Need help with the EMC,,,, cant find to buy plsss
https://cimg6.ibsrv.net/gimg/maxima....b1296316ea.jpg
https://cimg8.ibsrv.net/gimg/maxima....55c44426cc.jpg Hello I need help with the computer plssssssss,,,, cant find it whic one it is to buy or get it |
What is a EMC?
Did you mean ECM? (ECU?) |
yes pls where I can get it
Originally Posted by flakobello
(Post 9200795)
Yours may be different,after you get your number search ebay. https://cimg2.ibsrv.net/gimg/maxima....8ccd592a49.jpg |
My was stolem from the car , thats why dont have the part number so what can i do in this case? Sent the pic of the car
This is for the Israeli market. Any of the following part numbers should fit:
23710-3Y905 23710-3Y907 23713-3Y905 23713-3Y906 |
Im in the usa, where can i get it ? Besides ebay that im not able to find it
Google the part numbers.
Hello I need help with the computer plssssssss,,,, cant find it whic one it is to buy or get it for this car,, what is the part number ,,, the computer |
(Post 9200813)
Are you from the US? Does the car have EGR? |
Motor 3.0 V6
Automatic Engine model VQ30DE 2002 year https://cimg2.ibsrv.net/gimg/maxima....fadb797c15.jpg |
(Post 9200833)
Motor 3.0 V6
Automatic Engine model VQ30DE 2002 year Does it have traction control? |
(Post 9200825)
Hello I need help with the computer plssssssss,,,, cant find it whic one it is to buy or get it for this car,, what is the part number ,,, the computer 23710-3Y905 23710-3Y907 23713-3Y905 23713-3Y906https://maxima.org/forums/images/max...ser_online.gif https://maxima.org/forums/images/max...ons/report.gif |
Originally Posted by krismax
(Post 9200847)
OK do a carfax on your car or a vin check to find all options . Your car is not a 2002 ,they didn't have a 02 with 3.0.
SO what I supossed to do in this case? what do yu think ?
https://cimg1.ibsrv.net/gimg/maxima....12c22064e1.jpg
https://cimg0.ibsrv.net/gimg/maxima....973c787026.jpg WHAT WOULD BE THE EXALTY COMPUTER FOR THE CAR ,, |
(Post 9202496)
https://cimg0.ibsrv.net/gimg/maxima....973c787026.jpg WHAT WOULD BE THE EXALTY COMPUTER FOR THE CAR ,, that looks like an 00-01 i30. Answer these questions do you have an EGR system . It's under your TB. That's a VQ30DEK engine. IACV burns out the ECM and the electric Motor mounts. You need to replace the IACV and unhook the motor mounts if you have them. You need to fix those issues before you put a new ECM in. If not it will burn out again. I can get you a ECM if you answer my questions. And also do you have someone who can program your ECM? |
IACV is below the Throttle body ,it needs to be replaced with a nissan part .NOT aftermarket. Then it needs the antifreeze bypassed.easy to do.
Heres a picture of it. https://cimg1.ibsrv.net/gimg/maxima....ae096fd1af.jpg |
It was stolen, taking out
(Post 9202503)
Does your car have EGR? I can find you an ECM but i have to know ,this. Does it have EGR. |
Im going online and i can not find the model 23710-3y905
Yes i have one
This is the EGR its near the throttle body. Some cars don't have it. Mine doesn't .
https://cimg4.ibsrv.net/gimg/maxima....bd98893c43.jpg |
I have it , its in there
Its in there, my ecm was stolen from the car
(Post 9202505)
You need to tell me all the options traction control, EGR then i can find one for you. |
I WAS TOLD TO LOOK FOR THESE MODELS WICH I WENT TRHOUGH ONLINE AND ACTUALLY THE PARTS ARE NOT AVAILABLE AT ALL.
Any of these will work for your car 23710-3Y905 23710-3Y907 23713-3Y905 23713-3Y906 2261123710-3Y805ENGINE CONTROL MODULE(GEN+ME).VQ30DE.AT 2261123710-3Y815ENGINE CONTROL MODULE*GEN.VQ30DE.AT 2261123710-3Y905ENGINE CONTROL MODULE*GEN.VQ30DE.AT 2261123710-5Y205ENGINE CONTROL MODULE*GEN.VQ30DE.AT 22611 ⤷ 23710-5Y206 ENGINE CONTROL MODULE*GEN.VQ30DE.AT 22611 ⤷ 23710-5Y207 ENGINE CONTROL MODULE*GEN.VQ30DE.AT 2261123710-5Y320ENGINE CONTROL MODULE*GEN.VQ30DE.AT 22611 ⤷ 23710-5Y321 ENGINE CONTROL MODULE*GEN.VQ30DE 2261123710-5Y360ENGINE CONTROL MODULEGEN.VQ30DE.AT 22611 ⤷ 23710-5Y361 ENGINE CONTROL MODULEGEN.VQ30DE.AT 2261123710-6Y510ENGINE CONTROL MODULEGEN.VQ30DE 2261123713-3Y805ENGINE CONTROL MODULE(GEN+ME).VQ30DE.AT 2261123713-3Y815ENGINE CONTROL MODULE*GEN.VQ30DE.AT 2261123713-3Y905ENGINE CONTROL MODULE*GEN.VQ30DE.AT |
TOMORROW I WILL TRY TO LOOK FOR THE TRACTION CONTROL, HOW CAN i look for that facture of the car.
Tendrá un interruptor en el tablero. Por el clúster.
Tienes Corrígeme si estoy equivocado. 00-01 maxima / i30 (esto es realmente lo que tienes en los EE. UU.) EGR transmisión automática No puedes mirar el ECM por números de parte. Porque los ECM no tienen números de parte en ellos. Tienen diferentes números en ellos. PUEDO encontrarte un ECM / ECU si haces lo que digo. |
Puedo conseguirte un ECM.
Tu coche es un US i30 2000/2001. Necesita un ECM automático 2000/2001 maxima / i30 con EGR. Parece que no tienes control de tracción. Pero está bien si el nuevo ECM no tiene EGR .better para deshacerse de él de todos modos. Le conseguiré uno por $ 50 y lo pondré en eBay y pagará el envío. Puedo conseguirlo a principios de junio. |
Excelente utds sabe mas que yo,,,, por que por ebay no la hay verdad?
(Post 9202570)
Lo publicaré para usted en la sección de 5ta generación en venta cuando lo reciba. ¿Tiene un distribuidor de nissan cerca de usted para programar el ECM? Porque lo necesitará. No puedes ponerlo. no funcionará. |
Si si lo tienen aqui te mando los conectores del carro hacia la computadora y me puedes mandar el link de ebay lo podemos hacer por hay
https://cimg9.ibsrv.net/gimg/maxima....e76ef49887.jpg |
No necesito tus conectores, guárdalos en tu auto. Las teclas deberán programarse para el inmovilizador, para el ECM.
¿Tienes un chip en tus llaves? ¿Hay un inmovilizador alrededor de su ignición donde entra la llave? El lugar de nissan donde atienden los automóviles necesita programar las llaves cuando las reciba. |
Tengo un 00 i30, su conector se ve igual que el mío.
Te daré el enlace cuando reciba un ECM / ECU https://cimg0.ibsrv.net/gimg/maxima....40b994bb5e.jpg |
ecm
[QUOTE=krismax;9202500]¿Su IACV quemó su ECM?
parece un 00-01 i30. Responda a estas preguntas si tiene un sistema EGR. Está debajo de tu TB. Ese es un motor VQ30DEK. IACV quema el ECM y los soportes del motor eléctrico. Debe reemplazar el IACV y desenganchar los soportes del motor si los tiene. Debe solucionar esos problemas antes de colocar un nuevo ECM. De lo contrario, se quemará nuevamente. Puedo conseguirte un ECM si respondes a mis preguntas. ¿Y también tienes a alguien que pueda programar tu ECM?[/QUOTE Amigo busco una ECM 23710-3Y905 Nissan Maxima "01 3.0L V6 VIN: JN1CCUA33Z0150385 |
© 2024 MH Sub I, LLC dba Internet Brands
