CEL Code P0420 HELP
Hey everyone. So about 3500 miles ago I had a check engine light appear on my 01 Maxima 20th AE. I had it cleared and now being driven 3500 miles, it came back. I've noticed that when I drive, I burn a lot of fuel. And I mean a lot. I went to Autozone and got the code checked and it gave me P0420. I need help knowing what it is, how to get rid of it, and how to get my gas mpg back up again. The paper I got from Autozone said:
"-Catalyst system efficiency below threshold-bank 1" "Large vacuum leak" "Ignition system fault" "bank 1 catalytic converter" Please and thank you. Any help will be greatly appreciated |
search this forum tab in the right corner, type in code and do some research
Possible cause: clogged precat
OEM Genuine Nissan Cat cost $599.00 parts only, OEM aftermarket Cat (bosal, walker):cost $299.00 The best and the cheapest way is to gut both precat : precat near the radiator precat near the firewall. Install 02 nonfouler to the two secondary 02 sensor, for SES light not to turn on. :02 sensor with white wire :02 sensor with red wire. |
Originally Posted by colt149
(Post 8986145)
Possible cause: clogged precat OEM Genuine Nissan Cat cost $599.00 parts only, OEM aftermarket Cat (bosal, walker):cost $299.00 The best and the cheapest way is to gut both precat : precat near the radiator precat near the firewall. Install 02 nonfouler to the two secondary 02 sensor, for SES light not to turn on. :02 sensor with white wire :02 sensor with red wire.
colt has highlighted the choices. Spend $300 on an aftermarket and have it replaced or gut what you have, make more power and safeguard against that rear one breaking up and going bad on you. The choice is yours to make.
Originally Posted by ateick
(Post 8986334)
^ take it off and remove the insides
Obx v2
© 2024 MH Sub I, LLC dba Internet Brands
