Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   Rpm's stuck issue (https://maxima.org/forums/5th-generation-maxima-2000-2003/692649-rpms-stuck-issue.html)
1slwmaxima Mar 28, 2016 01:44 PM
Rpm's stuck issue
Question guys my 03 Maxima been acting weird while running I'm going down the street around 40 n than my rpm's get stuck at 2000rmps step on the gas alittle and they dont move n than drop to 1000 back up 1 1/2 rpm any suggestions?
NmexMAX Mar 28, 2016 02:14 PM
Sounds like a MAF issue.
Mattx Mar 28, 2016 04:47 PM
Do the rpms go over 2300 in any gear?
1slwmaxima Mar 28, 2016 09:43 PM
Yes they do car runs normal through out the gears just when I driving around whatever speed and let go of the gas it drops to 2k rms and get stuck their I try to push the gas little bit and doesn't go unless I floor it.I recently cleaned the maf sensor 2 days ago.
Mattx Mar 29, 2016 02:00 PM
I agree with nmexmax in that case your maf is probably dying. In my experience once the maf acts up cleaning won't help. If your maf is dying it's going to die. Our cars are extremely sensitive when it comes to mafs. Try swapping one out and see if that helps.
1slwmaxima Apr 2, 2016 04:56 AM
I did the idle relearn it works once the car is Running but once I turn of the car off and turn on again it goes back to the same rpm problem
