Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   6th Generation Maxima (2004-2008) (https://maxima.org/forums/6th-generation-maxima-2004-2008-48/)
-   -   It's time to drop (https://maxima.org/forums/6th-generation-maxima-2004-2008/335064-its-time-drop.html)
KCMAXX Dec 26, 2005 11:37 AM
It's time to drop
Im thinking im finally ready for a drop. I know there has been issues with the Eibachs, some have had probs, some havent. Theres the Cattman springs that people seem to be content with and Im sure theres a few others out there by now. I need opinions on which to buy... I tried researching the Cattmans on their website but found nothing for our gen. Please give me some insight guys, im wanting this done soon.
Thanks in adv.
Mike:hat:
DeusExMaxima Dec 26, 2005 12:39 PM
Cattman has springs. Just contact him by email and he will get em for u. U wont be disappointed. I highly recommend the RSB as well. I will make the car handle like a dream
kamski Dec 26, 2005 01:41 PM
Ya what he said. I got my Cattmans and I love them, I ordered with the rear sway bar also. I cant stand to look at stock now, I dont even want to remember how it drove before but it was junk compared to now.
Goo luck bro,
Kam
boone Dec 26, 2005 05:55 PM
My Eibachs have served me well. I researched all of the noise issues people were having and I admit I was a little concerned going in but I pulled the trigger just the same. I couldn't be happier with my combination of Eibachs and adjustable shocks and struts. The only thing that really held me up was my concern about the Eibachs messing up my stock struts and shocks. So I took a little longer to get them put on cause I had to save up for the aftermarket struts and shocks.
jcton20s Dec 26, 2005 10:16 PM
I have just a 2 inch drop on the front from eibach with stock struts and shocks. No issues so far (knock on wood) and the look is perfect with the 20's.
jsmithsole Dec 26, 2005 10:56 PM
I had my Eibachs on for about a year and a half with no problems at all, if I was to to buy now though, I'd go the Cattman route for sure (with the RSB)
MiamiBlackMax Dec 26, 2005 11:26 PM
can anyone tell me how much the cattman spings and RSB go for ?
akaxmrxhammer Dec 27, 2005 01:24 AM
i say go with cattman springs. i have koni/front kyb/back shocks with eibachs and have noise issue. i've tried everything from greasing to wire wrapping. the clunking sound still exists. i was leaning toward k-sport coilovers, but i already spent a lot of $$$ on my current setup.
PapaL Dec 27, 2005 03:09 PM
I as looking at some Intrax springs, they sell for about $225'ish. Asked dealer how much to install, since I was laready getting an oil change, and the quoted me $760 for labor plus $80 alignment. Seems like way to much. How much should an install be? Ballpark'ish.....
KUBLKMAX Dec 27, 2005 06:09 PM
should not be more that 200 bucks. You can do yourself for free.
boone Dec 27, 2005 07:14 PM
You'll still have to get the alignment done but around $200 for installation labor only sounds about right. You can do it yourself but be very careful since you'll be working with loaded springs. Getting help from a buddy is a good idea.
ramberg Dec 28, 2005 01:22 AM
I have the Eibach springs and Stillen RSB over a year now and have had no problems.
Warren
02MaxGLE Dec 28, 2005 04:06 AM
Eibach drop here....pulls to left, no one can seem to fix it. Including Nissan
andymax95 Dec 28, 2005 10:43 AM
The characterics between eibachs and cattman are probably pretty damn close. I think what it comes down to is what color spring do you wanna go with?
By the way what are springs used for?:newbie:
JiuJitsuThug Dec 28, 2005 05:22 PM
I have the Eibachs and Stillen RSB - completely happy with it.
DeusExMaxima Dec 28, 2005 06:33 PM
Check tire pressure. Take it alignment specialist. Does it pull when u brake, or all the time?
akaxmrxhammer Dec 29, 2005 01:21 AM
did you ever get rid of that clunking sound ?
2004 Smoke Dec 29, 2005 07:13 AM
Is anyone finding the need to add caster/camber plates when you lower the car? Anyone do this with the Cattmans?
MObruin Dec 29, 2005 07:34 AM
Add me as another VERY satisfied member of the Cattman springs and RSB club!
Got mine installed a couple days ago and now I take corners like nothing! Plus the gap is completely GONE!!!
:mardi:
-MO-
Ludxima Dec 29, 2005 08:22 AM
My Eibachs came in yesterday. I want to do this install myself, but never worked on a Nissan before. I've only lowered Honda's. Would it be installed the same way as the Honda's? I looked under my hood just for fun and didnt know how to take off those engine covers to unbolt the strut. Is there a writeup of how to exactly do it? I've tried searching, but its not as specific as I would want it to be.
DeusExMaxima Dec 29, 2005 09:13 AM
Hey MO, how bout some pics!!!!
2004Smoke: No need to adjust camber. I had mine checked and its about 1 degree negative which is very good for spirited street driving.
maxedout4 Dec 29, 2005 11:07 AM
If you go with cattman please post your results, that is going to be my next mod (springs)..
RHMax Dec 29, 2005 11:14 AM
Progress/Cattman springs and RSB here. My father-in-law drove my car while he was here last week. He loves the way it handles. He want the same setup for his(my old) '04SE.
andymax95 Dec 29, 2005 12:08 PM
I don't have a write up but have pics on my website of the install.
The front of the car is a strut spring combo ( need spring clamps) Remove the plasitic cover in the engine bay, remove the 3 bolts holding the strut to the frame and remove the two bolts behind the rotor. Place the spring compressors on the springs, make sure they are taunt, then remove the nut on the end of the strut shaft. Spring comes off and then pop the new one on.
In the rear, its a seperate spring strut setup.
Lift car up, put on frame stands, then take the jack and put under the spring holder part. Its a hindged part and only one bolt needs to be removed. Cause the spring is under pressure that why the jack is there, oonce the bolt is removed, slowly lower the jack and out comes the spring, then put new spring in, use the jack to line up the holes, put bolt in and done, the back end is really easy to do.
maxedout4 Dec 29, 2005 02:30 PM
Thank you for the feedback.. and by the way nice pic.. looks like mine when I purchased it.. I had the same rims minus the tints and all the other mods i have done..
PapaL Dec 29, 2005 02:37 PM
Did you guys with the cattman springs oder from the website? I don't see anything that says 2004-2006. Only see the following:
Progress Performance Sport Springs
PPSS
1995-2002 Maxima/I30; All (Does All mean all years and models?)
RHMax Dec 29, 2005 05:14 PM
PPSS
Call or email, check Group Deals section..
VQPRO Dec 30, 2005 04:56 AM
EIBACH all the way 2inch in the front and .08 of a inch in the back the best spring for the 04 , if you install it right no noise ever,
BLAXIMA2K4 Dec 30, 2005 05:49 PM
Why are you yelling?!?! :slap: lol
VQMAX05 Dec 30, 2005 08:09 PM
I had EIBACH.............blah!!! noises, clicking......no good.
NOW, I have Cattman Springs/RSB(2 months now)..........excellent...........like a whole new car...great product.
Now with my NIMSO wheels, the lower unsprung weight makes the car handle even better....PICS to come!!
MAXIMA-GHOST Dec 31, 2005 02:01 AM
Ok, it looks like i will be getting these next.. I will be going with the Cattman since i hear nothing but great things with them.. Are you guys using the stock shocks and struts? Camber? Please let me know where to get the whole set-up and the RSB as well...((BEST PLACE)) Which Shocks / Struts? Thanks guys..:wavey:
KCMAXX Dec 31, 2005 03:28 AM
I remember a few saying they were just installing the Eibach fronts. Im sure everyone with the cattmans are doing all 4, correct?
PapaL Dec 31, 2005 07:12 AM
They no longer have the group deal that was mentioned here going on. Call Brian and I'm sure he can hook you up if you buy springs and an RSB. I ordered mine last night.
chernmax Dec 31, 2005 07:23 AM
I have had EiBachs on my ride for about 18 months now and I have had ZERO problems and ZERO noise. IMO, I still think they are the best bang for the buck.
SoCalMax05 Dec 31, 2005 08:59 AM
Deus - Did you install your springs yourself or someone local - I also live in the wonderful city of Upland.
Any Ideas of who you would recommend for the install?
MAXIMA-GHOST Dec 31, 2005 06:34 PM
did you order the whole package from him including the RSB?? PM me if you like.. and thanks for the info...:bowdown1:
dannydoo Jan 2, 2006 09:12 AM
check out car domain for some cool drop pics
chernmax Jan 2, 2006 09:49 AM
Can you be more specific, there are thousands of rides listed!!!
