Foglights wont work
Foglights wont work
Hi, I have an 01 SE that I recently purchased for $300 and I cannot seem to get the foglights to work. I noticed the fuse was missing in the fusebox but inserting one did not do anything. I tried to see if the bulbs were bad but I cannot seem to figure out how to remove them. I would like to get them fixed as I have an odd obsession with lights and stuff, and was considering even down the road swapping them out for some projector lamps but I would like to have the stock ones working first.
There is a fog light relay that is located by the power steering oil reservoir. The cover labels it FR FOG LAMP.
if you live in the snow belt, there is a good possibility that the light bulb sockets have corroded out and need to be replaced.
I will check the relay, but as for the sockets, I am not sure what the easiest way to get to them is. I was under the car but it looked pretty cramped. Could anyone maybe post a pic of what needs to be removed to access the bulb?
If you want to remove the fog light assembly, there's one bolt that secures it which is marked '15' in the attached picture. After you remove it, you'll need to pop out the assembly since it will be held in with the 2 pawls.
Might be a good idea to take out the assembly to inspect it. There may be a way to change the bulb without removing the assembly, but I don't remember if it's possible.
