Any more news on '07 Maxima?
Old 03-05-2006, 12:33 PM
  #241
SilverMax_04's Avatar
Originally Posted by SteVTEC
Yep, looks like I'm back. Now if you think the gearing is non-optimal in your 04 6spd, you should go for a drive in a 3.0 5spd. Do you know what my 2000 rpm speed in top gear is? 45 mph. At 80 mph the VQ30 is up around 3500 rpm. Considering all the highway driving I do, it's annoying. It's fun though, because even with pretty aggressive highway passing maneuvers you don't need a downshift, and you can merge in 5th gear. But then again this car was designed in the era of $1.50/gal gas. Not so anymore so I think there's good justification for a shift in priorities.
Nissan could easily put taller gearing in that would give better efficiency while still not sacrificing the performance feel all that much. All they have to do is tweak the e-throttle gain map for the higher gears so that the engine is loaded a lot heavier for better performance, while not requiring the driver to increase throttle position from current which would still give them the perception of lots of reserve power and lively performance.
Steve, you did not quite understand my complaint about the close-ratio 6-speed manual trannie. If I'm racing this car, this is an ideal trannie. You can more easily keep the engine's RPMs in the ideal range by shifting gears as needed. This will maximize the car's performance on the track. But if you are not racing, the gears in this trannie need to be further apart for better economy. I would like a lower first gear for somewhat better starting ability. (I have a tendency to stall the engine if I'm not careful because of the taller than necessary first gear.) Third gear is ideal. The gears above 3rd should be taller, such that 6th gear gives you about 62 mph at 2 K RPM (not 55 mph).
The existing 6-speed at 80 mph is almost turning 3 K RPM (which is actually 82 mph). I certainly agree that there is now (with high gasoline prices) a greater priority for Nissan to shift priorities with their engine-trannie combos. I'm recommending taller gearing in the upper gears of the 6-speed to improve fuel economy. A higher "differential" gear would also help both manual and auto trannies improve fuel economy, but would also require some gear ratio changes in the trannies.
SilverMax_04 is offline
Old 03-05-2006, 02:39 PM
  #242
Mike_TX's Avatar
You're right in that I was referring more to the Infinitis when I say "drink" fuel, but it's not all due to gearing also. For highway that would definitely be the case, but not during city driving. The 18 mpg the G35 gets is practically the same as the 300C which is 600 lbs heavier and has a huge V8 engine. That tells me that the part-load efficiency of the high end VQ35 is "not that great", or those are some damned good domestic V8 engines.
Yep, and there's a LOT of monkey-business in the EPA ratings game, too. A mfr can set up an engine/drivetrain specifically to score well in these fuel economy tests, and with the current attention to gas prices, I'm sure a lot of thought goes into doing just that. And keep in mind a V8 actually has some advantage at certain loads, since it's stressed less than a smaller V6 doing the same work.
Anyways, the new Toyota 3.5L engine makes more power on regular fuel than the VQ35 in the Maxima does on premium, gets 2 mpg better in the city, and 3 mpg better on the highway. So the bar has been raised and there's room for improvement. Another point of comparison is the Acura TL and Honda Accord V6. They may be a bit less powerful, but despite the same EPA ratings it's not uncommon to hear reports of 34-35 mpg on the highway in those cars. Consumer Reports also managed about that, and got 2 mpg better overall in those cars than the Maxima despite having about the same EPA ratings.
The Toyota 3.5 apparently does benefit from some later engineering, although I hear in the real world, people aren't getting the EPA numbers (whereas many, many Maxima owners EXCEED them!). The TL runs on less displacement (3.2l v. 3.5l in the Maxima), so I'm not surprised to see a little better mileage. Less torque and lower pumping losses are going to yield better economy. Ditto for the even less-powerful Honda 3.0l.
I don't think FWD alone counts for anything as far as fuel mileage. Compared to the G, the Maxima has a more economy tuned engine, and highway revs at 75 mph are about 300-400 rpm less too. So little stuff like that can make a big difference when you're talking about highway mileage.
I don't know, Steve ... automotive engineers say front-drive is good for about a 10% increase in fuel economy all by itself. It's just a more-direct, more efficient driveline and it pays dividends in frictional and parasitic losses. That, combined with the more-relaxed final gearing, as you point out, can make a significant difference!
Mike_TX is offline
Old 03-05-2006, 04:54 PM
  #243
Dyno plot says I have the most area under the Administrator curve
SteVTEC's Avatar
no I gotcha
The V8s I mentioned (the Hemi and GM's LS4) all have variable displacement setups, so technically to produce the same amount of power as a V6, they can switch to V4 mode which then has the same load spread across only 4-cylinders instead of 6, or the full 8. Relatively higher load on a smaller displacement is generally more efficient than a lighter load spread across more, although there's a lot of other factors too.
The Honda vehicles definitely get a bit better economy but I think there's more to it than just the lower displacement in this case. They have a SOHC setup with roller rockers (lower overall friction), a belt cam drive instead of a chain (lower friction), a smaller bore than Nissan's VQ30 (favors better combustion efficiency), and a simplified VVT setup (2-step cam-switching, no cam-phasing, minimal overhead, simple, elegant, and effective). There is much to be said about pushrods when it comes to efficiency also. Take GM's LX9 3.5L V6 (Malibu). Single cam, small chain drive, only 2v/cyl, and 32 mpg hwy, and Consumer Reports testing it out at 36 mpg hwy. I've rented these and I can vouch for the oustanding efficiency. Of course, they'll get slaughtered by a Maxima but they're still more efficient.
I really don't think you're going to go from 18/25 mpg to 20/28 mpg just because of FWD. Would be curious to know who/where you heard this from, and if you have a link, because it sounds like marketing fluff/BS to me and not "automotive engineer" speak. That's about the G35's mileage vs the Maxima and we know that the G has shorter more performance tuned gearing, probably more performance tuned shift mapping, and the more performance tuned engine which most likely has poorer part-load efficiency than the Maximas. That's easily 2-3 mpg right there and we haven't even started talking about aerodynamics or drivetrain config yet. You can look at the Camry/Avalon vs the IS350 and you'll probably find about the same thing. 22/31 mpg on the FWD vs 21/28 mpg on the IS350 but there are a lot of differences. A n00b could look at that and say "hey, FWD = 10% better" when that really doesn't have anything to do with it.
It's really hard to make direct comparisons like this, but if RWD was really significantly less efficient than FWD to the tune of 10% then you would probably see some pretty big differences on the dyno but you don't. 10% is a lot. An SAE paper I have on the topic that looks at that sorta indirectly implies that a RWD live-axle setup is the most efficient because it's the simplest. It states that FWD or independent suspension RWD is 2-7% worse due to much more complex final drives.
With FWD, engineers know it isn't really for performance anyways so they put in the more economy tuned engine, they put in the more economy oriented shift mapping that'll hold higher gears longer, and they put in the taller gearing that has it revving lower during cruise. And then they do the exact opposite on RWD and tune everything up (at the expense of economy) because it's a "premium" RWD product. Watered down to basics for the masses, some engineer could say that "FWD = 10%" just for the purposes of explaining something, but it's not because of FWD but rather because of all of that other stuff.
2006 BMW 530iA: 21/29 mpg EPA
2006 Accord V6: 20/29 mpg EPA
Same displacement (3.0), similar internal config (accord: 86 x 86 mm, bmw: 85 x 88 mm), similar overall size, similar power (244/254 vs 255), similar weight (both 34xx lbs), similar aero. The 1 mpg better on the BMW in the city I would attribute mostly to Valvetronic which cuts way down on throttling losses especially at idle, and not to the drivetrain config (FWD or RWD).
Looks about the same to me.
SteVTEC is offline
Old 03-05-2006, 08:14 PM
  #244
Mike_TX's Avatar
We're in agreement on one point for sure ... there are lots of factors that go into the fuel economy equation! And while I can't readily pull up sources for the 10% economy advantage, I have read it several times over the years.
We all know, of course, that increased fuel economy is the *only* reason GM, Ford and Chrysler spent tons of dough to convert to FWD in the 70's, though. The Arab oil embargo forced them to find some quick way to cut gas consumption, and they saw the Japanese front-drive cars getting lots better mileage than their rear drivers. True, the Jap cars were smaller and lighter as well, but they wouldn't have spent the money to go to front drive unless they saw that as a quick way to meet the EPA and CAFE standards. We all know Detroit makes big changes only when forced.
I'll do some research when I get the time and try to substantiate the 10% story ... or correct it!
Mike_TX is offline
Old 03-05-2006, 08:29 PM
  #245
belal242's Avatar
Man i feel like I'm in automotive shop after reading the last 2 pages. And Steve nice too meet you, i find your info very accurate. Now I'm even more excited than ever for the 7Th gen. I just dont expect any of the changes that you mentioned to take place in the 6.5gen, i have a feeling they really want to just skip over this model and get the the 7th gen in early to mid 2008, as the 2009 model, but in those models i do expect the 3.7 with the 6AT and RWD or upgraded AWD.
belal242 is offline
Old 03-07-2006, 08:45 AM
  #246
95Max's Avatar
Originally Posted by RHMax
- a stock SL is equipped w/ H rated tires, which means the top speed is limited to no more than 130 MPH (probably 125 MPH), lower than SE w/ V rated tires (145 MPH limited on SE); and 6MT. Actually, ther should be a lower model like previous gens.
Actually the SL comes with V rated tires. Mine came with Continental Touring Contact CV95 which is a V rated Grand Touring Tire. Not sure but I think they changed the H to V tires with the trans change
95Max is offline
Old 03-07-2006, 07:10 PM
  #247
lightonthehill's Avatar
95Max is correct. My '04 SL (with 5 speed tiptronic auto tranny, assembled the last week of May, 2004) also came with the same 'V' rated Continental Touring Contact tires as his.
This now brings up another question: Why do all the glossy Nissan Maxima phamplets/brochures for the '04, '05 and '06 list 'H' rated all-weather tires as standard on the SL?
I checked the tire specs in my '04 Owner's Manual, and it listed 'V' rated tires as standard on both the SE and SL. The SL tires are specifically designated as 225/55R17 95V. Then, immediately and inexplicably, the manual says the 18" tires (SE) are 'V' rated and the 17" tires (SL) are 'H' rated. That is sort of a conundrum or non sequitur.
I then proceeded to examine every square centimeter of the sidewall of my SL Contis, and they are 'V' rated with no disclaimers.
So SLs do indeed have 'V' rated tires, and Nissan has a mess in its documentation.
I suspect there was some indecision early on as to exactly what rating tire would be standard on the SL, and once the decision was made (or changed) some documentation was never corrected.
But who knows?
lightonthehill is offline
Old 03-17-2006, 05:49 AM
  #248
dallasmax's Avatar
07' Pix I haven't seen in previous posts
Some might argue, but this is a much better design on the gauges! just my opinion!
dallasmax is offline
Old 03-18-2006, 04:55 PM
  #249
Mike_TX's Avatar
Shooey! Whatever that is, I sure don't like the dash! Looks too Buick-y to me. Closed-in and claustrophobic.
The whole car (exterior) looks too much like a Camry design to me ... too conservative to be called a Maxima. Our 6th Gen design looks way more sporty.
Mike_TX is offline
Old 03-18-2006, 07:53 PM
  #250
04BlackMaxx's Avatar
e you nuts, you like that dash? It screams old-fogey
04BlackMaxx is offline
Old 03-18-2006, 08:34 PM
  #251
Newbie just Registered
RHMax's Avatar
The interior is similar to the M35-45 w/o the wood/graphite trim. That steering wheel looks like it belongs in a truck.
RHMax is offline
Old 03-19-2006, 07:39 PM
  #252
Mike_TX's Avatar
I resent that! I have an '06 M45 and that doesn't look remotely like mine!
Mike_TX is offline
Old 03-19-2006, 08:47 PM
  #253
RHMax's Avatar
Oops! I said similar, as in simile is the highest form of compliment!
RHMax is offline
Old 03-20-2006, 01:56 PM
  #254
SteVTEC's Avatar
oh my lord :vomit:
I hope that isn't what the 07 interior will look like. If so, forget it. I'll either get an 05/06, used, or hello Infiniti M.
SteVTEC is offline
Old 03-21-2006, 06:16 PM
  #255
idnumber1's Avatar
oh my lord :vomit:
Rest assured that is not the interior of the new '07 Max. I can guarantee it 110%. The Max will be shown in April along with the all new Altima next month at the New York Auto Show.
idnumber1 is offline
Old 03-21-2006, 06:28 PM
  #256
Sexyass Maxima's Avatar
I hope the new max is everything we want. If not im going to get an 06
Sexyass Maxima is offline
Old 03-21-2006, 08:43 PM
  #257
Monotaur's Avatar
I'm pretty sure that this hasn't been posted before:
http://www.edmunds.com/insideline/do...ticleId=107415
Quoted (for the lazy ):
Nissan Eschews Trucks, Overhauls Cars in Model-Year 2007
Date posted: 09-29-2005
DETROIT — Nissan Motor is shifting its development focus in North America from trucks to cars in the coming year, with plans to redesign most of its current sedans, introduce its first gas-electric hybrid and add an entry-level model.
Nissan executives disclosed plans on Wednesday to launch the all-new 2007 Versa subcompact in mid-2006. But the company has a much more ambitious program in store for model-year 2007.
To make room for the Versa, Nissan will bump up its next-generation Sentra in size, performance, content and price. The 2007 Sentra, which also gets a full sheet metal overhaul, will go into production at the Aguascalientes plant in Mexico in fall 2006. The price is expected to range from about $16,000 to $20,000. The new Sentra will be unveiled officially in January at the North American International Auto Show in Detroit.
Nissan also plans to substantially remodel its midsize Altima sedan next summer, making the 2007 model year an especially busy time for the automaker. In addition, Nissan will introduce a new gas-electric edition of the Altima — the company's first volume hybrid offering in North America. The 2007 Altima will make its formal debut next spring at the New York International Auto Show.
Finally, the company will extensively upgrade the cabin of the 2007 Maxima, a year ahead of a full redesign.
What this means to you: Let Detroit talk about trucks; Nissan is turning its attention to cars in 2007. Could it be that the Big Three actually won a round?
So basically, a redesigned interior for 2007 and then a complete redesign? Interesting.
Monotaur is offline
Old 03-21-2006, 10:05 PM
  #258
Monotaur - That blurb was Edmund's interpretation of Nissan's plans. I would bet you money Nissan has not announced that the 7th generation Maxima will be released as an '08. I have found Edmund's 'guesses' to be off the mark quite frequently.
Think about it. The cabin interior of the '07 redesigned and upgraded, the front facia of the '07 redesigned (sneak peeks have appeared on this board for several months), and the whole thing becomes obsolete in one model year? I don't think so. That almost never happens with any model from any manufacturer.
I stick by my opinion of last summer: For '07, Nissan will make much needed improvements such as upgrade the interior, add a few features like tire low-pressure indicator, correct design mistakes made in the front of the 6th gen, release this '07 early - say May or June of '06, then let this upgrade ride for model years '07 and '08.
Then, in spring of '08, with much hoopla, the 7th gen Maxima will make its appearance as the '09 model year.
I have seen nothing concrete in the last eight months that would lead me to change my feelings about that being the schedule for the Maxima these next few years.
Old 03-22-2006, 05:13 AM
  #259
Monotaur's Avatar
Ah, OK, I was unaware of the track record of Edmund's guesses. Anyway, I think what you laid out makes more sense (especially in light of the spy shots). Good analysis, as always.
Monotaur is offline
Old 03-22-2006, 06:13 AM
  #260
Mike_TX's Avatar
So we've decided the intro of the '07 has slipped from April to May or June?
Mike_TX is offline
Old 03-22-2006, 11:15 AM
  #261
Mike_TX's Avatar
Are you guys actually telling me Nissan's security is so tight that no one really knows anything more about the '07???
I mean, I thought we had some Nissan employees on this board, and surely someone knows something! For example, if the '07 is maybe possibly going to be released in 30 days or so, surely that's too big a secret to hide ... isn't it? And it's been widely reported they are going to redo the interior ... but noone knows what the changes are?
This stuff has to be in production right now, even for a Fall introduction. Do they just have you guys sworn to secrecy or something?
Mike_TX is offline
Old 03-22-2006, 11:27 AM
  #262
RHMax's Avatar
These type of info is usually known to the marketing and distribution. The rest don't really get shared until before launch. I never worked for Nissan, but I've worked in marketing for another car company.
RHMax is offline
Old 03-22-2006, 06:29 PM
  #263
Nations 1st 6th Gen Turbo
chernmax's Avatar
I'm an old-fogey and I can't stand it...
chernmax is offline
Old 03-23-2006, 10:37 AM
  #264
Z
NYPD-Arnold's Avatar
We'll see the 07 Maxima very soon. They are in production already, and spy shots exist. The Altima will be debuting in the NY Auto Show, and apparently so will the upgraded Maxima.
NYPD-Arnold is offline
Old 03-26-2006, 08:58 PM
  #265
logik05se's Avatar
I dont know if im late on this...but today at my dealership i ran a locate through the nissan dealers network on the 07 maxima just for kicks and i'm not sure if this is really an option ( or the only choice if that) but when you select the options on the site, under transmission the only availble choice was CVT. Now like i said i dont know how true this is, maybe because the car isnt out yet the locate page isnt updated correctly....but i really hope CVT isnt the only choice of availble transmissions for the maxima.
and btw the launch date which was originally set for april has been pushed to july.
logik05se is offline
Old 03-27-2006, 07:05 AM
  #266
Mike_TX's Avatar
All I can say is I hope that isn't the case. My plans to get an '07 will go right directly in the crapper if CVT is my only choice.
Mike_TX is offline
Old 03-28-2006, 02:58 PM
  #267
3.5 Lover's Avatar
I just came from my Nissan Dealer and he told me the 07 Altima will definitely be on display but no word on the Maxima. That doesn't mean it won't be shown because we all know surprise is the name of the marketing game when your competing with others. If CVT is the only way to get a 07 Max, they will loose so many loyal customers. You can forget mods with a CVT, mono tone exhaust and no shifting for us that love manuals. I really hope this is not the case.
3.5 Lover is offline
Old 03-28-2006, 06:29 PM
  #268
Monotaur's Avatar
I'm sure it won't be the only option for the Maxima. I have read though, that Nissan wants to sell 10% of it's cars and trucks with CVTs within 2 years (I believe it was stated 1 year ago that in 3 years, 10% of their product will ship with a CVT). They are also going to be selling CVT's to Chrysler, so I'm guessing that they are going to start pushing the CVT pretty hard.
Monotaur is offline
Old 03-28-2006, 09:07 PM
  #269
CVTs are (fortunately or unfortunately, depending on ones point of view) the wave of the future.
As the CVT is gradually and continually improved, I feel it will beat the 'shifting' tranny in fuel economy and last longer without major repairs.
This next statement will be denied to the death by many, but here goes: at some point, a CVT equipped vehicle will be faster off the line and will out-accellerate its 'shifting' equivalent. That may not happen right away, but rest assured it will happen. The laws of physics say so.
Nissan can get away with using CVTs in every vehicle they produce except the two that have long held an image as 'sports-minded driver's' cars. The 350Z demands either a six or seven speed manual with either a five or six speed auto tranny optional. I would not expect to see the CVT, even as an option, in the 350Z for many many years, if ever. And the Maxima demands that tranny options other than CVT at least be available.
Nissan may initially make the CVT an option on the SL (or standard on the SL with a five or six speed auto optional). I hope the CVT is not even an option on the SE in the forseeable future. There is heritage, history and a faithful fan base for the Maxima as a '4 door sports car'. That fan base is not interested in a CVT in their Maxima.
Rest assured we will be able to obtain 350Zs and Maximas without a CVT tranny for at least a half dozen or more years. Otherwise, the assembly lines for both vehicles might as well shut down. And Nissan knows this.
Old 03-28-2006, 11:09 PM
  #270
Well said, and right-on, light. You got it all correct.
Old 03-29-2006, 04:19 AM
  #271
logik05se's Avatar
light on, what you said makes plenty of sense and I 100% feel the same way....I'm going to check that locate page again today and see if that was an SL model out of curiosity because being in the SL only would halfway make sense. Other then that when I seen this I was pretty disgusted I have to say, because cvt's only in a maxima is a disgrace.
unfortunatly though I can pretty much see the marketing strategy behind this being the growing demographic for maximas is becoming an older crowd.
crap.
Old 03-29-2006, 07:31 AM
  #272
Monotaur's Avatar
Yeah, what lightonthehill said makes a lot of sense. I remember reading about 6 months ago how Nissan improved their CVT design greatly, in that they were able to double the gear ratio. Also, I'm not sure if the Murano uses the "disc and wheel" design (I think it actually uses the steel belt design), but the "disc and wheel" design should be able to take a considerable amount of torque (much more than the traditional design I think).
Monotaur is offline
Old 03-29-2006, 11:13 AM
  #273
Mike_TX's Avatar
I mostly agree with lightonthehill, too, except that I don't see CVT's as the panacea for future AT's. The reason is that with a CVT, engine speed is not synchronised to forward speed - or even acceleration - so it is most efficient only at or near full-throttle operation.
Yes, I know that in a "regular" automatic, engine speed isn't directly proportional to forward speed, either ... except that in any given gear it is. And unlike a CVT (where the engine "motorboats", or spins out of proportion to forward motion), a regular AT can be driven gently and made to upshift early. A CVT simulates this behavior, but at lower speeds is actually less effcient than a conventional AT.
You need only look at EPA mileage ratings of cars offered both ways to see that CVT's rate only an average of 1mpg better than conventional AT's in City driving and the same as the AT in hwy. driving. The 1mpg edge in the City cycle is largely because of the way the EPA mileage is calculated, and most people never see that benefit in real life driving.
I see CVT's as a gimmick right now ... one that buys some time for the carmakers in metting EPA and CAFE standards. But I think they'll fall by the wayside in favor of better AT's as time goes on. Just my opinion, of course.
Mike_TX is offline
Old 03-29-2006, 01:26 PM
  #274
greg hazlett's Avatar
While having the oil changed today...
Spoke with the sales manager and he told me that not a lot of changes are upcoming for the 07 models but a V8 is in the plans for 08 models with RWD to
diversify it substantially from the Altima that is getting longer.
greg hazlett is offline
Old 03-29-2006, 01:47 PM
  #275
Wild for Width
Fr33way™'s Avatar
I'm sorry did you say V8 RWD Maxima?
Fr33way™ is offline
Old 03-29-2006, 01:50 PM
  #276
That is what the sales manager said, not sure if anyone else has heard that..
Old 03-29-2006, 02:05 PM
  #277
3.5 Lover's Avatar
Lightonthehill; what you say makes a lot of sense. Hopefully Nissan will listen. CVT's aren't bad, just not my preference and many others who love manual shifting. Autos are fine but the fun factor of having a stick cannot be equaled in a auto.
Old 03-29-2006, 02:08 PM
  #278
Z
Every sales manager that works for Nissan is apparently a moron and a liar.
Old 03-29-2006, 02:44 PM
  #279
Mike_TX's Avatar
People who hold their breath waiting for a V8 RWD Maxima will be black in the face before they see one.
And I believe you won't see either of those until a V8 has shown up in a G35 and has been there for a couple of years. It's just the nature of automobile marketing that the premium brand/model gets the goodies first, then they trickle down to the lesser models.
And as long as Nissan can maintain the V6 FWD platform for the Maxima, it will continue to do so - the current platform is solid and has a lot of life left in it. Engineering a whole new platform is an expensive and time-consuming operation and will require an total redesign (not due until the '09 model, I believe).
Mike_TX is offline
Old 03-29-2006, 04:13 PM
  #280
RHMax's Avatar
No, sales people are taught to emphasize the latest and sometimes greatest in technology. And often they have no clue what it is they are selling, nor do they care. All they want is to put something on the board.
Most of us here know more about cars in general, not just Nissans or Maximas, than the great majority of car sales people. How many of us had a moron as sales person when we bought our cars.
RHMax is offline
Quick Reply: Any more news on '07 Maxima?
