Wet Driverside Floorboard When it Rains
I keep getting water in my driverside floorboard when it rains. I don't have a sunroof. I had a mechanic look at the drain tubes and claims he cleaned them out. So I'm not sure if that's it or not.
Another thread on here had a guy who's Maxima had a tiny rusted out hole in his floorboard. So I'll probably check that next.
Anyone have experience with this?
Thanks.
Thanks.
Different car, but I had a leak on the Drivers side, was dripping down through the dash onto my feet form a bad windshield seal. Bad windshield seal is my first guess for sure. To repair it they needed a new windshield, as they expected to damage/break the old one. Was covered under warrantee so no need to call the insurance. Down side was waiting 2 weeks for a new windshield, also getting the dealership to concede it was in fact the windshield took a couple visits.
first guess is door gasket, because i have same issue. i get extra water on the door sill when it rains and have messed w the door hinge to get the door to shut better and it slowed the water entry, but still is existant, and it pretty much is a sign that it is the door seal.
My 4th Gen was involved in 2 accidents and I believe it could be the windshield itself....cause mine leaks right near the driver's left kick panel. the windshield was cracked when the car was given to me 7 yrs ago. The top windshield seal appears to be damaged. I replaced the driver's side fender when I first received the car and I've resealed the lower windshield and cowl area and didn't see any defects in those areas. I'll get out the water hose and start at the lowest position possible to find the leak. Start at the cowl with someone else and a light til you find about where the water was hitting just before the leak started...I'm hunting mine down and it'll probably disappear after the windshield is replaced!
look into where the water is coming in, maybe go as far as getting a friend to go to car wash or a hose at your house and sit inside the car and have them throw water on it to see the leak in action.
in my case its definately creeping in at the door sill near the hinge side (front). i am going to look into that ebay stuff, i almost was gonna buy a full oem gasket but yea thats the whole side of the car (2 driver side doors)
good info !, i am getting some weird very spotty water in my sunglass holder from my sun roof, its really confusing because its not everytime, i thought it was the windshield (it was replaced and under warranty) but it only comes in at the sunglass holder near the map lights. and only is 4-5 oz per rain storm, smaller stomrs I dont get any water there.
no problem, As a temporary solution before I got the windshield replaced, I put a thin microfiber cloth half in the sunglasses holder and half out (or what ever portion of it that allow visibility not to be blocked), like that the cloth absorbed the water so it didn't leak down.
PS. this is not related to the floor board, and I have a leak with that as well, and I am thinking that is door gasket to keep on topic
sounds perfect and a good idea, so i wanted to ask you a little more about this, was it like every other rain storm you had this? and is it literally in the sunglass holder and it like drips small amounts? i remember if i started driving on flat ground I wouldn't notice it till I hit a hill or turned and then it would drip, it was almost like the sunglass hodler held the water in untill tipped out. is that similar to what you had?
You guys with the sunroof leaks. There is only one way for anyone to fix if the gasket is in acceptable condition and it's super easy. On the left a right side there is two 10mm bolts/nuts. Either loosen and adjust or take out glass and shim. A quick realign fixes the leaks most of the time. The dealership still has shims (c washers) and they are cheap. If you get those you don't even have to take out the glass. Or regular washers. It usually just takes a little adjusting. Most sunroofs work this way. I just went through this a couple months ago. I had a leak and the glass was sitting kinda low so I figured a shim would take care of both. It was in the shop so theu said they would just do it real quick. The glass was now sitting a little to high and you could hear extra wind noise. Not to mention the leak was still there albeit much less. So I took the shims back out. Fixed the leak and the glass sits correctly. In the end it just took an adjustment.
Dolphinride
23
05-25-2017 09:48 AM
shobuddy
10-11-2013 08:41 AM
Flutie7NFL
03-05-2010 12:48 AM
