Info on this grille needed.
http://memimage.cardomain.net/member...85_20_full.jpg
I'm getting my front lip installed. Meanwhile, I am interested in this setup, both top and bottom. Does anyone know where I can purchase this set? |
I'd like to know also. It looks good! Only thing I would do is put the Nissan logo back on the grille.
the lower peice is from the 5th gens (00 maxima) lower grille, it don't fit perfect and needs some bending, but it works...
http://www.grille-tech.com/detail.html?prodid=87 |
The lower grill does need to be adjusted to fit the Stillen front. Here is a pic of my front with Stillen lip and powdercoated black.
http://i4.photobucket.com/albums/y12...r/PICT1031.jpg http://i4.photobucket.com/albums/y12...r/PICT1029.jpg |
Thanks for the info guys. I just went ahead and ordered the top piece from usspeedonline.com and the bottom piece from grille-tech.com
I was the first one to do the lower valence grill install, and it's been getting a lot of attention everywhere I go. Yep you have to tweak it a little to make it work, but the result is great... On the emblem, the speed grill is solid, but you can order a nissan hamburger (the one for the front end of our car) and then cut the hole using a dremel. Make it fit really tight and then finish it off with epoxy paste on the back of the emblem. It's not very difficult, I did it with the grill installed in the car!
http://memimage.cardomain.net/member...53_44_full.jpg Looking at Dues's pic now, it really looks like a stretched-out G35 coupe. Definitely better than the 4-door G35 available now.... |
you need the stillen lip to use the lower valence. will not fit or look good on the stock one.
Ordered Saturday, came in Thursday. 15 minute install and half of that was chasing my kid in the parking lot.
Just one question, the black plastic cover thats over the to of the factory grille (first thing you remove), does that go back on afterwards or it doesn't matter. Does it have a useful purpose? I was so excited to see my grille on, I forgot to look to see if I had any left over parts. |
http://i4.photobucket.com/albums/y12...r/PICT1031.jpg http://i4.photobucket.com/albums/y12...r/PICT1029.jpg That is a good look.. well done mate.. :woot: |
It is part of the factory grille, no need to install the black cover with the SSE grille...
Sort of on topic... but where is the best place to get a Stillen Lip? Other than directly through Stillen... I saw SCO has it, but was curious if there were any other options...
Thanks, Kaz |
my advice on the lower grille would be home depot.
Thanks, Kaz |
Originally Posted by Y2KSESteve
Dont forget to call in for an additional 5% off. ;)
From who? Stillen or SCO?
I second the Home Depot advice.
Us, SCO. :nod:
I'll keep that in mind. Thanks! |
© 2024 MH Sub I, LLC dba Internet Brands
