Fog Replacement/+other exterior bulbs
I've had several requests for the instructions on how to get to the fog bulbs, so here it is again. Perhaps our moderator could make it a sticky.
For the driver's side you need to remove the intake or the stock air filter. This will give you access to the bulb. For the passenger's side, remove the fluid reservoir (there's 2 10mm bolts holding it in place). After that you'll need to remove the fill tube for the windshield washer fluid. You can do this by twisting it counter clockwise. After that you should have access to the bulb.
Also, please note the bulbs/holder will only go in one way. If you are having trouble getting it in, try turning it over.
this is the same procedure to follow when getting to the turn signals.
remember, bulbs are covered under 3 year/36k mile warranty. this is if you want to change color bulbs or if warranty is up.
bulb sizes (which are also in your manual):
fogs are H3 (55W)
turn signals are 1157
cornering lights are 3156 (27W) and can be accessed by removing 2 screws directly under the bumper below them.
fogs are H3 (55W)
tail light removal:
http://forums.maxima.org/showthread....ighlight=tails
Headlight removal:
http://forums.maxima.org/showpost.ph...0&postcount=35
should be able to access them in the engine bay. pm me if you must remove the assembly (manual does not say it is necessary and we know the turns and fogs are not even though manual says to.)
Headlight removal:
trsandrew
10-25-2015 02:47 PM
Calabar
10-05-2015 09:57 PM
