Power steering belt tensioner
anyone know how to replace it?? I thought I could reach and unscrew the top bolt but I was wrong. Must be a nut on the other side and I’m not sure the easiest way to access it. i went to change the belt since I’m squeels but the tensioner screw is broken. Already have the new part. thanks in advance |
There is write up's and you tube videos all over for it. If you have the part then you should be able to tell how it comes off. I just changed it with my alternator last week.
I must be slow. I see write ups for the tensioner up too in the engine bay but that is for the alternator belt. I can’t see where I have access to the power steering belt. guess I’ll keep searching |
Here is a video on changing the power steering pump belt. It shows how to loosen the tensioner, so maybe you can get enough info to change it.
Key to it is that you must loosen the 14mm bolt behind the pump before messing with the tensioner
Belt is loose or squeals, b/c it's junk? If it's tight enough...
...then you can just cut the old one off and crank the new one on with a screwdriver. |
Nope the belt squeels because it is loose. I can not tighten it because the longer tensioner bolt is snapped. Just one of those things I will have to figure out. |
Originally Posted by 2damax
(Post 9172557)
go to the dealer ...save yourself the headache. I got the new tensioner and belt installed for $160
Here's the video I used to change mine,
© 2024 MH Sub I, LLC dba Internet Brands
