Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   Doesn't hold idle at first (https://maxima.org/forums/5th-generation-maxima-2000-2003/694328-doesnt-hold-idle-first.html)
Cephyr13 Jul 13, 2016 09:46 AM
UPDATE: It idled high after driving it today. Around 1800 to 2000 rpms at times. Also, the cruise control slows down, so there's probably a vacuum leak causing this.
2001 Maxima, 161k, manual
It won't hold idle when you first turn it on when it's cold. After giving it gas for a moment, it barely holds idle around 400-500 rpms. When it's warmed up, it idles at about 750 rpms. I think there could be a vacuum leak since the cruise control loses speed periodically.
It has codes that say the o2 sensors are all shot, as well as the knock sensor. The throttle body (which has the IAC valve on it, if I'm understanding it correctly) looks new, but I bought another just in case (hasn't arrived yet).
Any ideas what might be causing this?
Thanks.
- Brian
BigLou55 Jul 13, 2016 06:53 PM
Your codes are telling you what the issue is. You need to start there by searching for theads on this forum, there are plenty. Determine if you have fed or cali spec. My guess is cali since it's an 01 but the label on the underside of your hood will tell you for sure. The codes for the O2 sensors will specify a particular one primary/Secondary & bank 1/bank 2. Knock sensor isn't the easiest to replace but with right tools it can be done. Again plenty if threads on that too. Good luck.
mclasser Jul 13, 2016 07:30 PM
Bad O2 sensors can certainly cause a wonky idle.
Donkeypunch Jul 13, 2016 09:52 PM
o2 sensers all out??
The fuse under the dash might be blown. it's 15a.
Cephyr13 Jul 15, 2016 02:19 AM
Ok, I'll check the fuses before I change the o2 sensors. Not sure if it's cali or fed. Didn't think it would be cali since I'm in Texas, but I don't know much about these cars.
Also, the cruise control slows down sometimes, so I'm guessing there's a vacuum leak that's messing with the idle as well.
Thanks for the input.
Cephyr13 Jul 15, 2016 02:26 AM
If the fuse blows, does that cause the codes to come up as o2 sensors going bad when all i really need to do is change the fuse?
Cephyr13 Jul 15, 2016 02:28 AM
Since the idle varies and my cruise control speed slows sometimes, I'm guessing a vacuum leak is the main cause. But I think the o2 sensors could be messing with it too.
MadMax SE Jul 16, 2016 12:16 PM
You may need a new iacv or if yours was just replaced it may be a cheap unit. I replaced mine with a $40 eBay one and every now and then when I start the car after driving a bit it will cut back off before it can idle. It only happens when its warm. A blip of the gas right after starting and the problem always went away. When my iacv broke I was idleing at 1500-2000 rpm and it was literaly gulping coolant through the seal in the iacv. A gallon every 4 days too be specific. No real advice can be offered unless you go to AutoZone or advanced and have them tell you what codes you have.
Cephyr13 Jul 16, 2016 08:53 PM
Yeah, I just got the IACV in the mail a few days ago from eBay--probably the same one you got. lol Cost me $35 I think. I'll probably change some vacuum hoses and the IACV when I replace the valve cover seals and knock sensor.
I already know what codes I have. Knock sensor and all three o2 sensor codes.
Thanks for the advice. Much appreciated.
cornholio Jul 16, 2016 09:05 PM
when you do iacv bypass the coolant- and if you think the iacv is bad might as well pull the ecm to check for damage
Cephyr13 Jul 16, 2016 09:07 PM
Why would I pull the ECM just because I'm doing the IACV? Is it by the IACV? I'm confused. (I obviously don't know much about these cars)
To bypass the coolant, will I just need to put a hose going around the IACV or throttle body? That's what I've always done to my Taurus SHOs.
- Brian
cornholio Jul 16, 2016 09:22 PM
- Brian
https://maxima.org/forums/5th-genera...d-seconds.html
iacv going can take out the ecm in these cars. lots of members have had to send it off for repair to solve their issues. long story short, it's suspected the iacv gasket fails, coolant leaks in, shorts the iacv and take out the ecm with it. hence the reason for the coolant bypass- basically you want to do what you said, route the coolant out of the iacv, i had to buy generic hoses to do this, but i think some members have reported being able to reuse the old ones
maxiiiboy has been consolidating info on this issue, perhaps he will post a link to his most recent document on it
maxiiiboy Jul 16, 2016 09:27 PM
iacv going can take out the ecm in these cars. lots of members have had to send it off for repair to solve their issues. long story short, it's suspected the iacv gasket fails, coolant leaks in, shorts the iacv and take out the ecm with it. hence the reason for the coolant bypass- basically you want to keep the coolant out of the iacv, so loop the in hose to the out hose connection, i had to buy generic hoses to do this, but i think some members have reported being able to reuse the old ones
Here: https://drive.google.com/file/d/0B6O...hibHlkRmc/view (URL updated 7/20/16)
Cephyr, read the above document before doing any repairs .
Cephyr13 Jul 17, 2016 04:46 AM
Will do. Thanks so much.
Cephyr13 Jul 17, 2016 05:04 AM
Thanks for the article. I'll get those issues taken care if while I'm replacing the IACV.
