Stop Light in 2004 Maxima.....
Anyone know how to remove the Brake light housing in an 04' Max. I took out 2 bolts but there are 2 "stubs" that don't seem to want to budge.
REAR COMBINATION LAMP PFP:26554
Bulb Replacement EKS005AX 1. Remove rear combination lamp. Refer to LT-148, "Removal and Installation" . 2. Turn bulb socket counterclockwise and unlock it. 3. Remove bulb. Removal and Installation EKS005AY REMOVAL 1. Position trunk room trim aside. Refer to EI-42, "Removal and Installation" . 2. Disconnect rear combination lamp connector. 3. Remove rear combination lamp mounting nuts. 4. Pull rear combination lamp to remove from the vehicle. Copy and pasted from the maintenance manual... All it shows is the 2 nuts and the wiring connector: 1st nut is sever inches higher than where the wire come through and the 2nd is just below. |
© 2024 MH Sub I, LLC dba Internet Brands
