has a tensile strength in the neighborhood of 63000 psi IIRC. Add a few alloys to that and you can get upwards of 200000 psi. At half the weight. And highly corrosion resistant.
All the places under the hood that Rochester has pointed out can be safely replaced with aluminum or low grade steels. There is no shearing force which would cause any breakage of the screws. They are there just to hold something in place. For looks, titanium is best because it does not corrode even in the harshest environments. Aluminum corrodes easily unless anodized. Stainless will corrode unless it is marine grade, but still more quickly than titanium
knight_yyz is offline
Old 10-06-2010, 11:20 AM
  #43
coldfear13's Avatar
Really neat, good job.
coldfear13 is offline
Old 10-06-2010, 11:30 AM
  #44
Rochester's Avatar
After this winter is over, I'm expecting the titanium bolts to be unchanged.
Time will tell about the stainless steel items. I've got a mix of both.
Old 10-06-2010, 03:16 PM
  #45
RobertColianni's Avatar
You guys are right, it's not required but SAE spec calls for Stainless Steel SAE Grade 304 (8, 10, and 10.9) in motor vehicles. Long story short, the Society of Automotive Engineers wants to keep you safe and eventhough the majority of these bolts and nuts are just for simple supports (fuse boxes, headlamps, fenders, engine covers), it's worth the time to make sure that your equipment is supported and installed correctly.
RobertColianni is offline
Old 10-06-2010, 03:53 PM
  #46
SteveB123's Avatar
Good thing it's not required, as I don't think you'll find ANY 304 SS fasteners on our cars.
304 is used for pots, pans and the fork you're eating dinner with. I'd be interested to see where you've found bolts made out of 304 that are 10.9 grade.
SS is pretty, not strong.
SteveB123 is offline
Old 10-06-2010, 03:55 PM
  #47
SteveB123's Avatar
A tinge of rust in the socket heads. I went nuts on SS fasteners on my suicide machine.
Old 10-06-2010, 04:35 PM
  #48
2003 Nisan Maxima
Teaner's Avatar
Originally Posted by rroderiques77
You should sell your idea to DressUpBolts and other companies who sell "kits". They may be interested in this...
I agree with roderiques. If any of these business's were smart, they would market a package deal for this community.
I must say, this write up is extremely helpful. Great work on taking the time to not only replace these areas on your maxima, but also to contribute in helping other members out. I for one don't have many mods, but this is just a little extra step in making one's ride stand out. Nothing says CLEAN, more then a clean engine bay. I will be sure to tackle this one day. As my bolts are slowly starting to need that extra attention.
Teaner is offline
Old 10-06-2010, 05:23 PM
  #49
Rochester's Avatar
Funny you would say this... I've been trying to get DressUpBolts to join the Org and actively sell their stuff to members. I think they have a good product line, with reasonable prices, and good customer service.
Teaner, thank you for your comments about contributing to the community. Intrinsic rewards are the things that make creative efforts worthwhile. But it's really nice to hear when efforts are appreciated.
Old 10-06-2010, 06:08 PM
  #50
QnzMax's Avatar
Great thread Rochester. Nice job on giving us tips as to how to get our engine bay as clean as yours. I'll probably be doing this once spring time hits.
QnzMax is offline
Old 10-06-2010, 09:43 PM
  #51
8 and up is automotive grade. 304 SAE grade is used on almost all cars. I'm not sure if 10.9 is available in stainless steel, but you sure went out of your way to prove no point, so whenever you want to pick up your phone and call Totally Stainless Inc. in Gettysberg, Pa, you can find automotive grade 10.6 stainless steel readily available. This is the point in which I say game as the ball leaves my hand and walk off the court as the shot is drained, FTW. I've studied the subject all day.
Old 10-10-2010, 09:04 AM
  #52
Rochester's Avatar
In case anyone needs a stronger visual on what can motivate you to replace engine bay nuts & bolts, take a look at this. I swapped out these two bolts this morning, and thought it would make an interesting, side-by-side macro shot.
[edit: my bad. That's a SS bolt, not Ti.)
Old 10-10-2010, 09:31 AM
  #53
SteveB123's Avatar
Cool.
Where are the stock 304 stainless steel fasteners on Maximas?
Old 10-10-2010, 09:32 AM
  #54
SteveB123's Avatar
Awesome!
Old 10-11-2010, 04:56 AM
  #55
vball_max's Avatar
I think I like the one on the left better..... it gives a more rugged, tried and true look to it....
Really.....great work John! If I have a few more minutes in each day, this would definitely be on my list since you made so easy to follow.
Great contribution!
vball_max is offline
Old 10-11-2010, 05:32 AM
  #56
Rochester's Avatar
Great contribution!
Thanks for the props, Kevin!
Yesterday, I updated the spreadsheet in Post #1, and re-created the map photo in Post #2, color coded for M10, M8 and M6 applications, and to include a few bolts around the battery that I had missed.
Old 10-11-2010, 06:06 AM
  #57
NissanMan97's Avatar
how hard was it to get some of those bolts off? the one in the above picture looks pretty rusted?
and do you think these can replace some of the ones under the car that see more direct contact with the elements and are a PITA to get off?
B
NissanMan97 is offline
Old 10-11-2010, 06:47 AM
  #58
Rochester's Avatar
Buy a can of penetrating oil. I've been using KROIL for some time now. Love this stuff. If you're worried about snapping a bolt, apply the penetrating oil at least an hour before you try to loosen it. And if you're really, really worried, apply it a few times the day before you try to loosen it.
So far, I've only snapped one bolt; (one of the four M6 bolts used to hold the NWP Torque Link Connector frame plate. Very unhappy about that one. )
As to bolts under the car... if I had a lift built into my garage, then I'd probably go down that crazy road. And get busy grinding rust off the frame and repainting. However, um, no. That's not going to happen.
Old 10-11-2010, 06:54 AM
  #59
i was curious about the underside simply for the ease of pulling off that plastic stuff to change the fog lights. rusty screws and stuff is a nightmare.
on the lift.
B
Old 10-11-2010, 08:53 AM
  #60
Mr. Brett's Avatar
on the lift.
B
I've messed with my foglights countless times. Never had any issues with seized bolts down there. The splash guards do a pretty good job of keeping everything sealed up. The nuts that hold my fogs in place look brand new, in fact.
Mr. Brett is offline
Old 10-11-2010, 09:17 AM
  #61
Da Roller Coaster!
foodmanry's Avatar
Very nice...at one point in time I would have considered doing this. But, as of now, my money will be focused purely on keeping my max running and passing California smog.
foodmanry is offline
Old 10-11-2010, 10:06 AM
  #62
vball_max's Avatar
you dont drive in winters like we have up here......
Old 10-13-2010, 02:26 PM
  #63
Rochester's Avatar
I mentioned somewhere here that these Password-JDM Fender Washers come with 20mm countersunk, stainless-steel allenheads. However, that's 20mm as measured from the flat top, not the lower edge, which means you only get a few turns on them when used for the engine cover.
So... I found a site through ebay that's selling 25mm countersunk allenheads for $12 shipped (from Hong Kong). And these are Titanium.
Unquestionably, the titanium bolts are nicer, and they're the proper length. But the lip on the Ti-bolt head is thicker than the SS bolts, which means the bolt is not perfectly flat inside the collar.
Meh. Nothing is ever perfect. I should just stop trying.
Obviously, the one on the left here is the stainless steel bolt, and the one on the right is Titanium.
Old 10-22-2010, 05:37 AM
  #64
I'm a little late on this, but I sent an email to www.DressUpBolts.com asking for a price on titanium fasteners. I haven't gotten a response, yet, and I sent the old .xls list instead of the new one you've put together, but what sort of price did you get when going with a full titanium kit? I'm expecting around $250.00.
Old 10-22-2010, 05:57 AM
  #65
Rochester's Avatar
I never priced out a full titanium kit. The only pieces I bought in titanium are the strut nuts, the M6 nuts, and just a few of the bolts. The rest are stainless steel.
Point in fact, there is no "kit" per se for our cars. That spreadsheet was just a personal guideline for me to keep organized. I'm sharing it so others can do the same, if they like.
My recommendation is that you review the suggestions on the spreadsheet as it suits your intentions, with an eye under the hood to make sure each piece is really something you want. After you get all your ducks in a row, contact Chris at DressUpBolts.com, and he'll put together a custom order for exactly the pieces you want.
Lastly, please don't interpret my research as gospel. Confirm things according to your own experience and needs. And be patient with DressUpBolts.com... Sometimes businesses are smaller and more personal than your first impression through the mighty Interweb.
Good luck, Robert.
Old 10-22-2010, 06:48 AM
  #66
MaximusTi's Avatar
Jeez John, Pretty soon your going to make me get under the hood and start swapping bolts....This thread is getting to me....
MaximusTi is offline
Old 10-22-2010, 07:13 AM
  #67
Rochester's Avatar
To your point... it's a (relatively) inexpensive and engaging activity to be occupied with over a few months. I like to always have something going on with the car, even if it's small... like waiting on some bolts, or LED bulbs.
The little things mean almost as much as major mods, because it personalizes the hobby.
Or you could just call Psychological BS on that. Either way.
Old 10-22-2010, 09:02 AM
  #68
Demodded and Forgotten
rroderiques77's Avatar
QFT
rroderiques77 is offline
Old 10-22-2010, 10:17 AM
  #69
trooplewis's Avatar
Nice, my nuts are really corroded...on my way to the hardware store now, thanks for the XLS file.
trooplewis is offline
Old 10-22-2010, 11:23 AM
  #70
Good luck, Robert.
I think you misinterpreted my text. You seem to have taken offense to a few things, but I may just be misinterpreting yours. Either way, I'm in the Philadelphia area. We have a full winter (not like upstate New York, of course). so alot of steel is corroded on my car. I was actually in the process of writing out my own list when I found yours. My biggest concerns, however, will be the engine mounts, strut towers, and crossmember directly under the engine. It seems like the sit has titanium kits for around $250.00 +/-, so with a few additions, I'm hoping that $350.00 will get me on the safe side and halt the possibility of damage.
Old 10-22-2010, 11:54 AM
  #71
Rochester's Avatar
You read into my comments that I'm offended? Seriously?
I've been wondering myself about the engine mount bolts; (specifically the tranny and passenger mounts.) But I wasn't going to look any deeper into that until I buy new mounts next spring. At this point, I don't even know what size they are... M10, I think. Mine are rusted out, nasty hunks of steel. When the time comes, I was thinking of getting the mount hardware powdercoated, and buying some Ti-bolts for the install.
Let us know what you find out.
Old 10-22-2010, 12:22 PM
  #72
We actually have a powdercoating oven at my friends house. We're not sure if it works (it was given to his father by a family friend, because the friend had no use for it), but I was going the exact same route.
Old 10-22-2010, 01:28 PM
  #73
trooplewis's Avatar
Just an FYI, I just got back from Ace hardware and the 4 collar-nuts that hold down the upper radiator brackets and also a support on each headlight are called 'Whiz Nuts'.
They did not have them in SS, but in a bright aluminum finish, 23 cents each.
Oh hey, one other thing. If it was me I would not mess with the fender nuts if you ever plan on trading or selling your Maxima. That is the first place an appraiser looks to see if the fenders have been removed/replaced. The paint on the nuts should be original with no marks from a socket on the corners of the nuts.
Does anyone know what color paint best matches the silvery-color of our engine covers? The silver is chipping off on mine in parts and the base black plastic is showing through.
Old 10-24-2010, 02:33 PM
  #74
Rochester's Avatar
Hood Latch Bracket
I just realized the hood latch bracket uses two M8x20mm bolts that are obvious, once you take notice. And yeah, I'm very aware now of how rusty that area is.
Anyway, here's what I'm talking about. The bolt on the right was cleaned up on the wire-wheel. The bolt on the left... not yet.
Interesting looking bolt, once you scrape it clean. However, it will rust up right away, so I'm going to replace them with Stainless Steel.
Old 10-28-2010, 07:42 PM
  #75
trooplewis's Avatar
I was looking at my engine bay today and realized that I think you missed two bolts.
Two of the front valve cover hold down bolts are pretty visible, but they blend in with the black valve cover.
Might as well do those while you are messing with the rest of the nutz-n-boltz
Old 10-29-2010, 01:38 AM
  #76
Toolie
knight_yyz's Avatar
that's been mentioned but they are special shoulder bolts which help align the cover
Old 10-29-2010, 04:52 AM
  #77
Rochester's Avatar
...and 6 of them are still visible when the engine cover is on.
If someone were to buy me a quality inch-pound torque wrench, I'd be happy to pursue this further.
Old 10-29-2010, 08:14 AM
  #78
That's why I took those 6 to the wire wheel. Try it John. They will come out nice and shiny.
Old 10-29-2010, 08:40 AM
  #79
Rochester's Avatar
I've given consideration to M6 nylon shoulder spacers on 25mm flange-head Ti-bolts. The wire wheel thing works for some stuff, and not for others, depending on whether the bolts are SS or not. If the bolts are not stainless steel underneath the paint or plating (or whatever coating that is), then they rust up immediately.
For example, I went to LOWES and bought some stainless steel M8 hex-head bolts to replace the ones I cleaned up from the hood latch hardware, because not even a week later and they were immediately rusting up again.
And like I said, I would need a quality inch/pound torque wrench, and the bolts with the shoulder issue resolved, and probably a new VC gasket just in case...
...however, at this point in time, I'm kind of burned out on this project and need to take a breather.
Old 10-29-2010, 09:27 AM
  #80
Ahhh. Rust. I forgot that you get that in your neck of the woods.
That's why Jim Morrison always said: "The West is The Best".
Quick Reply: Dress up your Engine Bay -- A Write-up for Nuts & Bolts
