2000 Maxima GLE won't crank
Hello guys,
2000 Max GLE 180K miles A/T Yesterday I had issue with the car turning on so I did noticed the battery was dead because I'd hear the clicking sound and it just didn't go. Had the battery recharged - it turned on but after shutting it off. Won't go. Recharged battery overnight - multimeter reads 12.6V on the battery - thats a good charge. Put it into the car and I don't even hear clicking (crank) starter isn't firing. I do hear a tick on the pass side and thats about it. No crank. 1) Checked all fuses - all seem to be ok 2) Getting power inside - all accessories work 3) Checked for codes - no codes at all Any suggestions before I go and replace the Starter (if its the problem)? Thanks my friends :) |
Starter issue... with the amount of miles you have, it is normal. Hit the starter with a tube to see if it engages again. If not you will need to replace it, not difficult to do.
Originally Posted by Lontar1
(Post 8972286)
Thank you very much for the quick reply :) |
Tried smacking it around a few times - no change - i guess i'll have to replace the damn starter - wth caused it to break ? worked perfectly fine yesterday .. smh
Originally Posted by HotRod11686
(Post 8972291)
FYI: If you have alternate transportation just remove it (takes maybe 30 mins) and have it bench tested at your local parts store (free service). |
Maxiiboy,
The link is gone, do you mind sending it again? |
| All times are GMT -7. The time now is 05:27 AM. |
