Oil Change
Just a quick question had my oil changed now i cant get my oil change indicator to stop going off, Can anyone help out here?.... Thanks
go to the oil change menu and then press and hold the reset button. It will return to 0 miles.
Do you mean the maintenance reminder thingie in the info screen? I don't know if it's the same in navi versions, but on mine you can set the interval and reminders using the MAINT and SETTINGS buttons on the console.
After the oil change, you just press MAINT to pull up the oil change interval and then hold it, and it will reset. |
I've pushed all the resets but when i turn the car off and start it again the indicator that i set at my last oil change stays on.. Any thing else to try..
as soon as you hit the maintenance button, oil change # will flash (or the brackets will). move the center knob to adjust what you want. you can only do this while in park.
Thanks it reset
© 2024 MH Sub I, LLC dba Internet Brands
