It's alive
Greetings, My 2001 Nissan Maxima with the crank no start issue is on the road again.
We replaced the Cam sensor, the crank shaft sensor, then the second hidden crank shaft sensor, then re spliced a wire that was broken....... near the hidden crank shaft sensor....the likely source of the problem. Here is the question. The car seems to be running a little rough and the Air conditioning is blowing hot air. Do I have to retrain the computer on this car? I took the car for 20 minute drive that included some highway driving, I think it is less rough in nature but that might be wishful thinking. The AC I would like fixed. Is this part of the relearn curve? Never mind about the AC seems the fuse was pulled to try on the fuel pump then not replaced. |
| All times are GMT -7. The time now is 07:33 PM. |
