Happy new year! My alternator! :D
Local temperature drops big, I parked my Maxi outside for 1 hour and then....
Brake light and battery light are all on, of course, dim lights too.
Voltage measured, with car running, 11.89v at battery poles. I also measured directly from alternator pole against chassis, 11.81v, I think that is from battery, eh?
So, alternator is dead?only 3 months ago, my previous one was burnt, and this one is from a 02 Maxima at a car graveyard, looks like a genuine part, but......
It seems Mr. Alternie didn't make it to 2015......
Probably not. Probably the voltage regulator I haven't seen the alternator but if it's like
a Bosch you can just screw a new one on pretty easy.
https://www.youtube.com/watch?v=aVvPzwtxdrM
think the general consensus is go for an OEM alternator, at work we install reman Napa alternators and probably 80% of the ones weve put in Altima or Maxima fail again within 6 months
Hey, found this
http://market.autopartsfair.com/niss...lternator.html
what do you say? used OEMs vs. brand new aftermarket, who wins?
Hey, found this
I think my alternator is on it's way out too. I have an engine whine, and there are other signs. Do I really have to drop $260 for an OEM alternator if I want it to last? Has anyone had any success with a reman alternator from bbb?
Try a NAPA Premium one and if it f8ks up, fight with your mechanic
BTW, they also sell the OEM alternator made by Hitachi. It's REMANufactured, and more expensive than the TYC/Hitachi one, I think it's about $135. Go figure .....
Screw bringing it to a mechanic. I'll be replacing the alternator myself, it's not too difficult of a job.
No way will I be paying $500 bucks at a dealership to have it done. The reman alternator from BBB (I know, re-manufactured) is sold at Car Quest, and it's only $90 if you have the core. That's the one I've been looking into.
I searched for that Hitachi alternator you speak of on Rock Auto and found it, but it's listed for $110. Where'd you find it for $77?
Sorry if I'm thread jacking here, but I just tested the voltage on my own alternator. Engine was warm.
Running, voltage read 14.29 V across the battery posts.
Under load (lots of electrical stuff on, i.e. heated seats, hazards, full heat blowing, lights on, etc) voltage read 12.02 V across the battery posts.
Therefore. . my alternator isn't dead, but it's on it's way out?
updates: work finished just before 2015, took me 3 hrs.
tricks to share: I learnt from a lot others that it's a pain to get alternator out d/t its accessibility. Most of them took radiator off for extra space, disconnected drain hose etc. I just happen to find out that if you push a/c compressor far enough to driver's side, it will give you just enough space to get alternator out and back in.
This new one has a 2 years warranty on it, hope it lasts a little longer....
Happy new year folks!
I've done some searching through the forum, and I haven't really been able to find a troubleshooting situation where someone had engine whine (that wasn't power steering related).
When I went in to my Nissan dealership the other day for a hard to find part, I mentioned the symptoms to one of the guys there, and he said if it wasn't the alternator it could be the belt tensioner. I'm not really sure how to check for that though.
I did see that people suggested taking the accessory belt off and running the engine, so that the alternator, a/c condenser, power steering pump, and whatever else isn't getting any power. If the whine persists, it isn't one of those things. If it doesn't persist, it is one of those things (probably the alternator).
https://www.youtube.com/watch?v=UF3W...id=G4PS7WHlgi0
for your last paragraph, just remind you that power steering pump isn't sharing the same serpentine belt, but alternator, a/c compressor are on a same belt. and a brave guess, I'm pretty much sure that the whine will be gone when there's no driving belt. tensioner pulley? I don't think so coz they always make squeaky noise instead of whining.
May luck be with you and happy a new year.
try this pal, not guarantee it will work, but this is always the first step we do.
Right, power steering pump is on a different belt than the alternator and a/c compressor. My bad, I forgot about that. I'm thinking of taking the belt to the alternator and a/c compressor off and letting the car run to see if the whine persists.
The video was informative, but unfortunately I'm not really having any squeaky belts. It's a whine that's constant and correlates to the engine RPM. Perhaps I'll take a video and post that.
This is how my original OEM alternator and some of its replacements sounded like
https://www.youtube.com/watch?v=5VBUIzerLEY
https://www.youtube.com/watch?v=wG_4aw8TlxU
And there was one that didn't make any noise but would only intermittently work
JoshG
09-16-2015 08:56 PM
