Passenger Seat Air Bag Connector
Hi all
I recently purchased a 2001 Maxima. When I bought it the SRS light was blinking. The person I bought it from told me the light was due to a bad air bag module for the passenger side. While cleaning the car I discovered the connectors under the passenger seat were disconnected, however when I tried to connect them it would appear I am missing a middle piece to join them. Can anyone tell me what I am missing?
Chris
Chris
Chris
wow, I have to look at mine since I don't have power seat on the passenger side. I don't recall the side air bag was available on the 2001, I could be wrong but I remember when I bought mine new I still have the brochure and I looked and see and there wasn't available. You say your SRS light was blinking, that you might want to check and see if the car has deployed the airbag in an accident , hope you ran a carfax since a lot of previous owner never tell you that. You know the saying, "buyers beware". Hopefully the seller is right about the bad module.
There are no side curtain airbags. The passenger frontal airbag connector is behind the glove box. Big yellow thing you can't miss it. Wouldn't go messing around with it though until you disconnect your battery and wait a good 10-20 minutes for the capacitors to discharge. An airbag to the face would make for a bad day.
On that note can you direct me to a guide with continuity specs for for the module??
Chris
Rebel--. I found the air bag module while replacing the in cabin air filter. Correct me if I am wrong but I need to check the continuity of the module against factory specs to see if it is bad, correct? If it is I could try replacing it with one from a salvage yard or auto parts store and see if the light will reset. Or is that not a DIY type of fix??
Chris
Chris
Download the Service Manual for your car. You'll want the RS (Restraint System) section for sure. It's a lot of reading but will go through troubleshooting procedures for the airbags including how to pull the trouble code without a Consult II system. There are code readers that will do this easier but they are few and far between. Replacing the airbag can be a DIY job but care must be taken. Pay special attention to the safety section. Airbags are bombs. You do not want one going off in your face.
http://www.nicoclub.com/archives/nis...e-manuals.html
Download the Service Manual for your car. You'll want the RS (Restraint System) section for sure. It's a lot of reading but will go through troubleshooting procedures for the airbags including how to pull the trouble code without a Consult II system. .
If the fuse is good then the guide indicates the replacement of the module. Is there anyway to test the module?
