Orange/white wire behind Bose hu ?
My Bose hu is not getting power I removed the hu and found 2 plugs unhooked one comes from the hu orange/white stripe the other has orange black blue and red not sure where they go no plugs for them but I doubt they put them there for no reason I searched and no luck nothing to tell me what these may be or where they go also my car is an 01 se
Those may have something to do with the optional 6 CD changer. The radio/head unit only uses 2 connectors. The power for the head unit is on pin 10, a purple wire in one of the corners.
This power comes from fuse # 1, a 10 amp fuse in the dashboard to the left of the steering column. Fuse # 1 is in the top row, the left end.
Since you know the plugs better, look at this diagram: http://natebird.me/2001-nissan-maxim...iring-diagram/
Here is the 2000 & 2001 Maxima wiring.
Code:
This view is looking into the radio connector or the harness connector as plugged into the radio. Connector M62 (10 wire connector) ╔═══╦═══╦═══════╦═══╦═══╗ ║ 10║ 8 ║ LOCK ║ 4 ║ 2 ║ ╠═══╬═══╬═══╦═══╬═══╬═══╣ ║ 9 ║ 7 ║ 6 ║ 5 ║ 3 ║ 1 ║ ╚═══╩═══╩═══╩═══╩═══╩═══╝ 1 - Black - lft frnt speaker - (l/y for non-bose) 2 - White - lft frnt speaker + (l/w for non-bose) 3 - Red - rt frnt speaker - (br/w for non-bose) 4 - Green - rt frnt speaker + (br for non-bose) 5 - Green/white - antenna power 6 - Yellow - constant 12 volts 7 - Red/yellow - dimmer control 8 - Red/white - dash lights 9 - black - ground for frt spkr wire shield 10 - Purple - switched 12 volts Connector M61 (6 wire connector) ╔═══╦═══════╦═══╗ ║ 16║ LOCK ║ 12║ ╠═══╬═══╦═══╬═══╣ ║ 15║ 14║ 13║ 11║ ╚═══╩═══╩═══╩═══╝ 11 - black - ground for rear spkr wire shield 12 - Green/white - amplifier on 13 - Black/red - lft rear speaker - (b/y for non-bose) 14 - Brown - lft rear speaker + (lg for non-bose) 15 - black/white - rt rear speaker - (p for non-bose) 16 - Blue - rt rear speaker +
