Unable to pump gas into my 2K maxima
Whenever i open the gas cap, i hear either pressure releasing into the gas tank or from the gas tank.. i guess the venting / evap is broken. I read about not doing the over-filling could cause this just now and i am guilty of overfilling.. Now how do i go about checking if it is a totally blown charcoal canister or just some clogged up connecting tube.. i have the Haynes Repair manual but it says very little about which hoses goes where etc.. can some one give me some tips ?
Also this is a really old car - i am hoping to keep it usable for another year tops. Or can i just periodically keep opening and closing the gas cap to work around this problem.
thanks!
thanks!
Pollution laws require that gasoline fumes not be released into the air, so when the engine is running, vacuum is applied to the gas tank and the fumes are sucked into the engine and burned up. When you turn off the engine, the vacuum is slowly released. Sometimes people will hear a wheezing sound while this is happening. But if you remove the gas cap before the vacuum is removed, you will get the pressure sound you are referring to.
thanks!
thanks!
mark217
07-29-2019 09:27 AM
FormorAccordMan
03-03-2003 05:31 AM
