Clicking from new rear brakes. Stops when brake pedal is engaged.
Hey all...my search has come up empty, so I am wondering if you can help me out. I just replaced my rear rotors, pads, and calipers. I now have a clicking noise equal to the rotation of the tire and the speed...so something is rubbing at a point in rotation. However...it stops when I apply the brake. :confused: Seems everyone else gets the clicking when they apply the brake...but mine goes away when I apply the brake.
As long as my foot is on the brake pedal...the clicking noise goes away. As soon as I let off the brake...its back. I checked for a loose connection or bracket somewhere, but couldn't find one. Any idea what would cause this or what to look for and check? Or is this something that will just go away once everything is worn in? Thanks SO much for the help with this. I just hope I am not doing any damage to the new rear brake gear. |
Iv got the same issue with my new brake hardware in the front however....clicking rolling at low speeds is audible with windows down..and it goes away depressing the brake. its been about 60 miles since new rotors/caliper/pad.
I'm assuming that you installed everything. I would simply remove everything, inspect the parts then re-install.
Originally Posted by Maxgig
(Post 9017743)
Originally Posted by maxiiiboy
(Post 9017764)
When you do that, make sure that the springs that are supposed pull the leading edge of the pad away from the rotor are installed properly - at the leading edge of the pad, not at the trailing edge of the pad.
Thanks again! :thumbsup: |
© 2024 MH Sub I, LLC dba Internet Brands
