Anyone have a part # for heat seat relay or fuse?
Firstly where is the relay or fuse located? Neither seat heater work. Car is an 03. I checked courtesy but only found the switch or heating element. Any help? Thanks in advance
Do you have an owners or service manual?
Look under steering wheel by your left knee (as driver) and check your fuse. Relays are in engine bay, fuse is inside. Are you switches lighting up? |
Originally Posted by noahrexion
(Post 8721489)
Look under steering wheel by your left knee (as driver) and check your fuse. Relays are in engine bay, fuse is inside. Are you switches lighting up? The drivers side button bulb went out but the passenger side lights up but doesnt turn on. I might just stop by Nissan tomorrow and check before work. |
There is no relay for the heated seats. The seats use fuse # 9, a 10 amp fuse. It is in the top row, 3rd from the right end.
(Post 8721707)
Well ****! I have the correct fuse but I did not see any #9 down by the knee. It's an 03 altima 3.5 so I figured the fuse locations would be pretty much the same.
Originally Posted by VQMagic
(Post 8723296)
The relay is is next to the top left corner of the in dash fuse panel. In this fuse panel, check fuse # 12. It is used to energize the relay. I hope Nissan molded the numbers in the plastic like in the Maxima because I am not sure of the orientation of the fuse panel. My best guess is that fuse 12 is the one in the lower right corner. Fuse 29 is a 15 amp and is in the under hood fuse box. Starting at the rear fender side corner, it is the 3rd position. Position 2 is empty. |
(Post 8723350)
It turns out that the Altima is vastly different from the Maxima. The Altima uses a relay for the heated seats and fuse # 29.
The relay is is next to the top left corner of the in dash fuse panel. In this fuse panel, check fuse # 12. It is used to energize the relay. I hope Nissan molded the numbers in the plastic like in the Maxima because I am not sure of the orientation of the fuse panel. My best guess is that fuse 12 is the one in the lower right corner. Fuse 29 is a 15 amp and is in the under hood fuse box. Starting at the rear fender side corner, it is the 3rd position. Position 2 is empty. An No Nissan didn't mold the label into the plastic.. There is a black guideline but it doesn't mention anything about the seats or heaters. I'm going to copy n paste your response and email it to myself. Thanks again bro. Will report back tomorrow. |
Here are drawings of the two fuse blocks.
This is the one in the dash http://forums.maxima.org/picture.php...ictureid=36105 This is a close up drawing of the dash fuse block http://forums.maxima.org/picture.php...ictureid=36104 This is the under hood fuse block http://forums.maxima.org/picture.php...ictureid=36103 |
Got it. Was missing a 15a fuse on drivers side fuse panel under the hood. Now to fix the led bulbs the switches have inside them.
(Post 8725455)
Bump! I replaced the lights in each switch only to find out that there are two bulbs in each one. I need the bulb that makes them illuminate when you turn the headlights on. Any help? It has like a little condom on it. lol
(Post 8725589)
Well someone deleted their comment. Gave me the wrong P/N for the light bulb that illuminates when the headlights are turned on.. Either way I fried my driver side switch so gotta get a new one now. The little copper sliding thing bent to hell. No connection moving it with my finger.
© 2024 MH Sub I, LLC dba Internet Brands
