Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   *Need help - Replacing front struts... WHAT ELSE SHOULD i REPLACE WHILE i'M IN THERE? (https://maxima.org/forums/5th-generation-maxima-2000-2003/648779-need-help-replacing-front-struts-what-else-should-i-replace-while-im-there.html)
soundquest Apr 23, 2012 04:37 AM
Am replacing my front struts on my 2002 Max in conjunction with changing my front bearings and hubs. Is it totally necessary to replace the strut mounts and if so why? What exactly fails with the mounts or changes requiring replacement?
But aside from the struts, mounts, and boots and bumpstops, what else should I replace while I am in there? In other words, what else at 135K is worn or soon to be worn necessitating replacement or service?
Thanks.
UGAd13 Apr 23, 2012 06:12 AM
http://forums.maxima.org/5th-generat...-thread-5.html
http://forums.maxima.org/8443497-post177.html
L_U_D_I_AMaxima Apr 23, 2012 06:13 AM
front struts: replace the strut mount, replace the bearing, replace the dust boot... make sure you align the mount with the "outside" word on the strut and you will be good to go...
cjandura Apr 23, 2012 07:33 AM
Follow this thread and ask questions there Dj has the best info on all your needs and he knows his stuff and is well trusted around here
http://forums.maxima.org/5th-generat...on-thread.html
