Are all TSB's Limited to 3yr/36k???
Are dealers only obligated to provide service on a TSB within 3yr/36k or does it depend on the nature of the TSB?
Re: Are all TSB's Limited to 3yr/36k???
Originally posted by JohnNixon Are dealers only obligated to provide service on a TSB within 3yr/36k or does it depend on the nature of the TSB? A Technical Service Bulletin is a notice sent out to Nissan service departments describing a common problem and a fix that has been found to work. If your car is affected and has the problem they pay for fixing it only if warranty is still in effect, otherwise you pay. Sometimes a mfr. will find a problem so bad and common they extend warranty coverage for it. GM was famous for giving these "secret" warranties in the days of 12mo/12,000 mile warranties back in the 70's. But you had to know one existed, take it to the dealer and ask for the repair. Buddywh |
Re: Re: Are all TSB's Limited to 3yr/36k???
Thanks for the info Buddywh.
I'm looking specifically at TSB NTB01-018 (Manual Transmission - on/off throttle sensitivity). Since the fix for this is a new program to the ECU...does anyone think this would be covered by warranty after 3yr/36k? This is a grey area I think. The fix is a software solution, it's not actually a malfunctioning part.:( |
Re: Re: Re: Are all TSB's Limited to 3yr/36k???
Originally posted by JohnNixon Thanks for the info Buddywh. I'm looking specifically at TSB NTB01-018 (Manual Transmission - on/off throttle sensitivity). Since the fix for this is a new program to the ECU...does anyone think this would be covered by warranty after 3yr/36k? This is a grey area I think. The fix is a software solution, it's not actually a malfunctioning part.:( |
Originally posted by JohnNixon Thanks for the info Buddywh. I'm looking specifically at TSB NTB01-018 (Manual Transmission - on/off throttle sensitivity). Since the fix for this is a new program to the ECU...does anyone think this would be covered by warranty after 3yr/36k? This is a grey area I think. The fix is a software solution, it's not actually a malfunctioning part.:( But if it's cheap, and such a good thing to do, I'd take it in and do it any way. buddywh |
arent engine and tranny are under 9 year warranty? correct me if I am wrong.
Originally posted by BuddyWh A TSB is not the same as a recall so dealer's are not obligated at all to provide service on a TSB at no charge to you. A Technical Service Bulletin is a notice sent out to Nissan service departments describing a common problem and a fix that has been found to work. If your car is affected and has the problem they pay for fixing it only if warranty is still in effect, otherwise you pay. Sometimes a mfr. will find a problem so bad and common they extend warranty coverage for it. GM was famous for giving these "secret" warranties in the days of 12mo/12,000 mile warranties back in the 70's. But you had to know one existed, take it to the dealer and ask for the repair. Buddywh |
Re: Re: Re: Re: Are all TSB's Limited to 3yr/36k???
Originally posted by sleepermax Even if it's not it's only $40-50 bucks or so. I'd HIGHLY recommend getting it done if you've got a 2K or 2K1. |
Re: Re: Re: Re: Re: Are all TSB's Limited to 3yr/36k???
Originally posted by JohnNixon I'd be happy to pay $40-$50 for this fix. But I can't see how my dealer charges $65 to get the f*ing diag code for me that they would do this re-program so cheap. I hate the dealer, so I was hoping for some factual angle I could take that would 'persuade' into being obligated to do it. By the way... if I have the SES light on and a code set my dealer will read the code and reset the light for free. When I did it the first time I asked if this is only while it's under the 3/36k and he said anytime. I was wondering if it was due to pollution control warranties and changing laws in Texas this year. They won't renew safety inspection if the SES light is on or a code is set- and they won't clear it. But then it could also be just because it gives them a chance to sell you a repair! BuddyWh |
Originally posted by JohnNixon Thanks for the info Buddywh. I'm looking specifically at TSB NTB01-018 (Manual Transmission - on/off throttle sensitivity). Since the fix for this is a new program to the ECU...does anyone think this would be covered by warranty after 3yr/36k? This is a grey area I think. The fix is a software solution, it's not actually a malfunctioning part.:( l8tr -- SS |
Re: Re: Re: Re: Re: Re: Are all TSB's Limited to 3yr/36k???
Originally posted by BuddyWh Hey, I hear ya. If yours is still under the 6/60k warranty by all means take it in and expect the service at no charge. By the way... if I have the SES light on and a code set my dealer will read the code and reset the light for free. When I did it the first time I asked if this is only while it's under the 3/36k and he said anytime. I was wondering if it was due to pollution control warranties and changing laws in Texas this year. They won't renew safety inspection if the SES light is on or a code is set- and they won't clear it. But then it could also be just because it gives them a chance to sell you a repair! BuddyWh thx -- SS l8tr |
Re: Re: Re: Re: Re: Re: Re: Are all TSB's Limited to 3yr/36k???
Originally posted by ssiperko This is a quality organization who values the oportunity to obtain your business and my advice is to support them as they are far and few between. We will do the same for "our" customers at the dealer I work for. I have seen many times a customer bring in a vehicle for a "check" and get info from HIGHLY trained people and then take and have repaired elsewhere. Sometimes cheaper is not! thx -- SS l8tr They may be highly trained and well equipped, but the application of that training is at best an if-fy proposition. In my experience. BuddyWh |
| All times are GMT -7. The time now is 01:11 AM. |
