Z rims fit on 6th Gen Maxima?
Will Z rims fit on our 6th gen maximas? I think the Nismo bronze rims would be great but dont know if they are correct offset.
the Z is basicly the same dimentions of a max when it comes to wheels, so yes why not...
FYI... the lower the offset number is the closer the wheel gets to the inside fender of the car... |
Tek: Do you know what the offset is on the stock Z rims?
has to be 40mm the same as the max........ the oem rims don't go to far off this number.. they are usually around 30mm to 40mm..... in order for this rim to not fit it has to be a 30mm and below...
**** I'm not sure exact offset but they will fit no prob.... |
I found the exact offset of the Z here:
Size PCD------------------Offset(s)--------------Weight------------Finishes 18X8 5X114.3--------------30---------------------18.2--------------Silver 18X8.5 5X114.3-------------33---------------------18.6--------------Silver this site might help: http://www.discounttire.com/dtc/broc...eelOffsets.jsp |
© 2024 MH Sub I, LLC dba Internet Brands
