Air Conditioning - Maxima Forums
Air Conditioning
Old 03-01-2019, 03:50 PM
Air Conditioning
I have replaced the fuse, relay and the ambient temperature sensor........and still NO air. The blower and controller module are new also. Still the
clutch on the pump is not engaging. Unless theres some other trick. I'm at a loss???
dnichols5053 is offline
Old 03-01-2019, 04:04 PM
Slamrod's Avatar
clutch will not engage if there is not enough freon or w/e the gas is called in the system, to prevent it from burning out. It also will not engage if its overfilled. You can test if it works by taking a wire from your + battery post and jumping the terminal on the condensor. If it engages when you jump it, you know the condensor is working, if it doesnt, then you need a new one. Obviously you only want to jump it for a second just to see if it engages.
Slamrod is offline
Old 03-02-2019, 05:24 AM
Air
Thank you.....Will try on Monday.
Old 03-02-2019, 09:07 PM
If you have the auto climate controls, you can run a self diagnostic. In case you do, here is a link to the instructions.
http://boredmder.com/FSMs/Nissan/Maxima/2001/HA.pdf
The procedure starts on page 37.
DennisMik is offline
MAXSRB
10-03-2004 11:16 AM
Omegasrk
04-03-2001 08:36 AM
Colonel
03-23-2001 10:21 AM
bobg
11-18-2000 02:15 PM
jahav
09-07-2000 12:42 AM
Quick Reply: Air Conditioning
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
