P0455 just what I need
My car starts then stalls after a few sec I wonder how much this gonna cost. Im going to get a gas cap doubt thats the problem but gotta start somewhere.
Another cause of the P0455 is the EVAP Canister Vent Control Valve. This is attached to the EVAP canister and has a plunger that will get stuck and won't move. Many people have been able to free the plunger with WD40 type stuff and a screwdriver. The have been a bunch of threads on this and also youtube videos.
(Post 8861891)
Definitely start with gas cap like you said. EVAP shouldn't make your car stall and be inoperable. Check engine light is the only thing that should happen, but the car should still run.
My dad's old Camry has been running with a broken EVAP canister and check engine light ever since 200k miles, it's now at 300k with no issues. My little bro drives the heck out of that car with no problems. That said, you must have another problem if your car is stalling. Is there any other codes perhaps? Maybe something fuel related. |
(Post 8861930)
After checking my gas cap and clearing code I started my car this morning it ran fine but then I drove around my complex it stalled, cut off, the steering wheel locked up no codes are showing up.
I was able to restart my car and drive it back to my apartment.
My mechanic said it sounds like a cam sensor when I talked to him. He cant check my car out til wed, would that make sense?
Originally Posted by cmd26
(Post 8863753)
Might be my fuel pump I doubt it's the relay since it was failing over a period of time. Is this a hard job to do, search hasn't helped me at all.
Fuel pump is fine they changed the fuel delivery unit that didnt work either. My fuel guage isnt working right I keep running out of gas it gets to half full then stops. The shop said it could be the pcm or the cluster. I put $25 on friday around 930 at night I was out of gas by sunday afternnon I didnt even drive it that much. My car seems to be losing gas some how. I know when its about to cut off i get a heavy smell of gas while Im driving. Confused byu this no codes so nothimg to go on ant help would be appreciated.
A camshaft sensor should throw either a P0340 or P0345 code, depending a which bank.
The stalling could be a bad MAF, they don't always throw a code. There was a post by another org member that was having car dying issues and he discovered that Midas Muffler had some sort of test equipment for the MAF that most places don't have. He did have a bad MAF. As another point, a bad MAF can kill your gas mileage. There is a combined unit in the gas tank that has a sending unit for the gas gauge, a fuel filter and the fuel pump in it. You take the unit out of the tank (fairly easy to do) and then replace the section that is bad. If you replace the whole thing, it's kind of expensive. |
(Post 8874013)
1 Attachment(s)
Dude, wish I could get back to this sooner.
I'm pretty sure this is not fuel related and it's not camshaft sensor or any of those things... You mentioned a key code in an earlier post... P0420 = Catalyst Efficiency below Threshold (Bank 1 IIRC/please correct me if I'm wrong, it's the rear cat closest to the firewall) Attachment 27604 You either have a bad cat or it could just be the o2 sensor/circuit malfunctioning. This explains the fuel smell and stalling, all that other stuff. Likely why you had the EVAP code as well, all related to this I assume. You either need to reset the ECU/you might have a bad cat/it might just be an o2 circuit malfunction. This has been covered before on the forums, do a search. But you need to have the cats and o2's inspected as it can be a serious problem if the cat is bad. |
Im going to try changing out the fuel pump already have a new sending unit cant hurt unless I mess something up. This question is for those who have changed there fule pumps,which brand should I get?
I replaced the fuel pump problem solved.
(Post 8881029)
thanks |
Bought a new fuel pump from rock auto $25 fuel filter also yes I cleared the p0455 code the day it started having problems it never came back so I knew that it was something else.
New fuel pump but the problem has resurfaced. I still can't tell how much gas is in my car because the gas gauge is all over the place. Whatever this problem is the fuel pump wasn't my problem. Does anyone know what controls the gas gauge? I have a new sending unit also. Would a faulty cluster create my gas gauge issue?
Possibly, yes.
(Post 8873905)
^^^^^^^^^ If you recall your thread started about stallin, was your gas gauge working before this post ? Because its easy to f up the sending unit if not careful , idk how yours was changed if its solder to the rest of the unit, maybe they changed your fuel pump and filter and screwed up the lil arm floater and put every thing back wrong with the same o ring creating gas smells ..... Just my theory :) |
Originally Posted by nestorlugo
(Post 8955874)
(Post 8955919)
All my problems started at the same time. The sending unit was changed by the shop the problem didn't go away so I changed the fuel pump car drove fine for a few month's even on low fuel now the problem is back. After both were changed the gauge still wasn't working right showing me different fuel levels every time I started my car. But it never stalled again until Saturday.
I know it was changed I was there when the new unit was installed it had no effect until I changed the fuel pump. I took everything apart per the fuel filter write up, the sending unit was working like it should but the gauge wasn't.
(Post 8955936)
Fuel sending unit was under warranty so I'm going get it change again hopefully this time it works.
This is some frustrating bs, 2 new sending units same result im going to go insane until I fix this issue. My next step is to check the harness but after that Im clueless on what to do next. Ive never changed the fuel filter Im now wondering if its so dirty it might be the culprit but i doubtful about that. I trying to buy a house so a new car right isnt even an option plus I cant afford an audi anyway lol.
Cluster maybe? Does anybody know what the numbers under mileage on the cluster mean, mines is pretty high like 1700 and keeps rising, is this normal?http://s276.photobucket.com/albums/kk6/cmd265/Mobile%20Uploads/?action=view¤t=20140622_211421_zpsfde5feba.j pg
(Post 8963536)
Cluster maybe? Does anybody know what the numbers under mileage on the cluster mean, mines is pretty high like 1700 and keeps rising, is this normal?http://s276.photobucket.com/albums/k...psfde5feba.jpg
but i think your problem has to be something else, your focused on your fuel gauge when i dont think at this point you should be. go rent a fuel pressure gauge from the zone or oreilly or something and get fuel pressure readings unplug your Mass air flow sensor and see if it says running, it wont rev past 2500 rpm, but if it doesnt die, there is your problem |
© 2024 MH Sub I, LLC dba Internet Brands
