Oil Pan using RTV vs Gasket?
So my oil pan needs to be replaced. Rusted, busted and leaking oil. Plenty of how-to threads in searches.
But my question is, whats better? Using a gasket, RTV silicone, or both? Seems like the FSM says to use just RTV. But I read others saying the gasket is better at staving off leaks. Any opinions? Thanks in advance. |
use the OEM gasket... no headaches
Originally Posted by lontar1
(Post 9001927)
use the oem gasket... No headaches
My Oem gasket was RTV. Lol
Different people will tell you different things. I have seen people use both with success. You decide what is better. I would put RTV on it.
Went the old school way
FWIW,
I just recently did this job myself and I decided to go with the paper/cork (or whatever the heck it's made of) vs the RTV. RTV is great for the robot assemblers on the line but a bit of a pain for the DIY'er laying on his back on the garage floor. I used RTV when I did the water pump / timing chain tensioner because there was no other option. Came out fine. BUT - when I saw there was an aftermarket 1 piece gasket for the oil pan I decided to give it a try. Neater, simpler and no stupid tube of left over goo sitting in my toolbox. Cleaned everything up, torqued it down to spec (+2 more ft/lb taking into account gasket squish), RE-torqued 2 hours later (make sure you follow the pattern in the FSM) and so far ... perfect. I recommend replacing the washer behind the oil cooler while you are there. They leak don'tcha know. Easy job really. |
You still need to use RTV on a gasket...so, yeah. You might as well use RTV only and save money.
And since when does the lower pan have a gasket? I've never seen one. |
(Post 9002216)
(Post 9002216)
I used the included gasket then rtv on the corners for front & rear
Originally Posted by Blassmasta
(Post 9002497)
Wrong.
Are you for real? Every sealing surface on a motor has a gasket of some kind. RTV or otherwise. +1 and +1 |
(Post 9002497)
Wrong.
Are you for real? Every sealing surface on a motor has a gasket of some kind. RTV or otherwise. |
© 2024 MH Sub I, LLC dba Internet Brands
