Hello I'm new here to Nissan forums 2003 Nissan maxima windows will not work ??
Need help bad Can anybody tell digram for the driver side window wires are loose not one window will work because of this :confused:
Google search .....window master switch/maxima.org something should pop up :)
Or try the newbie thread but perhaps you should rephrase your question to include more details about your ride. |
Check the simple things first. Fuses, relays, etc.
here is a link to the service manual section for power windows. Start reading on page 251.
http://boredmder.com/FSMs/Nissan/Maxima/2003/EL.pdf |
Window want work
1 Attachment(s)
I have Check theFuses, relays, all are good my problem is all the wires that control the driver side window switch the wires are all disconnected and I need to know what order they go in the image blow should give a clue thanks
2003 Nissan maxima se |
Try this, it helped me fix my window when I had issues
2003 Nissan maxima windows not working
1 Attachment(s)
Thanks my problem is my wires are disconnected from where the window switch is connected would any one able to post a picture of their 2003 maxima SE?? so I could match my wires up right I have one window that want Down but want go back up lock also not working from driver side or passenger side
Below are my wires color's |
The master window switch in the driver's door has to work before the other 3 doors will work because some of the wires go to the other doors.
Code:
Sort the wires to make sure that you have a match to this chart. |
1 Attachment(s)
Thanks my problem is my wires are disconnected from where the window switch is connected would any one able to post a picture of their 2003 maxima SE?? so I could match my wires up right I have one window that want Down but want go back up lock also not working from driver side or passenger side Below are my wires color's Their are 1.big green 2.green/white big 3.green small 4.green/white small 5.green/yellow 6.blue big 7.blue small 8.blue/white 9.blue/orange 10. Black/orange 11.black/white 12.red 13.yellow 14.red/ green 15.black 16.red/ white I need to know what order they go in I thank the big black & big red/white goes to lock& unlock. |
DennisMik you have all my wires would someone know what order they go in
# color ---- ----- 1 yellow 2 white/black 3 red 4 orange/black stripe 5 green 6 orange/blue stripe 7 green/white stripe 8 thin blue (to window motor) 9 green/white stripe 10 white/blue stripe 11 green (to window motor) 12 13 green/yellow stripe 14 thick blue 15 green/red stripe 16 17 black 18 19 white/red stripe This is the view of the wires in the connector when it is plugged into the window switch. ╔═══╦═══╦═══╦═══╦═══════╦═══╦═══╦═══╗ ║ 1 ║ 2 ║ 3 ║ 4 ║ lock ║ 5 ║ 6 ║ 7 ║ ╔═╗ ╠═══╬═══╬═══╬═══╬═══╦═══╬═══╬═══╬═══╣ ╔═══╦╩═╩╦═══╗ ║ 8 ║ 9 ║ 10║ 11║ 12║ 13║ 14║ 15║ 16║ ║ 17║ 18║ 19║ ╚═══╩═══╩═══╩═══╩═══╩═══╩═══╩═══╩═══╝ ╚═══╩═══╩═══╝ connector D10 connector D13 |
This are the wires order for a 2003 nissan Maxima window switch
1 Attachment(s)
2003 nissan maxima window wires for driver side power window switch
We're are the one's for the window's. 1.yellow 2.black/white 3.red 4.black/orange 5.big green with pink dot 6.orange/blue 7.big white/green 8.big blue 9.small blue 10.small green white 11.blue/white 12.small green 13 14.green/yellow 15.small blue 16.red/green 17. lock are 18.black 19. 20.red/white ╔═══╦═══╦═══╦═══╦═══════╦═══╦═══╦═══╗ ║ 1 ║ 2 ║ 3 ║ 4 ║ lock ║ 5 ║ 6 ║ 7 ║ ╔═╗ ╠═══╬═══╬═══╬═══╬═══╦═══╬═══╬═══╬═══╣ ╔═══╦╩═╩╦═══╗ ║ 8 ║ 9 ║ 10║ 11║ 12║ 13║ 14║ 15║ 16║ connector D10 ║ 17║ 18║ 19║ ╚═══╩═══╩═══╩═══╩═══╩═══╩═══╩═══╩═══╝ ╚═══╩═══╩═══╝ connector D13 |
The row of wires that are facing the camera (pin numbers 1 through 7) are in the correct order.
I can't really tell about the back row but I think that the blue wire in pin # 8 which is behind the yellow wire at the top of your photo may be the wrong blue wire. Read my earlier post (# 8). I gave you the order. But here is another diagram that is matched up to your photograph Code:
2003 maxima window not working
1 Attachment(s)
This is the back roll picture I put my wires back together by lock at an 2003 maxima my friend just got but my window are still not working now it may be my driver side window switch???. On the other hand my lock are working now
Originally Posted by Maxima se 5184
(Post 8979415)
Thin blue and thick blue wires look to be in wrong spots. I cannot see the bottom row. Double check your wiring! |
It looks to me like you have the 2 blue wires switched.
It is possible that the switch is bad. 1 - you may have blown it up with the wires reversed. 2 - The switch may have been bad, which is why all the wires were pulled out. |
| All times are GMT -7. The time now is 03:22 AM. |
