Recharging AC q’s
If im recharging the AC but not replacing any components other than the drier/accumulator, do i need to add oil? Im finding nothing but conflicting info on this. My thought is no - straight r134a without additives is what i need, since vacuum purging wont remove oil? I dont want to add more and find out its too much and murder my ac compressor in the process. Plus less oil is safer than too much. Ill be using a manifold gauge set to do this, ive done it before on one of my 4th gens but i dont remember if oil was used or not.
If anyone could fill me in that would be awesome, starting to get too warm to go without AC any longer. |
So it turns out there is a significant leak on the high pressure side. There is a distinctive hissing noise at the back passenger side of the engine bay, where it appears some hard lines meet the firewall. Of course it has to be the worst cvntiest spot ever. It appears that this is the evaporator coil, which means now i have to pull the dash to get to it... Im hoping this is bad as it gets? Does anyone have experience with this? My biggest concern is that the hardlines leading to the evap coil are damaged, idk how i will possibly replace them considering i dont know where to find replacements. I imagine it must of gotten bumped during the motor swap.
In any case - can anyone fill me in on how those hardlines connect to the evap coil? Maybe i could just use some sort of sealant when i reassemble? Thoughts? edit: another question - how do i know which style of evap coil i need? https://www.rockauto.com/en/catalog/...ator+core,6768 rockauto has 4 listed and they come in 3 different styles, how do i figure out which is correct? |
I just finished this job. I just wrote a big response and then my tab crashed. Here is the condensed version:
Do not add oil if compressor was factory filled and working fine before service. FSM AC section about filling compressor is a good read for general knowledge. Lines at firewall connect to a TXV, I bought this one: TXV connects to evap coil, I bought this one-Four Seasons 54876: https://www.rockauto.com/?carcode=1431954&parttype=6768 You may have tweaked something during your swap. I doubt your evap coil was harmed. I replaced mine because I replace everything. Cabin airbox is a biatch but doable if you decide to replace your coil. I would say a 5/10. Took me about four hours both ways and I only broke a small piece of plastic on the white heater side pulling the airbox out but repaired it easy with glass and epoxy. There is no information on the forum other than one member I discussed this same issue with while he was searching for info. I can't find the thread to link, so here is a quote from the only other documented member to have done this with 5th gen and is what I used to guide me: "For anyone that still needs info on this though it's not as common as the fourth gen, I didn't get a chance to take pics but I installed my new evaporator and expansion valve. Removed the glovebox (6 screws and the light connector). Unplugged and unscrewed blower motor, unplugged blower resistor, some sort of blend door connector towards the top, removed right front lower kick panel, removed the air bag assembly (2 twelve mm. Bolts and connector). This helps with getting to the upper evap housing bolts and upper crash bar bolts. Removed a ten mm to the right of the opening that holds a black connector relay housing. Removed 2 10 mm. Bolts for a small bracket to the right that the black plastic piece. Removed the 6-8 10mm bolts that hold the evap box to the dash, removed the two a/c lines on the engine compartment side of the firewall by removing the 10mm, pull the lines out, and then there is 2 allen head bolts, I can't remember the size exactly. Wiggle and pull out the expansion valve, then go inside and last but not least I removed the 2 12mm nuts that bolt the crash bar in. The airbag removal makes getting to the top but easier and I got the the lower 12mm with a semi deep socket, swivel, and a extension. Then either have someone pry out on the bar or like the other person said jam something under the plate. I pulled the weather stripping partially out of the door jam right next to where the roll bar is under the dash, used my knee and pushed on the pry bar while driving the box out and down, (please note while removing, release the white tab on top of the housing to the left where it meets the heater box cause you may break that). It's not easy to remove, deep breaths and making sure your not cracking or breaking anything. Then once you get it out it's 7 screws I think and 3 black spring clips that holds it together, remove the evaporator and replace. I used foam wrap around the lines that go through the firewall to help kinda seal against stuff coming in. I reinstalled everything, used new o rings on everything, you can spray them down with silicone spray or soak them in oil. I left the expansion valve for last since you can install it through the firewall side and I believe it helps with clearance. Hope this helps, sorry I didn't get pics, was in a rush. Takes about 2 hours" If I were you, I would replace the TXV and associated O-rings, repair/reconnect the lines and pull a vacuum. It only makes sense that you hit the lines while lifting engines out/in. Probably just need to straighten them out and reconnect. https://cimg1.ibsrv.net/gimg/maxima....ff0a57b446.jpg https://cimg5.ibsrv.net/gimg/maxima....434eb29fbc.jpg https://cimg6.ibsrv.net/gimg/maxima....408aa9d6a4.jpg https://cimg7.ibsrv.net/gimg/maxima....def3932639.jpg https://cimg8.ibsrv.net/gimg/maxima....06aa8b185c.jpg |
Originally Posted by User1
(Post 9202104)
Do not add oil if compressor was factory filled and working fine before service. FSM AC section about filling compressor is a good read for general knowledge. Lines at firewall connect to a TXV, I bought this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 TXV connects to evap coil, I bought this one-Four Seasons 54876: https://www.rockauto.com/?carcode=1431954&parttype=6768 You may have tweaked something during your swap. I doubt your evap coil was harmed. I replaced mine because I replace everything. Cabin airbox is a biatch but doable if you decide to replace your coil. I would say a 5/10. Took me about four hours both ways and I only broke a small piece of plastic on the white heater side pulling the airbox out but repaired it easy with glass and epoxy. There is no information on the forum other than one member I discussed this same issue with while he was searching for info. I can't find the thread to link, so here is a quote from the only other documented member to have done this with 5th gen and is what I used to guide me: "For anyone that still needs info on this though it's not as common as the fourth gen, I didn't get a chance to take pics but I installed my new evaporator and expansion valve. Removed the glovebox (6 screws and the light connector). Unplugged and unscrewed blower motor, unplugged blower resistor, some sort of blend door connector towards the top, removed right front lower kick panel, removed the air bag assembly (2 twelve mm. Bolts and connector). This helps with getting to the upper evap housing bolts and upper crash bar bolts. Removed a ten mm to the right of the opening that holds a black connector relay housing. Removed 2 10 mm. Bolts for a small bracket to the right that the black plastic piece. Removed the 6-8 10mm bolts that hold the evap box to the dash, removed the two a/c lines on the engine compartment side of the firewall by removing the 10mm, pull the lines out, and then there is 2 allen head bolts, I can't remember the size exactly. Wiggle and pull out the expansion valve, then go inside and last but not least I removed the 2 12mm nuts that bolt the crash bar in. The airbag removal makes getting to the top but easier and I got the the lower 12mm with a semi deep socket, swivel, and a extension. Then either have someone pry out on the bar or like the other person said jam something under the plate. I pulled the weather stripping partially out of the door jam right next to where the roll bar is under the dash, used my knee and pushed on the pry bar while driving the box out and down, (please note while removing, release the white tab on top of the housing to the left where it meets the heater box cause you may break that). It's not easy to remove, deep breaths and making sure your not cracking or breaking anything. Then once you get it out it's 7 screws I think and 3 black spring clips that holds it together, remove the evaporator and replace. I used foam wrap around the lines that go through the firewall to help kinda seal against stuff coming in. I reinstalled everything, used new o rings on everything, you can spray them down with silicone spray or soak them in oil. I left the expansion valve for last since you can install it through the firewall side and I believe it helps with clearance. Hope this helps, sorry I didn't get pics, was in a rush. Takes about 2 hours" If I were you, I would replace the TXV and associated O-rings, repair/reconnect the lines and pull a vacuum. It only makes sense that you hit the lines while lifting engines out/in. Probably just need to straighten them out and reconnect. https://cimg1.ibsrv.net/gimg/maxima....ff0a57b446.jpg https://cimg5.ibsrv.net/gimg/maxima....434eb29fbc.jpg https://cimg6.ibsrv.net/gimg/maxima....408aa9d6a4.jpg https://cimg7.ibsrv.net/gimg/maxima....def3932639.jpg https://cimg8.ibsrv.net/gimg/maxima....06aa8b185c.jpg i think my first shot is going to be the ghetto route - disconnect the hard line and reconnect it with a tiny dab of rtv or something on the threads. Maybe ill get lucky and get away with it, function over form. |
The TXV is easily accessible (and only, unless you remove the airbox under the dash) from engine bay side. Two screws fasten it to the evap coil. Only one bolt to remove the line set from the TXV. Like i said above in the "if I were you" line. That's all I would do because I think that's all you need to do :)
RTV on what threads? The suction line connection up top mid-way between the heads? That joint is O-ring sealed. No RTV needed. |
Do you guys have the AC service machine? because when it's totally empty you need to vacuum the air out.
Originally Posted by krismax
(Post 9202109)
Ahhh ok, now its making sense. I really didnt understand how it all connected together but the way you describe it mades it sound simple. Its a bit of a tight spot and it was getting dark so i couldnt really make out what was going on back there but now i think i got it. Im going to go ahead and order the TVX and oring set and see if that solves the problem, the AC worked before the swap so the evap coil should be just fine. Ill try disconnecting and reconnecting first though just to see if i can get lucky lol.
As for the system itself im using manifold gauges to hook up and monitor pressures. Also you can rent a vacuum pump from autozone for free, its a $160 deposit but the thing works, ive used it in the past as well. |
Here is what you'll be dealing with. The only part inside the car being the coil.
https://cimg2.ibsrv.net/gimg/maxima....3dff0783b0.jpg https://cimg6.ibsrv.net/gimg/maxima....86ba07510b.jpg |
So i replaced the TXV and appropiate orings. Leak is gone. However, im still having issues. Once the system is cleared, i go to fill the low pressure side with refrigerant. The high side goes up to around 60psi and the low side goes up to around 50ish psi if i let it, i tried going to 30psi and nothing happened so i went higher. Compressor does not engage at all. Does this mean my compressor is toast? Im not understanding what i am doing wrong, shouldnt the compressor kick on and pressurize the high side? Car is running and climate control turned low as it goes. It seems the low and high side are more or less equalizing with the remaining pressure of the freon can and nothing happens after that. Can feels like its still half full.
What am i missing here? |
Get a temperature pressure chart for 134a. Im on mobile right now. Give me a few to get in front of a computer. You're not even close to the pressures you need to be at.
(Post 9202404)
edit: i tried jumping the compressor as a last resort. Clutch engages but it has no effect on the pressure readings, which to me further suggest my compressor died somehow. I didnt really fool around with this a lot though, because i didnt want to create any new problems. |
Check the under hood label. I think it reads 16 ounces or so IIRC. I didn't have time to check mine before I left. How are you measuring refrigerant? If you're using the 12oz cans, go ahead and dump one in with the car off. Start car, run AC full blast everything. Add second can 4oz (check total system volume) DO NOT slam liquid refrigerant into a running compressor! Charge with gas only, meaning do not invert the can. You are looking for a Delta T of around 45 degrees discharge air at 90F, more is better but again, too low and your coil will freeze. Not a common issue anyway as you'll hit your charge weight before that happens. Lot's of variables at play though. Lots of temp & pressure charts on google images. You want to check your discharge air temp with the windows down and the system on fresh air, not recirc, so we know exactly what's going on.
Also, good job on your leak fix! How did you test? Did you pull the system down for a while? You need to pull vacuum from both sides because you don't know if the TXV was open or closed. I don't know how it comes anyway. Whatever, pull vacuum from high and low service ports and leave for an hour or so. Maybe you did this. At any rate, if compressor was working fine before, no reason it shouldn't be fine now unless something happened during the swap. Let us know. Good thread as everyone is gearing up for summer and the Maxima AC is a pretty easy system to service. |
(Post 9202413)
If your pressures remain unaffected after manually engaging the compressor, then yeah, it is no longer a compressor lol.
Yeah, thats what i figured, i guess i just wanted to hear someone else spell it out for me just in case there was something else that i was missing and could account for the circumstances. Well that sucks. Considering the age of the car i guess i cant be that mad about it, but even so, im curious what killed it to begin with. It is worth mentioning that the AC i had before the swap was kinda sucky, like on a hot day it just barely made the car bearable to sit in. My 4th gens on the pther hand got ice cold, and that was with a black car and black interior soaking up heat as compared to my currently tan interior. For those of you with working AC, is it actually good? Was my AC on its way out all along, or does the 5.5gen AC just kinda suck in general?
So back to repairs - a new compressor is obvious. What about the evap coil? Brief bit of reading that i did says you should always replace the evap coil with the compressor in case of metal shards getting into it and clogging it up. I didnt see any such evidence of any material (other than neon green freon ofc) when i did the TXV. Opinions on leaving the evap coil alone? The stuff i read was just general, broad advice and not particular to maximas, so idk if it even applies. Wondering if anyone who has replaced their compressor and not the evap coil and had no issues, or did end up having issues. I gotta say, sometimes i feel like some sort of Sisyphus, pushing a boulder up a hill only for it to roll back down over and over and over. Damn cars are like a never ending project lol. |
Condenser is recommended to replace when a compressor craps out as it's next in line in the direction of flow. Evap coil is fine as compressor frag won't make it through the condenser coil, liquid line, then evap coil. It's too far. The green substance you are seeing is UV dye. As cheap as they are new, and as easy as they are to replace, I wouldn't even bother with diagnostics if I was remotely inclined to believe the compressor failed. Pull radiator, replace condenser, replace compressor, reinstall radiator, done.
For the sake of humor, I'm not sure what would be failing. A stuck reed would send high side way high, you're not even getting a pressure increase. Clutch may be engaging, but the compressor shaft may have failed. Why it engages manually and not with controls, not sure. I'd have to look at it. Try throwing a new pressure switch in. Or test yours. It lives on the driver side of the condenser. I replaced mine when I replaced everything. I still haven't used my system yet. I ruined the hose I had fabricated and have to go back to the hose guy this week, hopefully tomorrow. Getting too damn hot in Tampa already. |
Yeah, im gonna wait til tomorrow to order new parts. Gonna mess around a little more just for curiousity sake, cant hurt since the thing is already toast. Im curious about that switch also, ill see what role that has to play in this saga.
Yep usually a switch for each side. Not sure where the low side switch is for this car, never looked. If you're bypassing all that though and pressures don't change then bad compressor obviously.
great thread !
(Post 9202451)
great thread !
Ive been wanting to repaint the grill black but taking the whole bumper off just for that seems dumb lol. Now i finally have a good reason i guess. edit: does anyone know if the OEM condensor is tube + fin, or parallel flow? |
Why bother disassembling the front end? Pull the radiator. Accumulator/drier was a component of the condenser for mine, not a separate part -note: I opted for aftermarket on my evap and condenser coils, not even sure if what came with my car was oem so no idea about a separate drier, they usually come together-. Right to left parallel flow, no serpentine tubes.
(Post 9202532)
Not a hijack: see pertinent info below.
Just buttoned up my system today. Been at this non-stop for two days building line sets and $hit. Been working on (procrastinating because it was still cool out, running into swap/retro-fit issues) the system for months. Total charge weight introduced into my bone-dry, brand new system until I was satisfied was 18oz. Underhood label calls for 1.10lb=0.5kg=500 grams=17.6oz for 2003 SE. My high side was around 230psi @ 85 degrees ambient and 67% humidity. At this condition my vent temp was 42.7 with windows down. Temperature Delta exceeded my expectations. No leaks! I pulled a 132 micron vacuum in about one minute and it held like a champ for 10 before I started dumping refrigerant into it. Charge time took approximately half an hour introducing gas only (upright can) and intermittently revving to 2krpm and holding for several minutes at a time. Now my biggest problem is my big fancy Hollywood sunglasses fogging when I get out of the car. Something for you to shoot for/gauge your performance by when you get yours back together. Below is vent temp after a 20min drive with windows up and on recirc, with the current weather info and time below. https://cimg5.ibsrv.net/gimg/maxima....b702a137bf.jpg https://cimg6.ibsrv.net/gimg/maxima....280aef29ec.png |
Quick note: I hate to be presumptuous, and I certainly don't intend to insult, but when you said "mess around with it" I assumed you checked compressor fuses, relays, console switch and all that crap? You said you jumped it too, essentially bypassing all of that, so it didn't phase me earlier to voice the electrical components. You're a 7th gen vet, I just assume we know what we're doing sometimes. Just making sure that's out there before you disassemble the entire front end of your car and part of your motor!
Finally got around to working on the car today. I ended up not pulling the front end as planned because 1) thats the hardest way possible to do the job and 2) im too busy with painting other stuff to deal wih prepping and painting my grill like i wanted to. I replaced the compressor and condensor along with both hoses. AC works great! Within seconds of adding freon the compressor kicked on and did its job - last time the compressor did fck all. Overall took me a couple of hours going at a very leisurely pace. Job its much easier than i imagined, then again, im running out of jobs i have not done yet on these damn cars so my opinion probably aint worth much to anyone reading who is new to all of this.
All that being said, anyone have ideas on what to do with my old compressor? Its definitely toast, i didnt want to throw it out though since its an OEM calsonic unit and perhaps worth something to someone, somewhere. |
Fabulous!
lets take a step back, is it easy to simple recharge your ac? or does it require all the stuff in this thread?? im thoroughly confused
(Post 9205807)
The problem with your question is that if you need to recharge your AC, it means you have a leak somewhere - where that leak is will determine how simple it will be. Your first step should be determining where the leak is using UV reactive dye. That the hardest part, and its certainly not hard. Buy some manifold gauges off amazon or from china freight, the little can piercer adapter, and a couple cans of r134a. Borrow a vacuum pump from autozone for free. You technically dont even need the gauge set if you instead choose to simply weigh the amounts of r134a youre adding, probably the better method tbh. Basically you suck all the air/refrigerant out of the system, make sure it holds vacuum with the pump off (this ensures the system is sealed), and then add the correct amount of r134a to the low pressure port. Thats it. Its brain dead easy. Again the only trouble is figuring out what is broken or what is leaking. Its a very simple and straight forward system. |
nah ! nothings broke I still have AC, but what is the notion of recharging your ac? i feel like it was a maintenance kinda thing? if not I will leave it alone ! but from what I know my 2002 never had an AC recharge or maintence and i want to make sure it is "maintained" in 2019 and keep it running and performing
(Post 9205887)
awesome thank you slamrod ! i got this feeling with the recharge thing that there is a liquid level of refrigerant that needs a fill up or replenish from time to time. but that is not the case =)
© 2024 MH Sub I, LLC dba Internet Brands
