Low beam and rear tail light both went out at the same
Both my low beam and rear running light went out at the same time. I have a light on my dash for the lights and i think my rear brake light on the same side went out. Is there a fuse or something that would cause this? My high beams both work. I couldnt find any fuses for the lights in the under dash. Anyone find anything similar or should I just buy all the new bulbs? The filaments look fine and the bulbs arebt burnt. Thanks for all the help.
Ok, went and swapped all the bulbs, checked all the fuses, and swapped all the light relays. absolutely no change in what lights were out, so all bulbs, fuses and relays are good. Thinking ill have to do a voltage drop down test and check for bad grounds. Has anyone had similar problems? Ive searched on the forums but couldn't find any viable threads. Please if anyone can link me to the threads or help me out I don't want to take it to the dealer but I also am wrapped up in so many other projects. Thank you so much if you can help me.
VonLixion
04-11-2014 05:40 PM
DukeDuke
01-08-2006 03:26 PM
Umass021
10-15-2005 04:45 PM
