03 Maxima stalls after a few minutes and won't run
Old Jul 20, 2014 | 07:19 AM
03_maxima's Avatar
The other day I was driving home and my 03 Maxima started bogging down and finally stalled. I had it towed home. After it cools down it will start, run beautiful, and only run for a few minutes and then stalls. I have no trouble codes. I pulled off the fuel line under the back seat and it sprays fuel when I turn the key......any thoughts were I look or test next? HELP!!!!!!
Old Jul 20, 2014 | 07:55 AM
Fatboy98maxima's Avatar
Mass air flow, coils, crankshaft & camshaft
Old Jul 20, 2014 | 08:46 AM
03_maxima's Avatar
Already checked coils and camshaft sensors. I was thinking possibly a clogged cat? Mass air flow is another thought i will clean and see if there is a difference.
Old Jul 23, 2014 | 06:15 PM
03_maxima's Avatar
Just an update.....I finally pressure tested the fuel line and guess what.....NO PRESSURE. just because I pulled the fuel line and fuel sprayed out when I cranked the motor does not mean that I have the required 43 PSI to run the car. I replaced the fuel pump and as good as new! thanks
LilVito
Oct 25, 2019 08:12 AM
kjlouis
Nov 24, 2018 06:09 AM
acw
Aug 13, 2015 12:50 AM
Bruceharrison
Aug 9, 2015 07:56 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
