Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   What's this (https://maxima.org/forums/5th-generation-maxima-2000-2003/96073-whats.html)
NYC2SD Jun 20, 2002 11:31 PM
What's this
Anyone know what is this connector for. Its on the passengers side lower air dam.
http://images.cardomain.com/installs...823_9_full.jpg
mdeal Jun 21, 2002 05:28 AM
That is the ambient air temperature sensor for the AC (auto AC). That guy determines how warm it is outside and feeds that info to the AC brain, as do several others sensors in the car in an attempt to adjust the AC level. Also, the air temperature sensor for the auto-dim mirror is mounted in the same location, which that sensor could be for the mirror if you do not have the auto AC unit. I have two sensors in that same location, for example, since I have auto AC and an auto-dim mirror with the temperature display.
I just replaced my ambient air temperature sensor, as you have pictured, due to some weird activity of the AC.
Padsy Jun 21, 2002 05:38 AM
I disagree, I believe it is the light sensor for lightspeed:laugh:
Shaydz Jun 21, 2002 06:41 AM
I disagree as well, I think it is an electronic whistle to warn deer that you're coming in at mach 1 (come to think of it... the whistle sound would be behind you then, wouldn't it?)...uuhh.. Nevermind.
Padsy Jun 21, 2002 06:53 AM
If Im going the speed of light, and I turn on my HID's what will happen.....???
Will I see my self in the auto-dimming rearview mirror??
:eek: :laugh:
MichaelAE Jun 21, 2002 08:58 AM
:eek: :laugh:
Two points for creativity. :)
NYC2SD Jun 21, 2002 08:59 AM
:eek: :laugh:
Will you even need an auto dimming mirror? You'll be outracing the glare! :cool:
mingo Jun 22, 2002 02:16 AM
the auto climate control sensor is right by your gauge cluster. that little hole thing.. that wire connector is something else.
Tony Fernandes Jun 22, 2002 02:23 AM
Re: What's this
Why don't you unplug it and see what doesn't happen?:D
Tony
KaxMaxSEAE Jun 22, 2002 03:06 AM
You can't go the speed of light. But you can get close, and your HIDs will come on.
Yes.
If you can handle the math, go take a modern/quantum physics course that discusses relativity.
Really weird sh!t happens...
