Replacing a CV boot
I noticed that my passenger side axle is slinging grease all inside of my wheel yesterday while i was replacing balljoints, tierods, etc. It is the joint closest to the hub, the boot is not cracked but there is a hairlines gap under the larger end of the boot where the clamp/band is that is allowing grease to escape. Luckily in my case it appears the grease is still escaping and contamination has not gotten inside yet - this must have happened in the last hundred miles or two at the very most so its still a fairly new development. I went ahead and got a boot kit off of rockauto that appears to have everything i need (boot, clamps, big bag o’ grease) Anyways, can anyone give me a lowdown on how exactly the boot comes off and gets replaced? Theres tons of threads on this but they all devolve into a dozen people suggesting to just replace the axle, which was probably great advice in 2008 but not really helpful at all today with aftermark axle options being so poor quality. I did find a link to this writeup on a sentra forum: https://www.sr20-forum.com/general-m...axle-boot.html Does this seem like a fairly accurate writeup in terms of the axle layout? I figure the design of nissans axles cant be that different across the board. If so - i noticed that the guy leaves the axle in the transmission, and hammers out the outer cv joint from the axle shaft. Is this simple as it looks, ie; it simply pops off with a bit of force? Or is there more to it than that? Id prefer to not remove the entire axle as i dont wanna muck around with gear oil but if doing so makes the job drastically easier ill just suck it up and do it. Also, assuming i remove that joint, is it always necessary to fully clean it before reinstalling, or is it possible to just add grease if there was minimal/no contamination getting under the old boot? What kind of chemical would be best for dealing with that much grease? Or do you guys think i should just wipe off as much old grease as possible and not use chemicals at all? If anyone has dealt with this job before id be very grateful. Any recommendations on how to go about this would be much appreciated, im looking to do this soon so i dont have to worry about the joint itself getting damaged and needing to replace or rebuild the axle itself. |
Search it on youtube, but your link is good for the process, but it needs to be removed. Basically, you have to put it in a vice and beat it off over the snap ring, then it's cake. Buy the boot kit with grease, but if the outer is in really nice shape, then you could just regrease and clamp it down harder. Sooner or later the inner boot (sooner lol), it's gonna rip wide open if original boot. I think I paid 12 bucks/each on ebay for the name brand.
bunch of edits, hungry and tired |
Originally Posted by Slamrod
(Post 9192652)
… Also, assuming i remove that joint, is it always necessary to fully clean it before reinstalling, or is it possible to just add grease if there was minimal/no contamination getting under the old boot? What kind of chemical would be best for dealing with that much grease? Or do you guys think i should just wipe off as much old grease as possible and not use chemicals at all? If anyone has dealt with this job before id be very grateful. Any recommendations on how to go about this would be much appreciated, im looking to do this soon so i dont have to worry about the joint itself getting damaged and needing to replace or rebuild the axle itself.
See post #17 here for a ghetto CV boot fix, that actually holds up surprising well.
Originally Posted by CRBWS6
(Post 9194113)
© 2024 MH Sub I, LLC dba Internet Brands
