Need to replace entire headlights on my 2002 Maxima
I don't know if these will fit?? It says they don't fit factory HID xenon lights?? I don't know if that's what I have?? I would assume it's whatever the factory put it when they made the car. Does it even matter if I'm changing the whole entire thing?(mine are busted and cracked completely) will these work with my car?? And if so are they easy to install? Please I need advice I'm a woman and don't know much about cars . Here's the link to the ones I'm looking at buying if they will work??
https://www.ebay.com/itm/FIT-2002-2003-MAXIMA-JDM-BLACK-TWO-HALO-HEADLIGHTS-LAMPS-02-03/401635303563https://cimg8.ibsrv.net/gimg/maxima....5583db9831.png https://cimg7.ibsrv.net/gimg/maxima....81e7dcc1ed.png |
You dont want those, they are supposed to be much less effective than the stock headlights you had already. Just grab some used headlights, use ebay or a website called carpart that lets you search any junkyard in your area. |
Originally Posted by Slamrod
(Post 9193157)
I know these probably aren't preferred but for the sake of saving money... If I do get these will they fit or go in? Or they don't even match?
The headlights you found not only will suck but also wont fit the bulbs your car uses, 2002-2003 maximas use HID/xenon bulbs and the headlights you found say they wont work with those. Im sure it could be modified but again, ive heard nothing but bad things. try typing “2002 maxima headlight oem” and using the filter to accept only used items, youll get a ton of buying options. Yeah, theyre expensive with each hl costing on average $100, but be thankful this isnt back in the day when they were going for like 2 grand each lol |
keep looking, and you can even find them used around here, and + 1 on using a computer it is almost the only way to search for these things,
Originally Posted by vingodine
(Post 9194398)
© 2024 MH Sub I, LLC dba Internet Brands
