Not sure what this gasket is
It's the gasket in the middle the bigger orings I'm pretty sure the small ones are for the spark plugs
https://m.advanceautoparts.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&catalogId=10051&storeId=10151&krypto=NPJ0nA7%2FJ 9qJpIgwbDgWVWMkGdo%2Fy8Epn2Ft65GZf4nmzP9Puq1glv1d1 dug3AeMVoE4e31ryteqY81zhAhwIav8CT1CDl4cQMEiUqnILJ1 TmUNF1HX5AdK5YmcNfVHZq3EEgK6KYsWcNnqKUA1mbyVgHmaqg rD%2BlgSltQpm03X7LKr2e0FxZiDvqWqQpb1PNDJ2PN36BNx%2 BzkO8ztoa84ZWB6vWEV3yABK%2Fe5%2FhSr%2Bb04W6TQf1GOj 1cTMqEUo44Fd2WijYxk%2FU8yDW2dUWFIosV4wEDQABjvKLuSV F3e82SeKdRFf2rTZO%2FM4qvY7421YDN0s9BpeLi4evEIrp18F oeGyensqLt2M5wJOu1ck1M9zbFTu%2FHj9wpahRc5bI%2FexGI oQ7H0lYCu3O2HK3YsI8K1y%2B8vh8Zb6lN%2BL7djM2lH1Ht%2 F3IFjmLqv9RYV3WG%2F4IPwJXCOzMlfvSCMDLmyJrmTXaCCMjv HS%2FrX3ym2biJuQzGNpER9ez7Mb1%2Fq7II9iQyc85l%2BhPd 1X3FSwxbABjMn9myKZh0AiQWH5lairqbu%2FKedNwGmf%2BtEv GUplLn5CzKkSC3bO0l2hirozytw%3D%3D
That's a valve cover gasket. Just not for a Maxima. It's completely wrong even without the 4 spark tube seals.
Looks like a gasket for a 4 cylinder engine.
Maybe for a 2.5 liter Maxima from overseas.
You want the whole set. The very large gasket is for the cover, and like someone said, the others are for the spark plug seals and the small bolts holding the cover down.
Look at YouTube. There is a very good video of a complete replacement that I've watched and probably many others. It will make sense when you watch them.
If you're replacing the VC, the new one comes with the spark plug tube seals already installed so all you need is the gasket.
If you're just replacing the gasket on a 3.0 car you can replace the spark plug tube gaskets as well.
The 3.5 cars have plastic VCs and are very easy to break if you try to remove the old tube seals. You can use some quality RTV like Hondabond on them and reuse the seals but it's recommended to replace the VCs all together.
